cletus Posted November 2, 2021 Posted November 2, 2021 Yeah I think that would be OK to modify or remove , add some sort of strength back into the join another way Quote
Bearded Baldy Posted November 2, 2021 Posted November 2, 2021 1978 falcon. Never had rear seatbelts. If i was to cert for efi upgrade on the 6 cylinder, later diff with discs, aside from brake test and driveshaft hoop is there anything going to trip me up? Will i need to fit rear belts? Reg on hold not lapsed. Quote
igor Posted November 2, 2021 Posted November 2, 2021 Might have factory holes for seatbelts already in it. My '78 coon did. Quote
cletus Posted November 2, 2021 Posted November 2, 2021 79 is when rear belts became a requirement, so technically, you won't need them. Good idea to fit them though, if the holes are there already. 1 Quote
zep Posted November 2, 2021 Posted November 2, 2021 3 hours ago, cletus said: Yeah I think that would be OK to modify or remove , add some sort of strength back into the join another way Awesome, thanks Quote
Bearded Baldy Posted November 3, 2021 Posted November 3, 2021 21 hours ago, cletus said: 79 is when rear belts became a requirement, so technically, you won't need them. Good idea to fit them though, if the holes are there already. Haven't looked for mounting points yet. Need another storage shed before i take the rest of it apart. Can't rush these jobs. Cheers for the info. 1 Quote
Crispy Posted November 13, 2021 Posted November 13, 2021 Potentially looking to get rid of the yuck taillights on my Mk6 Mini and replace them with far cleaner looking Mk2 items that bolt straight in (so I'm led to believe). Only problem is they don't have provisions for reverse lights. Everywhere I've read says reverse lights need to work if fitted, but not an issue if they aren't fitted. Can someone confirm this. My WOF guy is pretty chill, but I don't want to test things too much. Quote
SOHC Posted November 14, 2021 Posted November 14, 2021 Frend took his car in for a cert for brakes and gearbox swap and the cert guy wants him to put Dynamat on the floor, is that normal? 2 1 Quote
AllTorque Posted November 14, 2021 Posted November 14, 2021 On 13/11/2021 at 21:55, Crispy said: Everywhere I've read says reverse lights need to work if fitted, but not an issue if they aren't fitted Correct. Reverse lights are a permitted lamp. So you don’t need them. Quote
cletus Posted November 14, 2021 Posted November 14, 2021 19 minutes ago, SOHC said: Frend took his car in for a cert for brakes and gearbox swap and the cert guy wants him to put Dynamat on the floor, is that normal? Not really, but there might be a reason, like the floor or tunnel gets really hot Quote
Adoom Posted November 14, 2021 Posted November 14, 2021 50 minutes ago, AllTorque said: Correct. Reverse lights are a permitted lamp. So you don’t need them. Just try reversing your 1973 mini estate with no reversing lights down an unlit winding driveway after delivering pizza to the address at night time. Is that bit of dark darker than the other dark? Yes, it's a post and you have just run into it. #oddlyspecific 3 4 Quote
Crispy Posted November 15, 2021 Posted November 15, 2021 5 hours ago, Adoom said: Just try reversing your 1973 mini estate with no reversing lights down an unlit winding driveway after delivering pizza to the address at night time. Is that bit of dark darker than the other dark? Yes, it's a post and you have just run into it. #oddlyspecific There is a rear fog/park light which I may wire up into a reverse light just in case any poles sneak up on me 1 Quote
igor Posted November 15, 2021 Posted November 15, 2021 Just put one of the indicators on when backing in the dark. Always worked for me on my Wolseley 1300. Quote
dmulally Posted November 16, 2021 Posted November 16, 2021 I have had my chev V8 rebuilt and it smokes a little on startup. Stinks of burnt oil and is blueish. A quick rev and it goes away so my guess is that one of the rings might be shot seeing as I had all new valve stem seals put in. Haven't compression tested it yet however. Does anybody know what is needed for a wof in regards to smoke? I have just moved to a new area so haven't figured out who are the better ones with old cars yet. Quote
AllTorque Posted November 16, 2021 Posted November 16, 2021 1 hour ago, dmulally said: Does anybody know what is needed for a wof in regards to smoke? https://vehicleinspection.nzta.govt.nz/virms/in-service-wof-and-cof/tb-general/guidance-clearly-visible-smoke If there is no smoke once it warms up when you give it a rev, it will pass. 1 Quote
dmulally Posted November 16, 2021 Posted November 16, 2021 14 hours ago, AllTorque said: https://vehicleinspection.nzta.govt.nz/virms/in-service-wof-and-cof/tb-general/guidance-clearly-visible-smoke If there is no smoke once it warms up when you give it a rev, it will pass. Ta. It's always a bit nervy going to a new wof place after leaving an area where the wof guy was really helpful. Pity it is a 3 hour journey back or I'd go back there. If anybody knows an old car WOF specialist in the South Wairarapa please shoot me a message. Quote
tortron Posted November 18, 2021 Posted November 18, 2021 On 23/08/2021 at 19:56, tortron said: If turners is selling a vehicle as dereg, but ltsa shows it as still live, do they dereg it before handing it over? or is it just a mistake on their data entry Owned 2 bikes in my name for 3 months, they dereged one the day before I picked up, the 2nd they took the plate but didn't dereg The system works 1 Quote
SOHC Posted November 18, 2021 Posted November 18, 2021 On 16/11/2021 at 15:23, dmulally said: I have had my chev V8 rebuilt and it smokes a little on startup. Stinks of burnt oil and is blueish. A quick rev and it goes away so my guess is that one of the rings might be shot seeing as I had all new valve stem seals put in. Haven't compression tested it yet however. Does anybody know what is needed for a wof in regards to smoke? I have just moved to a new area so haven't figured out who are the better ones with old cars yet. Take it back to the shop who did the rebuild Quote
dmulally Posted November 18, 2021 Posted November 18, 2021 13 hours ago, SOHC said: Take it back to the shop who did the rebuild Nah. It's only a little smoke and isn't using any oil noticeably. After years of it being a project I'm happy for it to just work. When it finally throws a leg out of bed it'll be a good excuse to put in a diesel truck engine like I've always wanted to do. I'm just sick of it being a project. Plus whilst I'm building a cabin it it better than a box trailer. 5 1 Quote
