threetwoskyline Posted August 26, 2013 Share Posted August 26, 2013 Salutations,So I'm thinking of converting my R32 to Macpherson strut because of reasons, but how about I check it's okay before cutting the towers up ?Main concern is about cutting new mounting points for the struts, because as far as I'm aware cutting the strut tower is no bueno. Thoughts ?Few people have done it, most notably Driftworks, but nobody has done it to a street car. Not here, anyway:http://www.driftworks.com/blog/2010/06/the-driftworks-r32-suspension-conversion-explained/That's a good photo of roughly where the new mounting points go.So, that's my main concern. The conversion is made up of S13 coilovers, knuckles, hubs, LCA, tie rods and tension rods. I'm told they all bolt straight up,and that the only thing to do is extend the swaybar mount. While I imagine that part of the job is okay, might as well list it and find out for sure.Cheers in advance. Quote Link to comment Share on other sites More sharing options...
escortwags Posted August 27, 2013 Share Posted August 27, 2013 dear great brain of wisdom (Clint) please riddle me this. Would a 61 belair (x-chasis) need drive shaft loops as its had a 355 chev plonked in it's hole? Only asking as the "X" covers 70% of the drive shaft Also any recommendations on a place in Auckland I can go to get compliance and cert from people that care? (had taken it to a compliance place that since collecting the car to fix a few things had curbed two wheels and rounded a wheel nut - don't want to go back) (sample pic below) Thanks x Quote Link to comment Share on other sites More sharing options...
cletus Posted August 27, 2013 Share Posted August 27, 2013 Salutations, So I'm thinking of converting my R32 to Macpherson strut because of reasons, but how about I check it's okay before cutting the towers up ? Â Â Cant see a problem if that area of the strut tower is strong enough, which it should be. Will need TAC approval and a 1D certifier to do it, however. Quote Link to comment Share on other sites More sharing options...
cletus Posted August 27, 2013 Share Posted August 27, 2013 Would a 61 belair (x-chasis) need drive shaft loops as its had a 355 chev plonked in it's hole? Only asking as the "X" covers 70% of the drive shaft Also any recommendations on a place in Auckland I can go to get compliance and cert from people that care? (had taken it to a compliance place that since collecting the car to fix a few things had curbed two wheels and rounded a wheel nut - don't want to go back)  last one of those i did, when i filled out the paperwork i wrote it was not necessary or possible to fit loops due to the design of the chassis, it went through fine  as for compliance for american cars- north shore compliance on porana rd are pretty good, or western compliance on westward ho rd in kelston- talk to Mooks hes a good bloke or C&P motors in grey lynn Quote Link to comment Share on other sites More sharing options...
escortwags Posted August 27, 2013 Share Posted August 27, 2013 Thanks for your help Quote Link to comment Share on other sites More sharing options...
MRWEST Posted August 27, 2013 Share Posted August 27, 2013 yup the guy i talked to in Hamilton said the same thing no problem without them/d ont need due to the design of chassis Quote Link to comment Share on other sites More sharing options...
Shakotom Posted September 2, 2013 Share Posted September 2, 2013 What's the legalities with hydraulic handbrakes? Quote Link to comment Share on other sites More sharing options...
cletus Posted September 2, 2013 Share Posted September 2, 2013 you have to have a motorsport authority card to run them on a road car legally Quote Link to comment Share on other sites More sharing options...
CorollaGT Posted September 3, 2013 Share Posted September 3, 2013 Have Recaro seats mounted using vehicle specific Recaro rails. The seat belt stalk comes off the rails, if going for a re-cert would the stalk need to re-mounted off the tunnel (using those belt mount plates). Or possibly get away with keeping them as is due to being reptible brand rails with all the stickers and standards? Quote Link to comment Share on other sites More sharing options...
cletus Posted September 3, 2013 Share Posted September 3, 2013 have seen one model of recaro seat bracket that needed bigger bolts to cope with belt buckle loading. Â most of them are ok though Quote Link to comment Share on other sites More sharing options...
CorollaGT Posted September 3, 2013 Share Posted September 3, 2013 So, depending on cerifier its possible? Excellent Quote Link to comment Share on other sites More sharing options...
Seedy Al Posted September 8, 2013 Share Posted September 8, 2013 ok, going to ask a few retarded questions.  my cressida has had done to it  sectioned front struts with shorter inserts and cut springs, clearly all captive  shorter rear shocks with cut springs and bump stops  adjustable pan hard rod  shortened front section of a two piece drive shaft due to slam making it to long and touching gear box.  what problems would you for see with this stuff. I know i will need to make a hoop for the front section, will i need todo another one for the facory rear section? motor and trans are factory?  cheers?? also have mild concerns about diff pinion angle?? is this a valid thing to worry about? Quote Link to comment Share on other sites More sharing options...
mutiny Posted September 8, 2013 Share Posted September 8, 2013 very intereted in this as i have done most of the above Quote Link to comment Share on other sites More sharing options...
Indiana_Jones Posted September 10, 2013 Share Posted September 10, 2013 Has anyone here ever used one of these forms?  http://vehicleinspection.nzta.govt.nz/__data/assets/pdf_file/0003/32862/VCUEF-11-Application-for-exemption-from-land-transport-Rules.pdf  Thinking of importing a car, would meet all the requirements, but not the exhaust emissions. A long shot I know, but thought I'd ask just in case someone has had any luck. Quote Link to comment Share on other sites More sharing options...
cletus Posted September 10, 2013 Share Posted September 10, 2013 ok, going to ask a few retarded questions.  my cressida has had done to it  sectioned front struts with shorter inserts and cut springs, clearly all captive  shorter rear shocks with cut springs and bump stops  adjustable pan hard rod  shortened front section of a two piece drive shaft due to slam making it to long and touching gear box.  what problems would you for see with this stuff. I know i will need to make a hoop for the front section, will i need todo another one for the facory rear section? motor and trans are factory?  cheers?? also have mild concerns about diff pinion angle?? is this a valid thing to worry about?  the way i interpret the hobby car manual, you shouldnt need a loop at all. that may differ depending on your certifier. make sure your springs, if they are cut, match the spring seat shape wheel alignment if you think the pinion angle is excessive, then that may be an issue  how did you section the struts? Quote Link to comment Share on other sites More sharing options...
Testament Posted September 11, 2013 Share Posted September 11, 2013 Are bump steer correction kits like this (see below) certable? I think mikuni asked about this kind of thing some time ago (or maybe that was balljoints?) but I haven't been able to find what the resolution was   Quote Link to comment Share on other sites More sharing options...
escortwags Posted September 20, 2013 Share Posted September 20, 2013 Hello sir  Is it true that Astro Supremes CANNOT be certed? This will decide my next wheel purchase  Thanks 1 Quote Link to comment Share on other sites More sharing options...
KKtrips Posted September 20, 2013 Share Posted September 20, 2013 I think it's only certain brands can be certified - there is a bulletin out about them.. Will find it for you, Â http://www.nz-hotrod.com/vbulletin/showthread.php?5666-Astro-Supreme-failures&s=5e11738c95f6c3ea8249cffe0a462f9f Quote Link to comment Share on other sites More sharing options...
KKtrips Posted September 20, 2013 Share Posted September 20, 2013 Here you go.. Â http://www.lvvta.org.nz/documents/infosheets/LVVTA_Info_01-2011_'Supreme'-_brand_aftermarket_wheels.pdf Quote Link to comment Share on other sites More sharing options...
escortwags Posted September 20, 2013 Share Posted September 20, 2013 hmmm cheers, so get pictures of the back first then I guess? ps. second link aint working Quote Link to comment Share on other sites More sharing options...
