low n slows mk1 2door
d.p.n.s
  • Replies 1.4k
KKChris Dan said your front end was metalic flatt. It looked really nice n matt in the workshop, does it get a bit of a shine on when its out in daylight? Do you know how much flttening was added?
Oh shit son - just read this now..
bit late it would seem
looks bloody good mate, you must be proud.. are those stripes stickers or painted on?
Cheers SmithE, Painted on to get the same matt finnish as body. Masking up the hole car was quite a big job turns out!
Also got the perspex windows cut :)
The rear sits real nice and lush low. Hows the front with the engine in?
Gaz
way way way lower, the springs are not even in place in that shot.
Just painted and fitted lex windows and half the body parts and looks way way better. Didn't realise how much stuff i had for her to be assembled! Cant wait to get some time to work on her properly evenings go to quickly.
Have just stolen this of CDL's project and pasting them in here for my own referance so i dont forget to look at doing this to mine! ... (this is exactly why im hoping the matt paint job will be good)
So yip,
have decided that i will infact be side piping
SO much so that I have cut a fucken big hole in my sill haha
So heres some sweet sweet pics
(read shit pics)
So, firstly, i cut a hole in the inner sill, to where i want it to enter. you can also see the sweet prevouisly cut chassis mod
Next was to remove the outer sill, and after having a good look reasling there is also a center member in there to, which i had to drill out the spot welds on the out side to realise.
Then deciding what how much of the sill to cut out and marking it up
then bam, a hole and what the center member looks like, So that gout cut out too for now
Then started mocking up the 3 inch as to where it needs to go. I have a lot of work a head of me and fuck all time.
Also have ordered my r32 radatior, which is going to be so fucekn good for cooling
Almost insanly good, So will pick that up on tuesday most likely
Takign pictures and holding stuff at the same time doesnt really give a good indication as to how it will look, but all in very short good time
CDL
ok so took most of the day off to get this pretty much sorted besides a final weld around the pipe and sill and then deciding weather to flush mount or not
At the moment thi is how it is
Fistly a how much or the sill i had to move to get decent welds going on on inner sill
Then re welded on the back of the inner sill
And how far the exhuast is which cant be removed from vehicle
And the start or rewelding up the outer sill
And how it pretty much looks now, which is terrible with all the exposed welding haha
the bits used to coonect up to new section from old via a flange
And how it looks on the ground,
im kind of half half on which way to have it, flush mount would be so sweet, but i like this look too
Anyways
Love
Allan
