RUNAMUCK Posted August 18, 2014 Share Posted August 18, 2014 Fuck! The old boy has a fury which has had some rust work done, and is now in a meke as fuck paint. The car was blasted first too. I would resort to bribery to avoid removing new paint. bribery, and/or death threats......... Quote Link to comment Share on other sites More sharing options...
keltik Posted August 18, 2014 Share Posted August 18, 2014 i have looked at a few of them (probably 6 or 7 over the last 8 years) and priced it up, all but 1 ended up removing the rear seats and belts, it gets quite expensive to do. Wait.....thats a thing!? Will be very happy if yes. Quote Link to comment Share on other sites More sharing options...
dave Posted August 19, 2014 Share Posted August 19, 2014 my diff/driveshaft area is hard on my tunnel can i take to it with a hammer to gain clearance or is it a no no, or should i be legit and get the floor raised up a bit over this area Quote Link to comment Share on other sites More sharing options...
Nominal Posted August 19, 2014 Share Posted August 19, 2014 Wait.....thats a thing!? Will be very happy if yes. Sure, I think it might have been discussed up-thread.. From LVVTA site: Can I remove my rear seats from my vehicle? Yes, however to pass a WoF the seatbelts will also need to be removed from the vehicle Quote Link to comment Share on other sites More sharing options...
cletus Posted August 19, 2014 Share Posted August 19, 2014 my diff/driveshaft area is hard on my tunnel can i take to it with a hammer to gain clearance or is it a no no, or should i be legit and get the floor raised up a bit over this area if its hard on it you would need to cut it and raise it, beating it with a hammer would probably not give it enough clearance Quote Link to comment Share on other sites More sharing options...
dave Posted August 19, 2014 Share Posted August 19, 2014 yea ok so if i cut n raise it, will that be sweet for wofs or need a cert Quote Link to comment Share on other sites More sharing options...
keltik Posted August 19, 2014 Share Posted August 19, 2014 Sure, I think it might have been discussed up-thread.. From LVVTA site: Can I remove my rear seats from my vehicle? Yes, however to pass a WoF the seatbelts will also need to be removed from the vehicle I meant with regards to that bypassing the rusty floor rule. It must do. Would be stupid to have no rear seats and still fail a wof for shitty seatbelt anchorages. Quote Link to comment Share on other sites More sharing options...
cletus Posted August 19, 2014 Share Posted August 19, 2014 yea ok so if i cut n raise it, will that be sweet for wofs or need a cert would need cert. surely if your driveshaft rubs on the floor its low enough/ has other mods to need cert? Quote Link to comment Share on other sites More sharing options...
dave Posted August 19, 2014 Share Posted August 19, 2014 haha probaly Quote Link to comment Share on other sites More sharing options...
Bangbug Posted August 27, 2014 Share Posted August 27, 2014 I do hate deleting things. Quote Link to comment Share on other sites More sharing options...
Bling Posted August 27, 2014 Share Posted August 27, 2014 You can chop a solid rear to add camber, then grind it flush to hide it. Maybe he's been caught out before. Alignment is good for saving tyres though, so not a complete waste of money. I assume he would need to camber specs for the front as well anyway? Since camber is now dangerous lol. 1 Quote Link to comment Share on other sites More sharing options...
AllTorque Posted August 27, 2014 Share Posted August 27, 2014 He'll need to know the front is within spec too. 2 Quote Link to comment Share on other sites More sharing options...
cletus Posted August 27, 2014 Share Posted August 27, 2014 every time we submit the paperwork, and it says lowered suspension, we have to supply a wheel alignment report, I know its dumb in your case as the front is only lowered a minimal amount but thats the rules. http://www.lvvta.org.nz/documents/infosheets/LVVTA_Info_04-2012_Suspension_Camber_Angle_Guide.pdf as for the towbar bolts being loose, if the vehicle hasnt had a recent wof check then we have to do a basic safety check like a wof as part of the inspection, that is a legal requirement. if you have a problem with the inspection, feel free to ring me on 0274 522 049 Clint. 3 Quote Link to comment Share on other sites More sharing options...
Bangbug Posted August 27, 2014 Share Posted August 27, 2014 Clint is a nice guy. Quote Link to comment Share on other sites More sharing options...
Beaver Posted August 27, 2014 Share Posted August 27, 2014 Stop complaining lol, it sounds like you have a pretty small list of things to sort out! Clint knows first hand the amount of retards who try to cert dodgy shit so hes doing us all a favor by checking the rest of the car as well! 2 Quote Link to comment Share on other sites More sharing options...
Bangbug Posted August 29, 2014 Share Posted August 29, 2014 No complaints. Quote Link to comment Share on other sites More sharing options...
cletus Posted August 29, 2014 Share Posted August 29, 2014 if you remove the blocks and raise the front back up, you wont need the alignment report. its the front suspension being lowered that means you need the alignment report, as you have pointed out, the lowering blocks make no difference to camber, when we do a cert check on a 4x4 with solid diffs front and rear we dont have to get a wheel align report. My point for you in long hand: Nobody finds it odd that if the suspension was stock it wouldn't need a check but I could modify it as soon as I had a cert and it's still legal? once its certed then the vehicle has to match what the cert plate says, so if its certed for an engine swap and has original suspension, then it gets lowered, it needs certing again- even if the modifications fall within the wof criteria Quote Link to comment Share on other sites More sharing options...
Mof Posted August 29, 2014 Share Posted August 29, 2014 once its certed then the vehicle has to match what the cert plate says, so if its certed for original suspension, then it gets lowered, it needs certing again- even if the modifications fall within the wof criteria So if it has never been certed for anything, and it gets lowered without certing but falls within wof criteria, Does it need certing? lol mindfuck Quote Link to comment Share on other sites More sharing options...
Bling Posted August 29, 2014 Share Posted August 29, 2014 You can lower a car without a cert yes. The WOF thresholds (restrictions and rules) are available online @ NZTA. Quote Link to comment Share on other sites More sharing options...
cletus Posted August 29, 2014 Share Posted August 29, 2014 have edited my post as it was a bit confusing Quote Link to comment Share on other sites More sharing options...
