thegreatestben Posted June 21, 2009 Author Share Posted June 21, 2009 Did some rejiggling of things in the engine bay. Also finished tidying up the battery tray, or lack there of. Probably doesn't look like I've done much but I've removed a lot of criss crossed lines and wires from over the gearbox. Will finish the wiring off with p clips once it's all done. Have a factory toyota ABV as a 'BOV' attached to the back of the intercooler. Way stealth. Will be plumb back. Quote Link to comment Share on other sites More sharing options...
thegreatestben Posted June 24, 2009 Author Share Posted June 24, 2009 slow and steady wins the race: Quote Link to comment Share on other sites More sharing options...
kyteler Posted June 24, 2009 Share Posted June 24, 2009 I woodn't have used that block. BA-DOOM-TISH! Quote Link to comment Share on other sites More sharing options...
CaMpylobacter Posted June 24, 2009 Share Posted June 24, 2009 oh god the comedy. keep up the good progress ben you man stallion. Quote Link to comment Share on other sites More sharing options...
shizzl Posted June 25, 2009 Share Posted June 25, 2009 i like how speedtech had written "rangi welding" Quote Link to comment Share on other sites More sharing options...
thegreatestben Posted June 28, 2009 Author Share Posted June 28, 2009 Everyone lol'd... like ages ago. Anyway. Intercooler piping is done all but connecting turbo to inlet side. Pulled the turbo off, rotated compressor housing. Mounted the wastegate actuator, seems to work which is good. Pictures: Closed : Open: And I think I found a few kilowatts hiding in the exhaust: Quote Link to comment Share on other sites More sharing options...
Hemi Posted June 28, 2009 Share Posted June 28, 2009 Everyone lol'd... like ages ago.Anyway. Intercooler piping is done all but connecting turbo to inlet side. Pulled the turbo off, rotated compressor housing. Mounted the wastegate actuator, seems to work which is good. Pictures: Closed : Open: And I think I found a few kilowatts hiding in the exhaust: ok umm goodness what on earth could that be good for Quote Link to comment Share on other sites More sharing options...
Goat Posted June 28, 2009 Share Posted June 28, 2009 man. I've dropped off the radar for too long. I never knew you had a red one. Lush boi. Also, need to have a luncheon someday this week. Whats you phone number. Cos it has changed hasn't it, Quote Link to comment Share on other sites More sharing options...
Raizer Posted June 28, 2009 Share Posted June 28, 2009 And I think I found a few kilowatts hiding in the exhaust: ok umm goodness what on earth could that be good for WTF why would someone put a restricter plate in it? Quote Link to comment Share on other sites More sharing options...
Brock-Lee Posted June 28, 2009 Share Posted June 28, 2009 stop it from overboosting yo/danger to manifold/group n restritor/couldnt be fucked cutting the gasket properly/help make it quieter Quote Link to comment Share on other sites More sharing options...
Hemi Posted June 28, 2009 Share Posted June 28, 2009 stop it from overboosting yo/danger to manifold/group n restritor/couldnt be fucked cutting the gasket properly/help make it quieter you can never have too much boost /oh yuh true dont want chequer plate falling out of the floor of the car / that a steel sheet sandwhiched between two gaskets Quote Link to comment Share on other sites More sharing options...
tortron Posted June 28, 2009 Share Posted June 28, 2009 Quote Link to comment Share on other sites More sharing options...
thegreatestben Posted June 28, 2009 Author Share Posted June 28, 2009 Reading through the build he mentions putting it in to pass cert. Looks like he didn't bother taking it back out. I thought it was loud before I took it out Quote Link to comment Share on other sites More sharing options...
thegreatestben Posted July 6, 2009 Author Share Posted July 6, 2009 Nice day of slow progress, I've pretty much accepted that to be happy with the cars standard of work, it's gonna take me a lot longer than I thought. Spent today making intercooler brackets and prepping the intercooler to be welded and marked it for pipe alignment. Really happy with how piping and mounts have turned out. (OS reppin') And I had planned to upgrade the rear brakes at somestage down the track but the parts required for the mods I had in mind came up for an absolute steal. I already have larger disks on the front with larger calipers, the stock rear brakes are pretty pathetic really. After doing a bit of reading the best thing I could do was find a set of factory facelift front rotors and a set of SW20 later model rear calipers (22v stamped on them). I managed to pick up a set of rotors for $50 second hand (impossible to buy new for cheap) and I lucked out and found some 22V's for $100 complete with pads and lines. These are hard to find and $100 is cheap! guys in aussie are paying $350 AUD out've japan for them The swap is pretty straight forward, the calipers bolt on and since we're reusing front rotors on the back the stud pattern is the same. Lines also fit straight up. Longer studs are needed, luckily the previous owner intended on doing this swap and had already chucked some longer studs in. The only hard part is the disk needs to be spaced out 6mm from the hub. I read this on toymod forums but checked myself and can confirm 6mm is the correct spacing. I am making my spacers out've high tensile steel since we had a piece of stock the perfect inside diameter of the rotor's hat (130mm) Piccys: Original brakes: Longer studs: New vs. Old: New system: Wheel isn't bolted on, The rotors aren't much larger in diameter but are more than double the thickness. I like how stock it keeps everything looking. I'm gonna give things like the brakes and engine bay a spruce up once I've installed everything. Suggestions on engine bay paint schemes please Quote Link to comment Share on other sites More sharing options...
Simon Posted July 6, 2009 Share Posted July 6, 2009 Can see Jesus in the rear window. Do you know if those 22v calipers are from a turbo car? Quote Link to comment Share on other sites More sharing options...
thegreatestben Posted July 6, 2009 Author Share Posted July 6, 2009 NON TURBO. Weird because apparently they are supposed to be turbo only. I saw an auction for a later model n/a being wrecked and asked if they had 22v on the rear calipers. Yes indeedy. Quote Link to comment Share on other sites More sharing options...
Honda Ass Dragger Posted July 6, 2009 Share Posted July 6, 2009 I love you work man This is going to be so sweet finshed Quote Link to comment Share on other sites More sharing options...
Truenotch Posted July 6, 2009 Share Posted July 6, 2009 Much better Ben, looks like it'll be tidy in the end. Are you running the celica twin pots from the grey car on the front? Quote Link to comment Share on other sites More sharing options...
thegreatestben Posted July 7, 2009 Author Share Posted July 7, 2009 Nah this one already had the ST185 single pots and matching rotors redrilled to 4x100 I'm also going for a 1" master cylinder off've a hilux. $50 new from work and matches up with factory lines, I wonder if a bias valve would be of use as well... Quote Link to comment Share on other sites More sharing options...
Honda Ass Dragger Posted July 7, 2009 Share Posted July 7, 2009 Please remove intake manifold and please have bead blasted back to stanard finsh the red is so ugly Quote Link to comment Share on other sites More sharing options...
