Gaz Posted March 30, 2012 Share Posted March 30, 2012 What gear you pop it going into or just top end?? Gaz Quote Link to comment Share on other sites More sharing options...
My name is Russell Posted March 30, 2012 Share Posted March 30, 2012 5th was the first to go then the rest stopped playing ball fairly quickly. . . Least it didn't happen at Taupo in-front of OS boes, that would have been shame. Which was the point in today to test, just hope i can turn it around in time, is probably the trickiest thing to fix that could have broken. Dow Quote Link to comment Share on other sites More sharing options...
Gaz Posted March 31, 2012 Share Posted March 31, 2012 Whats the 5puk clutch plate on the floor next to the new box, old clutch or new? Gaz Quote Link to comment Share on other sites More sharing options...
My name is Russell Posted April 1, 2012 Share Posted April 1, 2012 old Quote Link to comment Share on other sites More sharing options...
Dell'orto Posted April 1, 2012 Share Posted April 1, 2012 Cool car, first time I've read your build thread! What box did you have in behind it? Quote Link to comment Share on other sites More sharing options...
Gaz Posted April 2, 2012 Share Posted April 2, 2012 His mums nasty 5 speed, it was pretty flogged out but now its smashed to bits. Quote Link to comment Share on other sites More sharing options...
Truenotch Posted April 2, 2012 Share Posted April 2, 2012 He smashed his mother's flogged box to bits? Quote Link to comment Share on other sites More sharing options...
Gaz Posted April 2, 2012 Share Posted April 2, 2012 I think it may have been Aiden, not sure who went first tbh Gaz Quote Link to comment Share on other sites More sharing options...
My name is Russell Posted April 2, 2012 Share Posted April 2, 2012 I think it may have been Aiden, not sure who went first tbhGaz Whats this dribble coming of your chin Quote Link to comment Share on other sites More sharing options...
My name is Russell Posted April 2, 2012 Share Posted April 2, 2012 His mums nasty 5 speed, it was pretty flogged out but now its smashed to bits. Wasn't that bad, sounds like it will shift better than the new one , just always knew it was a bit of a weak point and when the car was running on tune (i.e. not 50/50 oil mix from turbo seal) it just stripped it in 1 1/2 warm up lap Car felt significanlt quicker so taking good with the bad. Quote Link to comment Share on other sites More sharing options...
My name is Russell Posted April 5, 2012 Share Posted April 5, 2012 Oh man its going to be a battle getting this thing ready for nats, lots of custon machining required and most shops closed for four days, will go nuts this weekend and see how we get on. Quote Link to comment Share on other sites More sharing options...
Truenotch Posted April 5, 2012 Share Posted April 5, 2012 Welcome to the rat race. Fuck you long weekend! Quote Link to comment Share on other sites More sharing options...
My name is Russell Posted April 5, 2012 Share Posted April 5, 2012 Who sells bearings that could be open in the weekend? Roller type not engine type Quote Link to comment Share on other sites More sharing options...
KKtrips Posted April 5, 2012 Share Posted April 5, 2012 For your spigot?? Make a bronze bush man.. seriously so much easier for your situation.. Quote Link to comment Share on other sites More sharing options...
Truenotch Posted April 5, 2012 Share Posted April 5, 2012 UJ to the rescue? Quote Link to comment Share on other sites More sharing options...
My name is Russell Posted April 5, 2012 Share Posted April 5, 2012 KK I'm hoping we should be able to slap one on the Flywheel which will make it happy as for length so long as can find a Bearing the correct size / get flywheel centre machined appropriatly. Quote Link to comment Share on other sites More sharing options...
KKtrips Posted April 5, 2012 Share Posted April 5, 2012 Sweet as - as I said to Aidan - as long as you have the spline fully engaged then you can most probably get away without a spigot bearing as they are not essential IMO. Quote Link to comment Share on other sites More sharing options...
My name is Russell Posted April 5, 2012 Share Posted April 5, 2012 Yeah true like yourself or Aiden said FWD cars dont have them, so i gues they are just there for the vibrations of the driveshaft? but then when the clutch is out it wouldnt do anything anyway? man im confused now! Got cluch back from having centre changed today so thats a good start. Then its; New Driveshaft, exhast system re done around new bell, bearing, new crossmember made, box tunnel modified, fluids, clutch release sleave, and put engine + box bay back together. Yay Quote Link to comment Share on other sites More sharing options...
KKtrips Posted April 5, 2012 Share Posted April 5, 2012 I ain't a gearbox expert sorry but yeah FWD don't have them - if its going to be the only thing stopping you from going to Nats then just slam it in without a spigot bush/bearing. If you have time then get a longer bronze bush made up to support the spigot. Quote Link to comment Share on other sites More sharing options...
Gaz Posted April 6, 2012 Share Posted April 6, 2012 gbox xmember looks mint, is the gbox to gbox mount standard? For driveshaft you prob want to find someone who can make + balance in the same shop.. Howat Engineering where I got the one your currently using done had to send it away to get it balenced and thats what took a bit of extra time. I am using Aztec Engineering a bit for work, I can see if they do this kind of stuff if you like? Gaz Quote Link to comment Share on other sites More sharing options...
