low n slows mk1 2door
d.p.n.s
Have since purchased a first home and just finished putting new kitchen in and painting rooms, but all finished for now less the kitchen bench, So we we weeee back on the escort.
Just built a nice solid bench cheers to Hayhole 4 assistance. And vice is bolted in place for 1st time ever so shouldn't drop it and break any more toes!
SEE QUESTION HERE VvVvV
Seeing as the sumps been all chopped up the dip sticks hits a different spot that's shallower now and doesn't measure accurately so i want to re make it all including a welded nut with copper washer + bolt on the end to seal when not using the stick as it leaked last time out when i didn't put it back in properly.
MY QUESTION IS AT WHAT LEVEL SHOULD THE OIL BE AT? I have previously been a bit dodgy and just put 3.5L but struggled to measure and be 100% sure its correct.
18TH DECEMBER MANFIELD ROAD AND TRACK EVENT IS NEXT DAY OUT SO TRYING TO GET HER READY FOR THAT.
  • Replies 1.4k
Hey boe garage looks all good.
Are your wheels rubbing on the inner guaard is that why you have chopped it out? I member having this issue in my escort.
Dipstick should go into the actual sump and prob most of the way down to the bottom. How much oil goes in there is dependant on the crank I think.
Gaz
Plug the hole in the block and weld a bung into your sump and insert the dipstick there - pretty sure some small fords have the dipstick in the sump bowl - definitely is the case with a lot of 70's Holden stuff so worst case you could cut one out of a holden sump and stitch it to the FE sump..
How high the oil level needs to sit in the sump to be a balance between too high and having crank splash and too low to uncover the pickup on corners - I'm not totally sure on but I'll have a google round and see what I can find.
edit - it seems the common theme is that oil level should be just below the windage tray.
If you don't have a windage tray then I would say 5mm below the lowest point that the crank counterbalance rotates.
Once you have figured out where this is in the sump then if you make a sump bowl mounted dipstick hole (as I suggested above) then it should be piece of cake to make a dipstick the correct length with appropriate marks cut in it.
Cheers KK was struggling to find any info and couldn't remember if the crank was supposed to dunk into the oil or not. Just below the windage tray would sound about right for it working, if i had one so will go with '5mm below the lowest point that the crank counterbalance rotates'. I like the idea of making dipstick of the side of the sump also. Cheers brother
Gaz yup got a bit of rub, had already moved it back but going back another inch just to be safe.
d.p.n.s dont have any vids sorry my SLR only does photos, might have to look into getting one of those GOPRO things they seem to take dam good vids!
Ya might want more like 30mm under the crank lowest point but I guess that would depend where it sat the oil in the sump. I would have thought you would fill the actual bowl up but not the flat part?
Dont we have som vids around somewhere from Port Rd? Ill take my camera and take some vids next trackday or borrow one and I can man it hardcone.
Gaz
Thoughts?, struggling to picture what they would look like, same specs as what i have now so will deff fit. Would look ugly with polished dish lip? Mabie just painted black?
http://www.trademe.co.nz/motors/car-par ... 692829.htm
Bloody G1 Links! Couldn't get her started for the life of me last night, hopefully its just super flooded so have opened everything up to let her dry out. Spark is very strong and appears to be fuel pressure and wet plugs just no happy ending.
Inner guards all welded up.
Engine oil leak should be resolved now also :)
Yup got voltage, and seem to have spark now. hmmmm
Was super close to running when i first got home after it airing out with no plugs in all day, So could be just flooding due to humid conditions and crappy G1V5? Starting to get stressful normally starts fine after a bit of cranking and don't want to miss this road track event! 2nd night of just trying to get it to run!, will go over everything again tomorrow with a fresh head. Not as annoying as having your hog pinched at-least! :(
Could to much oil be the cause? put 3.5L in which I'm sure is how much it had previously.
If you flood it should only take approx 30mins or so to clear out, flooding an efi engine wouldn't be as easy as a carb engine. Too much oil also wouldn't stop it starting either.
You havnt put them new cam gears on yet aye?
Did ya hog get pinched?
Gaz
Oh na hog not stolen bro, was referring to marku's FA that's since been found, man there would be tears if i lost another hog.
Just got her running all thanks to Jason Sutherland!
She was supper flooded.
Plugged link into laptop to check tune hadn't been lost and was all ok. Have since saved the file.
Then changed the cold crank settings to reduce flooding. (Settings > Fuel Menu's > Auxiliary > Cold crank > set to 20 > store(the "S" up top of screen)) for future reference.
Then cleaned the plugs with brake clean and dried them out with a heat gun which worked extremely well it started first pop!
Turns out just cleaning spark plugs with wire when you have wet plugs doesn't do allot, nor does un plugging pump relay and cranking engine over.
Cheers again Jason! Track day progress is back on!
