My name is Russell Posted May 21, 2011 Share Posted May 21, 2011 Yup keen on main track Quote Link to comment Share on other sites More sharing options...
Snoozin Posted June 30, 2011 Share Posted June 30, 2011 Sweet! Now it's an actual racecar! Are you bringing this along to the 1vaknd trackday at all? Quote Link to comment Share on other sites More sharing options...
My name is Russell Posted July 1, 2011 Share Posted July 1, 2011 Sweet! Now it's an actual racecar!Are you bringing this along to the 1vaknd trackday at all? I'm not sure, i really would like to but depends how negotiations on a place im trying to buy go this week as it is the same day it would go unconditional if accepted and will need to sort that stuff out. Quote Link to comment Share on other sites More sharing options...
Gaz Posted July 1, 2011 Share Posted July 1, 2011 Your mums unconditional word Gaz Quote Link to comment Share on other sites More sharing options...
KKtrips Posted July 1, 2011 Share Posted July 1, 2011 Congrats Russell.. Where is it? Quote Link to comment Share on other sites More sharing options...
Truenotch Posted July 20, 2011 Share Posted July 20, 2011 Looking good Russell!! how long till it's finished + homologated? Quote Link to comment Share on other sites More sharing options...
My name is Russell Posted July 20, 2011 Share Posted July 20, 2011 Picking up this weekend brother. Unsure how long paper work is taking at moment will go down and see them. Quote Link to comment Share on other sites More sharing options...
Gaz Posted July 20, 2011 Share Posted July 20, 2011 Will this help it do skids? Quote Link to comment Share on other sites More sharing options...
Truenotch Posted July 20, 2011 Share Posted July 20, 2011 K. Come to road And track in august please. Quote Link to comment Share on other sites More sharing options...
KKtrips Posted July 20, 2011 Share Posted July 20, 2011 Awesome digger.. Looks a fuckin comprehensive cage, but its going to be a prick to wind up/down windows. Also why is attaching the cage to the factory seatbelt mounting points - you are using harnesses arn't you? Quote Link to comment Share on other sites More sharing options...
My name is Russell Posted July 20, 2011 Share Posted July 20, 2011 Yup you have to open doors to do windows, but that's ok they will probably end up lexin. The plate is gusseting to add strength to the body. On the pillars the cage is so tight the tube could be welded straight to the pillar. Quote Link to comment Share on other sites More sharing options...
anglia4 Posted July 20, 2011 Share Posted July 20, 2011 That car is so awesome. Good job! Also I think yes you should dry sump Quote Link to comment Share on other sites More sharing options...
EURON8 Posted July 24, 2011 Share Posted July 24, 2011 How on earth do they weld on top of these joins? So sweet though. Quote Link to comment Share on other sites More sharing options...
d.p.n.s Posted July 24, 2011 Author Share Posted July 24, 2011 normaly cut holes in the floor so the tube falls threw . then weld the top of the joint .pull cage back up and welf plate on floor. Quote Link to comment Share on other sites More sharing options...
kyteler Posted July 24, 2011 Share Posted July 24, 2011 You have holes in the floor at the base of the pipe that the cage can lower down through, then once you've got the upper joins welded you raise it back up and put the ends of the pipe onto support plates, buzz them in with some gussets, etc. Edit: Beaten. Quote Link to comment Share on other sites More sharing options...
EURON8 Posted July 24, 2011 Share Posted July 24, 2011 Ahh yes, so obvious. Quote Link to comment Share on other sites More sharing options...
KKtrips Posted August 11, 2011 Share Posted August 11, 2011 Awesome Russell - going to plan for trackday next weekend I hope? Whats left to do? Quote Link to comment Share on other sites More sharing options...
My name is Russell Posted August 11, 2011 Share Posted August 11, 2011 Not sure at this stage brother with another monther. Depends on a fair few things, Only have one free day to work on it and i have a fairly substantial list of things I probably shouldn't rush such as brake lines. also trying to close the deal on a house around this time (just down from Jakes ), find new tenants for an appartment im looking after, working late every week night at work and have a deliverable that day so might not even get the day off, and pajero and trailer are un WOF'd, but im BLOODY keen to come along if i can so im going to go nuts on it on sat and if everything clicks in place ill be there. If i dont make it im definatly of to Manfield on the 27th Aug for that toolshed track day! Slurp Slurp Quote Link to comment Share on other sites More sharing options...
KKtrips Posted August 11, 2011 Share Posted August 11, 2011 I'll be free most of Sunday if you need a tool bitch/someone to mop the sweat off Aidans top lip/generally unhelpful help.. Quote Link to comment Share on other sites More sharing options...
Truenotch Posted August 27, 2011 Share Posted August 27, 2011 Good to finally see the Fe3t touching tarmac! It looks staunch on the track. Some results if you want to traul through: http://www.mylaps.com/results/showevent.jsp?id=705544 PM me if you've got any queries about car setup, lines etc and we'll start working towards some driver training type stuff for next time. Try to make the oil stay in the sump and come back . Quote Link to comment Share on other sites More sharing options...
