Beaver Posted December 3, 2013 Share Posted December 3, 2013 not if a get cheap kit from you tho! haha Quote Link to comment Share on other sites More sharing options...
Goat Posted January 16, 2014 Share Posted January 16, 2014 Hie. Your fuel pump. Is it mean? Is it a fuel flow thingy from trademe? Do you use a regulator still? I need to upgrade mine as it sounds like a router. H<3rts Quote Link to comment Share on other sites More sharing options...
Beaver Posted January 16, 2014 Share Posted January 16, 2014 yeh fuelflow one. I got the low pressure yellow capped one http://www.trademe.co.nz/motors/motorbikes/parts-for-sale/performance/auction-686095818.htm not running a reg as it self regulates. works a treat but it makes a fucking racket when the car isnt using much gas and its pumping ontop of its self. the dude said the piston ones are noisy (which I have), the diaphragm ones are much quieter. Ill be going back to factory pump when the a15 goes in (as il be running factory carb on it) so you can give this one a hoon if you want? Probably doesnt have enough balls for you needs though. Quote Link to comment Share on other sites More sharing options...
Rookie Posted January 16, 2014 Share Posted January 16, 2014 I have two of the su spec fuel flow ones in the back of the Jag and they go mean. Quote Link to comment Share on other sites More sharing options...
BobbyBreeze Posted January 16, 2014 Share Posted January 16, 2014 Why back to standard carb Beave?!? Quote Link to comment Share on other sites More sharing options...
Beaver Posted January 16, 2014 Share Posted January 16, 2014 manifolds are different/ive had my fun with bike carbs lol. get pretty annoying when you dont want to doort everywhere Quote Link to comment Share on other sites More sharing options...
Rookie Posted January 16, 2014 Share Posted January 16, 2014 Blasphemy!! 2 Quote Link to comment Share on other sites More sharing options...
Steelies Posted January 17, 2014 Share Posted January 17, 2014 "dont" want to doort everywhere ok, you've lost me now 1 Quote Link to comment Share on other sites More sharing options...
crustywhip Posted January 26, 2014 Share Posted January 26, 2014 Try back the gear box bolts off until the engine can spin freely. Then tighten again slowly while checking that the engine can still spin. Ive had this problem and recently had it again with the engine on the floor. It might be the location of the shaft and the spigot. Quote Link to comment Share on other sites More sharing options...
Beaver Posted January 26, 2014 Share Posted January 26, 2014 hmm interesting, will give it a shot. Il whip the gbox off regardless as its 30 seconds work, the motor and box will have to come out regardless I think I suspect I may have mucked up the release bearing somehow/thats the only thing I can think of that could be put together wrong. Quote Link to comment Share on other sites More sharing options...
AllTorque Posted January 26, 2014 Share Posted January 26, 2014 You haven't got the gearbox in gear have you? Quote Link to comment Share on other sites More sharing options...
Beaver Posted January 26, 2014 Share Posted January 26, 2014 Dont think so...that would make a different though would it? I can turn it over with a socket on the crank, and it feels like its dragging on something for about 3/4 of the turn and then frees up. Its a solid noise so I expect it to be pretty obvious when I pull it apart Quote Link to comment Share on other sites More sharing options...
Beaver Posted January 26, 2014 Share Posted January 26, 2014 /the driveshaft isnt in. Quote Link to comment Share on other sites More sharing options...
shaneo Posted January 27, 2014 Share Posted January 27, 2014 I had a problem like this changed the fly wheel and turned out the ring gear was different so the starter wouldn't work just a thought Quote Link to comment Share on other sites More sharing options...
KKtrips Posted January 27, 2014 Share Posted January 27, 2014 That's a typical escort problem though. Difference between inertia type and pre engaged type. Quote Link to comment Share on other sites More sharing options...
Beaver Posted January 27, 2014 Share Posted January 27, 2014 Got it sorted. Knew it couldn't have been anything major as the flywheel, engine ans gbox are all buddies. Its just me being a Muppet 1 Quote Link to comment Share on other sites More sharing options...
AllTorque Posted January 28, 2014 Share Posted January 28, 2014 Listen to that beast roar. So many horse powers. Quote Link to comment Share on other sites More sharing options...
Beaver Posted January 28, 2014 Share Posted January 28, 2014 something like that....haha Quote Link to comment Share on other sites More sharing options...
coldturkey Posted January 28, 2014 Share Posted January 28, 2014 You're such a cutie... Quote Link to comment Share on other sites More sharing options...
RUNAMUCK Posted February 2, 2014 Share Posted February 2, 2014 Shit beaver-san, From that video, I can see that your engine is from a Van. For one, Vans are fitted with less than awesome cams. (More bottom end) Plus you have the uber ghey inlet manifold. See how the runners aim downhill from the ports? That was done on the later vans to gain more clearance on the underside of the seat. Fuck that manifold off, and fit a different one, and gain free ponies. I might have one spare if you're lucky...... Quote Link to comment Share on other sites More sharing options...
