My name is Russell Posted July 8, 2010 Share Posted July 8, 2010 if seats are on runners then they must be double locking, i dout mk2 escort ones are.once cage is been put through the homoglation process no changes are allowed. unless you get it re-homoglated ah i see so each rail needs to have locking fingers as bellow on both sides. Quote Link to comment Share on other sites More sharing options...
Truenotch Posted July 16, 2010 Share Posted July 16, 2010 ^^ Yip that's the one. And to further the cage modifications question - if you modify the cage you need to get a "homologation extension" which costs about $50 as far as I remember. Quote Link to comment Share on other sites More sharing options...
My name is Russell Posted July 16, 2010 Share Posted July 16, 2010 Good to know cool cheers mate. will have a look tonight Quote Link to comment Share on other sites More sharing options...
My name is Russell Posted July 19, 2010 Share Posted July 19, 2010 Anyone know how to wire in a knock sensor to a V1 G5 LINK computer? Aparintly this sender circled on the left is a knock sensor and i just found an old quote from the guy who built the engine and tuned the computer that said "it was knock limited at 11psi so no more power would be achieved." What will happen if i run the engine without one? It seems from the manual the computer can't run one? if this is the case do i need to make a seperate circuit for one? Quote Link to comment Share on other sites More sharing options...
Truenotch Posted July 19, 2010 Share Posted July 19, 2010 They may have been monitoring the knock with a set of headphones. Quote Link to comment Share on other sites More sharing options...
Gaz Posted July 19, 2010 Share Posted July 19, 2010 Knock limited? WTF is that? I guess they have just given it a safe tune at 11psi. I assume he is saying that anymore timing/boost and she starts to knock, how bad it knocks is another story. Run the knock sensor and hook it to a light on the dash if you can. Gaz Quote Link to comment Share on other sites More sharing options...
QCADTA Posted July 19, 2010 Share Posted July 19, 2010 yeah thats a bit randomn. run a screened coax from the knock sensor back to the ecu. and if you dont decide to run one your ecu may slip into limp mode? if it has one? or you will have to find an appropriate sized resistor to bypass it maybe, not to sure how links work. Quote Link to comment Share on other sites More sharing options...
eke_zetec_RWD Posted July 19, 2010 Share Posted July 19, 2010 v5lem wont run a knock senser. you need a knock block from link. but you dont really need one anyway. if its tuned properly on a dyno to a safe level and not set on auto tune then it will be sweet as Quote Link to comment Share on other sites More sharing options...
thegreatestben Posted July 19, 2010 Share Posted July 19, 2010 Yeah, no knock sensor on my car man. If it doesn't knock when it's being tuned, why would it knock afterward? Quote Link to comment Share on other sites More sharing options...
Truenotch Posted July 19, 2010 Share Posted July 19, 2010 ... good question... Quote Link to comment Share on other sites More sharing options...
Brock-Lee Posted July 19, 2010 Share Posted July 19, 2010 carbon build up in the head causing hotspots? Quote Link to comment Share on other sites More sharing options...
thegreatestben Posted July 19, 2010 Share Posted July 19, 2010 If it was tuned why would it do that too. Quote Link to comment Share on other sites More sharing options...
Gaz Posted July 19, 2010 Share Posted July 19, 2010 Change it atmospheric conditions Quote Link to comment Share on other sites More sharing options...
thegreatestben Posted July 19, 2010 Share Posted July 19, 2010 the ice age? Quote Link to comment Share on other sites More sharing options...
eke_zetec_RWD Posted July 19, 2010 Share Posted July 19, 2010 a safe tune will be fine with that ecu. other wise buy a g4 and get the extra 3 hp and knock trim and a baro senser and inlet temp retard and engine temp boost trim ect. Quote Link to comment Share on other sites More sharing options...
My name is Russell Posted July 19, 2010 Share Posted July 19, 2010 v5lem wont run a knock senser. you need a knock block from link. but you dont really need one anyway.if its tuned properly on a dyno to a safe level and not set on auto tune then it will be sweet as Cheers for all the above replies guys sums up and answers my uncertanties , confirms for me V5 doesnt have knock so will get it onto a dyno once i have all the glitches out of the way which hopefully should be to far off. Whats thoughs on them aftermarket Fuel regulators? what fuel pressure should I have? Got the plenum of at the moment so trying to decide if i should have one as now would be a good time to get an outlet nob thing welded on to run vacum line to it. Or is it just one more thing to go wrong having / not having one? Quote Link to comment Share on other sites More sharing options...
QCADTA Posted July 20, 2010 Share Posted July 20, 2010 so you dont have one now? should be one on ya fuel rail so remove that put an external on and use its vacuum line. Quote Link to comment Share on other sites More sharing options...
eke_zetec_RWD Posted July 20, 2010 Share Posted July 20, 2010 v5lem wont run a knock senser. you need a knock block from link. but you dont really need one anyway.if its tuned properly on a dyno to a safe level and not set on auto tune then it will be sweet as Cheers for all the above replies guys sums up and answers my uncertanties , confirms for me V5 doesnt have knock so will get it onto a dyno once i have all the glitches out of the way which hopefully should be to far off. Whats thoughs on them aftermarket Fuel regulators? what fuel pressure should I have? Got the plenum of at the moment so trying to decide if i should have one as now would be a good time to get an outlet nob thing welded on to run vacum line to it. Or is it just one more thing to go wrong having / not having one? you got standard one atm? from a turbo motor? should be ok unless you have a biger fuel pump. dont get a cheap/chineese regulator. i learnt that the hard way. was ok up to 250hp then just does weird shit. buy a good one. cheap compaired to a new motor. Quote Link to comment Share on other sites More sharing options...
My name is Russell Posted July 20, 2010 Share Posted July 20, 2010 v5lem wont run a knock senser. you need a knock block from link. but you dont really need one anyway.if its tuned properly on a dyno to a safe level and not set on auto tune then it will be sweet as Cheers for all the above replies guys sums up and answers my uncertanties , confirms for me V5 doesnt have knock so will get it onto a dyno once i have all the glitches out of the way which hopefully should be to far off. Whats thoughs on them aftermarket Fuel regulators? what fuel pressure should I have? Got the plenum of at the moment so trying to decide if i should have one as now would be a good time to get an outlet nob thing welded on to run vacum line to it. Or is it just one more thing to go wrong having / not having one? you got standard one atm? from a turbo motor? should be ok unless you have a biger fuel pump. dont get a cheap/chineese regulator. i learnt that the hard way. was ok up to 250hp then just does weird shit. buy a good one. cheap compaired to a new motor. CRAP! I had an autobid on this thing that I apear to have won, i presume its a rubbish one? So going to just re list it and get a Tomei Fuel Pressure Regulator. Once i get it what pressure should i set it to? i presume the tuner will adjust it for me. Quote Link to comment Share on other sites More sharing options...
My name is Russell Posted July 21, 2010 Share Posted July 21, 2010 Found these that look quite neat for fitting fuel gauges in line £10.85 (exc.Vat) FUEL PRESSURE GAUGE ADAPTOR WITH PLUG https://www.burtonpower.com/product_mai ... 16&PSet=19 Quote Link to comment Share on other sites More sharing options...
