Bling Posted May 4, 2014 Share Posted May 4, 2014 Lowering will just end up as another situation where a small minority ruin it for the majority. How did it even get a cert anyway? Quote Link to comment Share on other sites More sharing options...
MRWEST Posted May 4, 2014 Share Posted May 4, 2014 Whats the story with seatbelts for vin/cert. Can i use the american ones or do i need NZ ones? Also Accuair E Level assume its all the same for cert as per a normal bag set up just needs lock out while in motion? Quote Link to comment Share on other sites More sharing options...
Nominal Posted May 4, 2014 Share Posted May 4, 2014 Whats the story with seatbelts for vin/cert. Can i use the american ones or do i need NZ ones? Also Accuair E Level assume its all the same for cert as per a normal bag set up just needs lock out while in motion? On my 64, I got through vin check with just the original US lap belts in front. Think it might be different for cert though. Quote Link to comment Share on other sites More sharing options...
BlownCorona Posted May 4, 2014 Share Posted May 4, 2014 with regaurd to having to certify adjustable suspension due to ride height being able to be changed. can you install a set of adjustables, set them how you like (above 100mm) and then somehow make them permanent? as in weld the collars (probably cant weld them) or something along those lines? I have a Toyota soarer that i want to lower and adjustable suspension is pretty much the same price as lowering springs and new shocks, but i dont want the hassle of cert, and i dont want to be able to change the height etc etc cheers, Quote Link to comment Share on other sites More sharing options...
Beaver Posted May 4, 2014 Share Posted May 4, 2014 I suspect you will fall into cert category anyway as it is not oem spec. /just cut and shut factory struts with shorter shocks and springs and plead innocence Quote Link to comment Share on other sites More sharing options...
BlownCorona Posted May 5, 2014 Share Posted May 5, 2014 wait are you telling me you now need cert for simple lowering springs?? im just looking for the most cost effective way to lower the car and give a slightly firmer ride, and i hear that soarer factory shocks dont really take well to lowering springs, but this could be internet myths Quote Link to comment Share on other sites More sharing options...
durty Posted May 5, 2014 Share Posted May 5, 2014 Would need a cert for shortening the struts /need cert for welding anything suspension related I would think Quote Link to comment Share on other sites More sharing options...
Benno Posted May 5, 2014 Share Posted May 5, 2014 Yup, but wouldn't need a cert for just adding some lowering springs and shocks provided the height was over 100mm and can be made captive without modifying the strut at all Quote Link to comment Share on other sites More sharing options...
Beaver Posted May 5, 2014 Share Posted May 5, 2014 wait are you telling me you now need cert for simple lowering springs?? no thats not what I said. What I meant was is I dont think its just the adjustablility that puts it into cert territory, I would suspect that if you change the struts from oem to aftermarket you would meet the cert requirements regardless if you made them fixed or not. Quote Link to comment Share on other sites More sharing options...
Beaver Posted May 5, 2014 Share Posted May 5, 2014 Would need a cert for shortening the struts /need cert for welding anything suspension related I would think Easy to hide though..... Quote Link to comment Share on other sites More sharing options...
AllTorque Posted May 5, 2014 Share Posted May 5, 2014 cert in not reqd if; the springs or shock absorbers are direct replacements, and replacement springs are contained within unmodified OE seats throughout full suspension travel, and replacement springs are self-retaining in their seats at full extension, without the use of non-standard devices such as wire-ties, straps, or external spring locators, and replacement springs have not been heated or cut, and springs and spring seats are not height adjustable by any means (unless OE), and replacement shock absorbers, including air-adjustable units, fit unmodified OE mountings, and suspension maintains sufficient travel for safe operation when fully laden, and suspension components maintain sufficient clearance from unmodified bumpstops when fully laden, and a minimum of 100mm ground clearance (unladen and without driver) exists below any part of the vehicle structure, or any steering, braking or suspension component2, and the normal relationship between front and rear suspension height is not unduly affected. 2 Does not include such items as exhaust pipes and exterior body panels that do not contribute to the structural strength of the vehicle. https://agentvpn.nzta.govt.nz/PT/http://vehicleinspection.nzta.govt.nz/virms/in-service-wof-and-cof/general/steering-and-suspension/steering-and-suspension-systems Quote Link to comment Share on other sites More sharing options...
Beaver Posted May 5, 2014 Share Posted May 5, 2014 hmmm, might be able to roll fixed adjustables then. Quote Link to comment Share on other sites More sharing options...
AllTorque Posted May 5, 2014 Share Posted May 5, 2014 I guess it would depend on the WOF inspectors interpretation of "direct replacement" It's going to make him scratch his head anyway and cause you problems. Perhaps Clint will come in with a definite answer. Quote Link to comment Share on other sites More sharing options...
Fat Dan Posted May 5, 2014 Share Posted May 5, 2014 It's going to make him scratch his head anyway and cause you problems. This^, to me, in theory it sounds legal, but its hard enough getting your certed 80mm ride height a wof without "the man" getting pissy cos he cant fit his 100mm block under it Quote Link to comment Share on other sites More sharing options...
BlownCorona Posted May 5, 2014 Share Posted May 5, 2014 the soarer is jacked as hell at the moment, im not gonna be rolling super slammed because its a highway car and the speed bumps in blenheim are like 3ft tall, but i just want it to ride nice through the hills and look nicer when i swap the wheels out. hopefuly clint will be along soon, but from reading ltsa stuff i cant see how it would be an issue, apart from perhaps the welding of suspension components. exploring all my options anyway Quote Link to comment Share on other sites More sharing options...
Lunacy Posted May 5, 2014 Share Posted May 5, 2014 Ok spoke to compliance guy in New Lynn this morning about my cut out VIN from the firewall, and he basically said to be 100% legit get a new VIN reassigned. Said it has to be done by the right person at VTNZ, and then should be all sweet. Would that be enough for LV certificate purposes? Quote Link to comment Share on other sites More sharing options...
Ranter Posted May 5, 2014 Share Posted May 5, 2014 Yeah it will mate, that widebody of mine has no chassis numbers at all, everything done from VIN. Similar to certing fresh imports, run them thru to get vin first. Quote Link to comment Share on other sites More sharing options...
cletus Posted May 5, 2014 Share Posted May 5, 2014 ha, the number plate is ftp. Is there a minimum height for a motorcycle? not that i can find, the VIRM doesnt mention anything about 100mm minimum, and theres nothing in the cert book about motorsicles Quote Link to comment Share on other sites More sharing options...
cletus Posted May 5, 2014 Share Posted May 5, 2014 Whats the story with seatbelts for vin/cert. Can i use the american ones or do i need NZ ones? Also Accuair E Level assume its all the same for cert as per a normal bag set up just needs lock out while in motion? they can be either- as long as they have a safety standard on them or they are the original GM ones in good condition, they will be ok. E level thing- no operate bags while moving, easiest way to do this is wire it to the inhibitor switch so it only works in park or neutral. you can have it so it works up to 20kph but then it has to automatically go to a preset level once you get to 20kph. i dont know anyone who has done this though, as 95% of the population fiddles with it after cert so it works all the time anyway 1 Quote Link to comment Share on other sites More sharing options...
MRWEST Posted May 5, 2014 Share Posted May 5, 2014 cheers cletus the man with the answers as per usual!! Is there any other things we should know about bags? saw someone posting somewhere that they got pulled up for not p clipping lines every 300mm? Any other painful little things taht should know about before installation? Quote Link to comment Share on other sites More sharing options...
