My name is Russell Posted June 8, 2010 Share Posted June 8, 2010 iv got the second one in my escort. is double pass, 3 core, cross flow. all good features. both inlet and exit on drivers side tanks.also core is exacty the same width as a 450x300 intercooler. i presume thats the size you are running? although i still need a very very good electric fan to cope in city traffic. Got one of these ones http://www.trademe.co.nz/Trade-Me-Motor ... 089854.htm Is cross flow radiator when the inlet and outlet are on the same side? / whats better as i'm tossing up if to get botton outlet changed to pass side or just running a pipe along the front as will have a tad more space now. Na iv got some retarded custom size IC thats 470 x 360 x 60 and had to chop allot out to get it in Quote Link to comment Share on other sites More sharing options...
eke_zetec_RWD Posted June 8, 2010 Share Posted June 8, 2010 nah cross flow is when the tanks are on the sides not the top. double pass is when its crossflow and the tank with the outlets has a divider plate in the center forcing the water to cross the radiator then drop and cross it again to the outet. moving the inlet for your radiator will be easy, take to a sheet metal place. Quote Link to comment Share on other sites More sharing options...
KKtrips Posted June 8, 2010 Share Posted June 8, 2010 nah cross flow is when the tanks are on the sides not the top. double pass is when its crossflow and the tank with the outlets has a divider plate in the center forcing the water to cross the radiator then drop and cross it again to the outet.moving the inlet for your radiator will be easy, take to a sheet metal place. take to Mark at Abel Smith Radiators - they can move the inlet easy as buddy - did Manu's radiator for a good price IIRC Quote Link to comment Share on other sites More sharing options...
My name is Russell Posted June 8, 2010 Share Posted June 8, 2010 back on the injector hunt again, this is whats in there now which has been dynod at 212KW what i dont understand is how? all my research seems to point towards them being far to small? or does the 2.0 ohms have something to do with it? making it what will it do to the computer if i go slap some 4-500cc ones in? just going to do some trademe surfing now Part Number lbs/hr cc/min grams /min PSI BARS lbs/hr cc/min 80% 95% Feed Impedance Application 195500-2610 22.45 235.9 169.7 43.5 3.0 22.45 235.9 34.5 41 Top Low Quote Link to comment Share on other sites More sharing options...
My name is Russell Posted June 8, 2010 Share Posted June 8, 2010 nah cross flow is when the tanks are on the sides not the top. double pass is when its crossflow and the tank with the outlets has a divider plate in the center forcing the water to cross the radiator then drop and cross it again to the outet.moving the inlet for your radiator will be easy, take to a sheet metal place. take to Mark at Abel Smith Radiators - they can move the inlet easy as buddy - did Manu's radiator for a good price IIRC cheers bro was going to just drop of at johhny mines as got a fair bit of alloy for him to weld now and he is just a block away and a GC. supporting local industry is good cept when you buy expired beers from the local dairy on a friday night Quote Link to comment Share on other sites More sharing options...
eke_zetec_RWD Posted June 8, 2010 Share Posted June 8, 2010 236cc!! no way you will get 212kw out of them. you sure thats waht you have? 550cc ones from a s5 rx7 turbo will be a good swap Quote Link to comment Share on other sites More sharing options...
My name is Russell Posted June 8, 2010 Share Posted June 8, 2010 mean looks like the core for the new radiator (270x533x52mm) will fit two 10" fans perfectly Quote Link to comment Share on other sites More sharing options...
My name is Russell Posted June 8, 2010 Share Posted June 8, 2010 236cc!! no way you will get 212kw out of them. you sure thats waht you have?550cc ones from a s5 rx7 turbo will be a good swap yeah doesn't seem right according to my googling its correct. he might have done the dirty and swaped them on me. Quote Link to comment Share on other sites More sharing options...
Gaz Posted June 8, 2010 Share Posted June 8, 2010 Lol just sent you an email but everything was basically said in here bout radiators. Injectors.. If you put larger ones in at the mo then it will surge on idle and use lots of gas, poss wash the bores if done for long enough. Also you will obviously need a retune which is a good idea anyways since youve got diff dump pipe, turbo, cooler, intake, exhaust etc etc to when it was tuned last. Umm that is all. Gaz Quote Link to comment Share on other sites More sharing options...
My name is Russell Posted June 8, 2010 Share Posted June 8, 2010 You reckon these will work? http://www.trademe.co.nz/Browse/Listing ... =294269383 the bottoms of them seem to be a little shorter than mine? have not checked that they are low Impedance yet. Quote Link to comment Share on other sites More sharing options...
Gaz Posted June 8, 2010 Share Posted June 8, 2010 Id prob go for some that have been flow tested on TM. Will cost ya an extra $50 or so but at least ya know they not fucked.. Plus it would pay to spend the $50 for a flow test anyways so as to know one aint going to fuck out on dyno. Maybe 550cc too incase you decide to change turbo a lil later down the track and need a little more juice. I beleieve resistance can be changed by addidng resitors. http://www.trademe.co.nz/Trade-Me-Motor ... 748861.htm http://www.trademe.co.nz/Trade-Me-Motor ... 521478.htm Gaz Quote Link to comment Share on other sites More sharing options...
eke_zetec_RWD Posted June 8, 2010 Share Posted June 8, 2010 You reckon these will work?http://www.trademe.co.nz/Browse/Listing ... =294269383 the bottoms of them seem to be a little shorter than mine? have not checked that they are low Impedance yet. you got a link a? dnt need low resistance injectors. just remove the resisters you should already have in your loom. Quote Link to comment Share on other sites More sharing options...
My name is Russell Posted June 8, 2010 Share Posted June 8, 2010 Id prob go for some that have been flow tested on TM. Will cost ya an extra $50 or so but at least ya know they not fucked.. Plus it would pay to spend the $50 for a flow test anyways so as to know one aint going to fuck out on dyno.Maybe 550cc too incase you decide to change turbo a lil later down the track and need a little more juice. I beleieve resistance can be changed by addidng resitors. http://www.trademe.co.nz/Trade-Me-Motor ... 748861.htm http://www.trademe.co.nz/Trade-Me-Motor ... 521478.htm Gaz you recon the evo ones can work? i would of thought they are standardized but they look a little different to what i have now (the bottom looks shorter). what ever i buy even if tested i will probably get re coned after the shit i just went through buying two fucked coil paks dont trust "mint working condition" stuff anymore. Quote Link to comment Share on other sites More sharing options...
Gaz Posted June 8, 2010 Share Posted June 8, 2010 I will drop you off a 550cc evo one tommorow for a look/test if you want? Infact I can drop of 4? Meet you at lunch? Umm, find out what recoing 4x costs before buying on TM. Can get a new set of Denso ones for pretty cheap via TM. Gaz Quote Link to comment Share on other sites More sharing options...
thegreatestben Posted June 8, 2010 Share Posted June 8, 2010 Should've bought my RX7 injectors. I only wanted 200 for the set of four Gone now. If you want timing belt, idler, tensioner and water pump come see me. You've got my cellphone number eh? Even if you just want a price giz a txt to remind me. Quote Link to comment Share on other sites More sharing options...
My name is Russell Posted June 8, 2010 Share Posted June 8, 2010 You reckon these will work?http://www.trademe.co.nz/Browse/Listing ... =294269383 the bottoms of them seem to be a little shorter than mine? have not checked that they are low Impedance yet. you got a link a? dnt need low resistance injectors. just remove the resisters you should already have in your loom. yup got link, oh ok so you can just slap 12V down them? yup i put resistor in 12v feed. Quote Link to comment Share on other sites More sharing options...
My name is Russell Posted June 8, 2010 Share Posted June 8, 2010 Should've bought my RX7 injectors.I only wanted 200 for the set of four Gone now. If you want timing belt, idler, tensioner and water pump come see me. You've got my cellphone number eh? Even if you just want a price giz a txt to remind me. dam should of remembered that just paid stupid amount for a water pump on sunday Quote Link to comment Share on other sites More sharing options...
My name is Russell Posted June 8, 2010 Share Posted June 8, 2010 I will drop you off a 550cc evo one tommorow for a look/test if you want? Infact I can drop of 4? Meet you at lunch?Umm, find out what recoing 4x costs before buying on TM. Can get a new set of Denso ones for pretty cheap via TM. Gaz got a fair bit of stuff to sort before i start her up again (re PM radiator has a 12month warranty ) Quote Link to comment Share on other sites More sharing options...
My name is Russell Posted June 8, 2010 Share Posted June 8, 2010 http://www.amazd.co.nz/forum/viewtopic. ... ht=#211607 Quote Link to comment Share on other sites More sharing options...
lowlancer Posted June 12, 2010 Share Posted June 12, 2010 http://www.mx6.com/forums/1g-faq-engine ... rence.html Sounds like they aren't? Quote Link to comment Share on other sites More sharing options...
