MaxPower Posted January 3, 2017 Share Posted January 3, 2017 Hi there I'm buying a 1980 jeep j20 6.2 diesel, it has the usual rust in the cab from sitting outside. A guy in hamilton makes fibreglass cabs for these and I'm quite interested. Whats the go with getting one certified? He said they put steel in for all the mounts etc but said they need extra if you want to use it on the rd, do they need a roll bar type arrangement? is it a bitch\costly exercise? don't want a jungle gym to get into. cheers max 2 Quote Link to comment Share on other sites More sharing options...
flyingbrick Posted January 3, 2017 Share Posted January 3, 2017 I worked for 4wd fiberglass briefly and had a CJ tub from them. Flick me a PM Quote Link to comment Share on other sites More sharing options...
MaxPower Posted January 3, 2017 Share Posted January 3, 2017 16 minutes ago, flyingbrick said: I worked for 4wd fiberglass briefly and had a CJ tub from them. Flick me a PM cheers will do. Quote Link to comment Share on other sites More sharing options...
cletus Posted January 3, 2017 Share Posted January 3, 2017 On 12/26/2016 at 7:33 PM, Transom said: looks like a good start to add a loop onto this, bolt a 360deg 50x5 loop to that crossmember and you should be right Quote Link to comment Share on other sites More sharing options...
cletus Posted January 3, 2017 Share Posted January 3, 2017 On 12/29/2016 at 7:44 AM, oldrx said: Can I machine away small part of front hubs? Bit of them show through gaps in aftermarket wheels, looks rude as shit. would need to see what you want to do, would not be able to if it weakens it in any way 1 Quote Link to comment Share on other sites More sharing options...
cletus Posted January 3, 2017 Share Posted January 3, 2017 3 hours ago, MaxPower said: Hi there I'm buying a 1980 jeep j20 6.2 diesel, it has the usual rust in the cab from sitting outside. A guy in hamilton makes fibreglass cabs for these and I'm quite interested. Whats the go with getting one certified? He said they put steel in for all the mounts etc but said they need extra if you want to use it on the rd, do they need a roll bar type arrangement? is it a bitch\costly exercise? don't want a jungle gym to get into. cheers max the main problem is it would become a new scratchbuilt vehicle, so would have to meet all the requirements of a new build http://lvvta.org.nz/documents/infosheets/LVVTA_Info_02-2013_New_SB_&_Mod_Prod_LVV_definitions.pdf 1 Quote Link to comment Share on other sites More sharing options...
cletus Posted January 3, 2017 Share Posted January 3, 2017 On 12/21/2016 at 10:25 AM, ~Slideways~ said: Hi, can you tell me if I'm up shit creek with a modified/cut radiator support on my 1990 NZ New S13? This model was no airbag, no ABS and obviously over 20y/o. It was like that went I bought the rolling body, but it works well since I have a long engine in there now. I do have a spare support that could be welded in, but it would make it very hard to fit a radiator and fan. nah should be ok, may need some strengthening to make it as strong as it was originally Quote Link to comment Share on other sites More sharing options...
~Slideways~ Posted January 7, 2017 Share Posted January 7, 2017 On 1/3/2017 at 8:27 PM, cletus said: nah should be ok, may need some strengthening to make it as strong as it was originally Cool thanks for the info, good to know its not a definite 'you're screwed' haha. Quote Link to comment Share on other sites More sharing options...
Sunbeam Posted January 7, 2017 Share Posted January 7, 2017 I have a lead on an MGBGT I can get essentially for free. Was imported from the US about 20 years ago and converted to RHD but NEVER been complied or seen by any authority here. The only bit of paperwork we can dig up is the registration certificate from North Carolina. Is it a lost cause? I haven't been able to find an answer on the Land Transport website. Maybe someone on here has been through something similar? Quote Link to comment Share on other sites More sharing options...
Bling Posted January 7, 2017 Share Posted January 7, 2017 Paint it black Quote Link to comment Share on other sites More sharing options...
Metalhead96 Posted January 9, 2017 Share Posted January 9, 2017 Hey everyone. Friend of mine is doing a s13 suspension conversion on his r31 skyline. All the componants and parts a bolt in except for the rear struts. Reason is the r31 has 3 bolts for the strut top as the s13 uses 2. My question is, can we mark out and drill 2 new holes in the strut tower to install the strut in or is this considered a big no no? Thought I would check before we make swiss cheese out of a strut tower Quote Link to comment Share on other sites More sharing options...
kyteler Posted January 10, 2017 Share Posted January 10, 2017 Swap the strut tops? 2 Quote Link to comment Share on other sites More sharing options...
Mr Vapour Posted January 10, 2017 Share Posted January 10, 2017 Clint I have a mate wanting to put a jag front end in a old dodge truck. He has been told that this will make it a scratch build. IS this correct. Can you do the certification on this? HE is an engineer with all the correct equipment to do it correctly. just wanting to know if the information he has been given is correct. Thanks. Quote Link to comment Share on other sites More sharing options...
cletus Posted January 10, 2017 Share Posted January 10, 2017 6 hours ago, kyteler said: Swap the strut tops? This would be the best idea otherwise you could re drill, your pic doesn't work for me but you may have to do some strengthening, ie just as an idea you could cut a 3mm disc that fits up under the strut tower, plug weld it through the un used holes then drill your new holes Quote Link to comment Share on other sites More sharing options...
cletus Posted January 10, 2017 Share Posted January 10, 2017 6 hours ago, Mr Vapour said: Clint I have a mate wanting to put a jag front end in a old dodge truck. He has been told that this will make it a scratch build. IS this correct. Can you do the certification on this? HE is an engineer with all the correct equipment to do it correctly. just wanting to know if the information he has been given is correct. Thanks. Not if he uses the original dodge chassis, it would still be a modified old dodge truck. If he makes a new chassis or used a chassis from something else then it would be a 2017 lvvta dodge truck replica it does require a certifier with 1D which is the same category as a scratch built car needs. I would recommend he gets the relevant hobby car manual chapters as it will need a bit of work, extra crossmembers etc. You can buy the individual chapters now which makes it cheaper I have that category so can do that level of cert 1 Quote Link to comment Share on other sites More sharing options...
oldrx Posted January 10, 2017 Share Posted January 10, 2017 Is there a limit to how long a lower control arm spacer can be (under strut)? Quote Link to comment Share on other sites More sharing options...
cletus Posted January 11, 2017 Share Posted January 11, 2017 There is no specified max height, but it would still have to be a sensible amount Quote Link to comment Share on other sites More sharing options...
oldrx Posted January 11, 2017 Share Posted January 11, 2017 75mm spacer? Whats considered an acceptable bump stop clearance? Quote Link to comment Share on other sites More sharing options...
Mr Vapour Posted January 11, 2017 Share Posted January 11, 2017 On 10/01/2017 at 21:15, cletus said: Not if he uses the original dodge chassis, it would still be a modified old dodge truck. If he makes a new chassis or used a chassis from something else then it would be a 2017 lvvta dodge truck replica it does require a certifier with 1D which is the same category as a scratch built car needs. I would recommend he gets the relevant hobby car manual chapters as it will need a bit of work, extra crossmembers etc. You can buy the individual chapters now which makes it cheaper I have that category so can do that level of cert Thanks I will pass on your details Quote Link to comment Share on other sites More sharing options...
CamB Posted January 12, 2017 Share Posted January 12, 2017 11 hours ago, oldrx said: 75mm spacer? Surely the rim would hit the ball joint? Or are we talking about different things? Quote Link to comment Share on other sites More sharing options...
