d.p.n.s Posted June 12, 2010 Author Share Posted June 12, 2010 thats sucks man!! hope its all well Quote Link to comment Share on other sites More sharing options...
QCADTA Posted June 12, 2010 Share Posted June 12, 2010 that would be my worst nightmare bad luck mate, time to whip the head off for a look i guess. any reason why it did it? Quote Link to comment Share on other sites More sharing options...
My name is Russell Posted June 12, 2010 Share Posted June 12, 2010 i didn't put the front alternator pully on was alternator not wired up and turns out that the shim between them stops the cam sliding off Quote Link to comment Share on other sites More sharing options...
Brock-Lee Posted June 12, 2010 Share Posted June 12, 2010 google says non interference Quote Link to comment Share on other sites More sharing options...
My name is Russell Posted June 12, 2010 Share Posted June 12, 2010 yeah massive relief just going to do some tests now to clarify just in-case it has non standard pistons as its a re built engine. and a little worried about the noise i heard No idea how to get this belt back lined up eeek and gaz seems to think it may be difficult due to non standard cams. i really have no idea time to learn i guess Quote Link to comment Share on other sites More sharing options...
Gaz Posted June 12, 2010 Share Posted June 12, 2010 Need to find out what cam last owner put in and what it was set to. Gaz Quote Link to comment Share on other sites More sharing options...
QCADTA Posted June 12, 2010 Share Posted June 12, 2010 all good. being turbo'd it wont have high top pistons then. check on the cam belt to see if there is three marks, two that line up with indents on the cams and one for the crank possibly? nissans like that but not sure on mazdas. Quote Link to comment Share on other sites More sharing options...
eke_zetec_RWD Posted June 12, 2010 Share Posted June 12, 2010 put it back together using the factory timing marks. the front cam lobes will be pointing up and outwards on about a 45deg angle. then wind over slowly by hand. with no plugs. should be smooth without and hard spots. if this is the case do a compression test. be sure to have the crank about 45deg btdc when you position the cams to insure no contact. then finally turn to tdc and put belt on. good luck Quote Link to comment Share on other sites More sharing options...
Testament Posted June 13, 2010 Share Posted June 13, 2010 leakdown test is the other thing you can do to check nothing is bent and all is well. Quote Link to comment Share on other sites More sharing options...
eke_zetec_RWD Posted June 13, 2010 Share Posted June 13, 2010 you must have a mechanic mate to help with this part? Quote Link to comment Share on other sites More sharing options...
My name is Russell Posted June 13, 2010 Share Posted June 13, 2010 Yeah think I'm going to have to get a mechanic to fix this fuck up way over my head. anyone for a cash'e in wellington? fairly confident iv gotten away with no damage to anything, however old Muppet features could be wrong again. Quote Link to comment Share on other sites More sharing options...
Gaz Posted June 13, 2010 Share Posted June 13, 2010 Hit up Mongol. Gaz Quote Link to comment Share on other sites More sharing options...
Hemi Posted June 13, 2010 Share Posted June 13, 2010 cam timing is piss easy i should know ive done it a bazllions times on the ca lol , they are standard cams though aye? , havent played around with dialing cams in . Quote Link to comment Share on other sites More sharing options...
Gaz Posted June 13, 2010 Share Posted June 13, 2010 They are not standard but out of another engine I believe. Much like the de exhaust you have used. Gaz Quote Link to comment Share on other sites More sharing options...
Hemi Posted June 13, 2010 Share Posted June 13, 2010 if i have the info on hand easy , so they still use same cam gears and dowels? . Quote Link to comment Share on other sites More sharing options...
My name is Russell Posted June 13, 2010 Share Posted June 13, 2010 ITS GOT TWIN FE5 CAMS INSTEAD OF FE3 INLET FE4 EXHAUST OR SOMETHING ALONG THOSE LINES. STANDARD BUT HARD TO FIND CAMS APPARENTLY. DIFFERENT DURATION OF SOME SORT. Ok i just had a go at putting the belt back on using original markings from prior to the 1st time i removed it. THESE ARE THE MARKINGS PRIOR TO REMOVING IT FOR THE FIRST TIME AND THESE ARE THE MARKINGS AS ITS ON NOW. Just chopped my new radiator in several directions for Johnny Mines to weld up, should be mint! shame he is on holiday for a week Quote Link to comment Share on other sites More sharing options...
Hemi Posted June 13, 2010 Share Posted June 13, 2010 lol there you go then , turn it over by hand a couple times just in case , didnt realise it had been marked . Quote Link to comment Share on other sites More sharing options...
My name is Russell Posted June 13, 2010 Share Posted June 13, 2010 lol there you go then , turn it over by hand a couple times just in case , didnt realise it had been marked . yeah neither! I thought all the markings had rubbed off! was to worried about bent valves to look properly , turns over fine, feeeeeew. Cheers boes Quote Link to comment Share on other sites More sharing options...
Gaz Posted June 13, 2010 Share Posted June 13, 2010 You havnt turned the crank at diff times to the cams have you.? Couldn't ya still have those marks line up but it be out 180deg say? Gaz Quote Link to comment Share on other sites More sharing options...
Hemi Posted June 13, 2010 Share Posted June 13, 2010 they move at 1/2 engine speed , so not really . Quote Link to comment Share on other sites More sharing options...
