Showing content with the highest reputation on 10/04/22 in all areas
  1. The engine is a Suzuki GSF1250, so not a big hp R1, Busa type but the price was about a third the cost of a sport bike engine and it has a stacked gearbox which was gonna be useful. It still puts out 110-120hp with some easy mods but its main feature is torque, about 110NM which is all in by 4000rpm. Space was a big concern as these cars are tiny, 3m front to back, 1.295m side to side. From the rear axle to the back of the car is 50cm or something silly so I needed a compact engine to allow enough room for a diff, that's where the stacked gearbox helps as it makes the engine shorter front to back. I spent a while considering different configurations, putting it in front of the axle would make it easier to sort the drivetrain but there is still minimal room in that direction and I really didn't want to chop up the interior. This way around had some benefits but still not enough room. White tube at the bottom is the axle centre. Then I noticed the bumper sized space behind the headers.
    24 points
  2. Trans cooler mounted, shifter cable set up. Underneath looks pretty busy now but there's no other way of getting everything to work so meh. Ordered some sound deadner stuff for the floor before carpet goes in
    21 points
  3. I picked this little thing up ages ago from Fronte fiend @Goat, good things take time but I just fuck around heaps so I'm only now making some progress worth posting up. Hopefully some peer pressure will give extra motivation.
    16 points
  4. So I kind of went too full on with the throwbacks this year. not only acquiring a set of recaro fishnets and a stainless dumpy for the rotor conversion. I seemed to have impulse purchased myself a 89 bg8 Mazda gtx hatch, but in Rallycar steez. the body is immaculate condition, with a very well built cage, terratrip and terraphone already set up. 3 sets of rims and tyres and 2 spare motors and a host of other bits. score right???? well the car was sold with some “ lifter noise”. ok sure, that’s fine. I decided to pull the spare motors apart. motor 1 “run bottom end”… missing all lifters, hmmm. Head off for a look. Oh boy, pistons are umm smoked, ring lands are awol. bottom end however is mint. Block could be saved with a light hone, head has some heavy combustion chamber damage. To the parts shelf it goes. motor 2 “rebuilt motor but has lifter noise”…. missing lifters also, Dafuq. head off, wow looks like shit has gone through the motor aswell. Bottom end also mint. Could actually use these bearings aswell. motor 3 “ in the car, runs but lifter noise”. hla’s have lots of play. Pulled the sump to inspect. Bottom end is tight and super clean. No crap in the pan bar a small amount of sludge build up. turbo exhaust side has a fair amount of oil residue in there. I will replace all lifters in this motor and test it out. It starts so good, does die out because some numpty has cut the intake pipe too short to fit the restrictor, and isn’t sealing. False afm reading I guess. car has new discs and pads fitted. savage gauges, yup they’ll go straight to the bin. new alloy radiator too, full width dealio. new Silverster Hans spec belts and some sick stickers bro. Love the fit of the Racetech seats too. plans: sort the lifters etc, get it running like a boss. gain by msnz license finally and get an authority card. hopefully find a spare gearbox for it. go full send on some club stuff.
    16 points
  5. I have been keeping an eye on the lvvta docs but if you see anything whack let me know. Crush tubes for the engine subframe mounts Put the rear ones where the original engine subframe mounted Bending tube to fit The subframe isn't finished, I still have another engine mount I want to pick up and maybe tie it into the shock towers but for now it's enough to get it in.
    14 points
  6. Ive been continuing to pick away at the 7M motor. @Roman dave made me some prototype pistons to try out some things. with my big cams and increased lift there is still a million rooms between the valves and the pistons. im never going to keep this a non interference engine if im aiming for 11 to 1 so i might as well re-think the whole piston dome situation. all those years building stupid two stroke engines might just pay off after all........ upshot is that i can run bigger valves without any clearance issues - only thing limiting this really is the 5M head's fondness for cracking between the valves and the spark plug hole. the other thing ive done is to sort out the cambelt/front pulley drive on the front of the crank. 5Ms have a stepped crank at the front and the cam pulley has a larger internal diameter than the crank pulley, 7Ms do not, the 7M crank pulley is larger internal bore than the 5M. so i machined the front of the crank and cut a new keyway in the crank so i can run the 5M pulleys on the 7M crank. i did spend 2 hours machining the crank only to find that it was bent and the middle journal was running out by half a millimeter. i had a spare crank so i just used that in the end. 2022-04-10_04-22-50 by sheepers, on Flickr 2022-04-10_04-23-10 by sheepers, on Flickr 2022-04-10_04-22-58 by sheepers, on Flickr 2022-04-10_04-22-44 by sheepers, on Flickr 2022-04-10_04-22-30 by sheepers, on Flickr 2022-04-10_04-22-37 by sheepers, on Flickr 2022-04-10_04-22-22 by sheepers, on Flickr 2022-04-10_04-22-14 by sheepers, on Flickr
    14 points
  7. What an idiot, he could have probably made it that light just by swapping a 1NZ in
    12 points
  8. so that the engine side of the ecu all wired up and plugged in .. relays done for ecu main and coil packs... on advice from a mate I ran all 4 ITB runners to 1 vacuum manifold and ran FPR and MAP of that and I also ran brake booster aswell... so thats all vacume hoses done aswell.. still need to run wire to boost switch, boost solenoid , wideband o2 ,.. put a relay in the boot and wire fuel pump...and put ends on spark plug leads.... oh and get spark plugs... but then it might be time to try and fire the old girl up..
    12 points
  9. I got distracted with engine stuff. Pulling apart the sweet 3 cyl 2 stroke engine I found a blown bigend. I still intend on rebuilding it but after reading some cool builds on the net I bought one of these to go in first.
    11 points
  10. Mate I am only too happy to post extra graphs in this thread
    9 points
  11. Alright people, I have a strict Tuesday/Saturday upload schedule. So this video won't be searchable and public till Tuesday - I'd appreciate the link not being shared around till Tuesday. BUT for oldschool.co.ng members, I shall post it below. Mainly because @Roman and I have already watched it and are impatient. Please interact with the video if ya like it. Was very very very very fun to come and check out a car in it's natural? habitat. Okay, enough advertising my own film project in someones build thread. Here's the link:
    9 points
  12. V2. Find an unbent pair of the correct struts, strip, paint and reassemble. New shocks and fittings. The original rubber from the strut tops have been removed and replaced with poly. The 2 different strut bodies but look very similar. The correct mk2 escort in the foreground and the unknown in front. The tube diameter, caliper spacing, disk shield spacing, stub axles and heights all measures exactly the same.
    9 points
  13. There was a bit of rust in the plenum that needed sorting so I started poking around. View from the inside I cut it all out about 2 years ago and it's still in the same state.
    8 points
  14. needed to do som maintenance on the focus ... one of the rear wheel bearings was making a hell of a noise so thought I would just do both. you can but a complete hub with studs an all from any focus fiesta with 4 studs.... but replacment bearings where just Over 50bucks to my door..(I've git other projects draining my wallet). next was the thermostat housing..I thought it was leaking from the bung on the bottom (think it's for turbo coolant times on the rs) but turns out that the side of the seal place as gone the new one bought didn't have any of the holes drilled for temp sensor or bottom bung ...so figured it can't leak from there then. I doubled up on the temp sensor o ring then put the clip in ... and no leaks. gets up to temp quicker and the heater is amazing... think the old one was stuck open (191 odd thousand ks) as this is the 1st time the temp Gaughan gone to half way and stayed there ... use to hover around 1/4..
    8 points
  15. I've got most of the underseal off the underside. Starting off with the heat gun and some narrow paint scrapers with the corners ground off. Then wet it down with turps. I started off with kerosene, but it takes ages to evaporate. The turps seems to work better, it's the cheapest solvent I could find. $5 per L when you get it in 4L. It evaporates, but not as fast as thinners(which is super spendy from Mitre10). Agitate the wet turps with a brush and steel wool to dislodge/dissolve the underseal. Wet it down some more with the brush. Make a big mess on the floor. Then use a rag to wipe up all the dissolved underseal. Change the rag when you run out of clean sections. Repeat until no more underseal. I decided to remove all the bent strips of metal they use to hold the brake and fuel lines, etc... down. I'll put rivnuts in and use p-clips instead. I also did some panel beating along the bulkhead seams to tidy up the edges and make them sit flush. The spinning death wheel uncovered some pin holes around the front end of the drives side sill. So I went exploring. Looks like a really straightforward repair. I'll replace that section of inner sill and the little bit of floor. And I'll have to re-use the vent thingy and make a new outer sill section. Looks like 1.2mm... I'll have to get some. The 1.6mm I have is a bit overkill. The front end has kissed something once upon a time and the area below the headlight has been pushed in about 10mm. I've had a go bashing it out but it's not keen to move. The front panel is rusty all the way across behind the bumper lip and the bonnet slam panel doesn't look so good either. I can get the whole front panel for $300, it's not worth the effort trying to repair what's there. The small panel below the headlight also needs replacing, but it's not available separately. Hopefully I can get it cut from another one. It's all curvy so I'd rather not have to make one.
    7 points
  16. It's interesting to see the difference it makes, being less of a weiner with launch rpm. On my fastest run, launched at 7500 and then rpm dropped to about 6300 at minimum. (pink line) The last time I was launching at 4500ish, and engine speed dropped to 2300 haha. This probably wasnt my fastest last run, but yeah really need to keep that rpm up and allow for that it's going to bog a bit. These tyres are more happy to just keep spinning for a bit than bogging.
    7 points
  17. Yeah but I cant even take a photo of it, because the printing on it is super shit Type it out for you though. In brackets next to it, is my PB from last time R/T: .531 (.411) 60: 2.096 (2.182) 330': 5.689 (blank) 1/8: 8.682 (8.928) MPH: 81.12 (80.17) 1000': 11.276 (11.583) 1/4: 13.496 (13.832) MPH: 99.51 (99.65) I thought my 60ft was heaps better being "2.0" but 2.096 is pretty damn close to a 2.1 haha Only 0.086 seconds better! So maybe it is/was actually a power improvement, or the smaller tyre diameter helping out rather than an epic launch. It looks like most of the gains were actually in the 1/8th mile region
    6 points
  18. So now I had a spot for the engine I had to work out if I could get drive from it to the axles that goes in the right direction. I spent more time thinking, looking at pictures, measuring, reading forums, asking @yoeddynz questions, doing nothing, buying parcel shelf speakers, looking at rims, starting other projects. I started to cad (poorly) up my own diff with countershaft unit when I found an outfit in the UK who do R1 conversions for Minis and they have their engines facing the same way, a quick email confirmed they would sell one of their diffs separately if I wanted one. This Or this So now I had a solution I started to fit the engine.
    5 points
  19. So woke up this morning and it indeed needed an overnight burp. It took around half a litre to top up and good to go. What a difference it makes. It can now easily sit on 60mph without stinking of burning oil and smoking on cool down. Fixing the oil leak helped too. I'm genuinely shocked at what a difference it makes. Random pic of it with it's bigger brother outside the new shed I need to build for it.
    5 points
  20. Last night was wild! I've had this on my mind all week but made sure everything was going to be 100% and didnt forget anything etc. So I leave super early so I could get through scruitineering early, and get some runs early. I stop in at morrinsville on the way to get some food. Start the car back up - and my electric waterpump isnt working! Fucks sake! So I checked over everything and nothing obvious causing the issue. Was pretty disheartened and so I messaged @MopedNZ and @GuyWithAviators to say that I probably wont be able to make it. As they were coming from Tauranga to see it. They insisted that at the least they'd meet me where I was. The previous times the pump has failed, it's been that it just wont hot restart. Because the big starter capacitor cracks or something. So sure enough, once it cooled down enough it started again. This gave me the confidence to take a gamble on that it'll be the same issue, and I'll be able to get there and back home so long as I just let it cool if needed. So, yeah! Second run of the night. 13.49 @ 99.5mph and 2.09 60ft. It was awesome! I experimented with some other launch settings and tyre pressures, my "bad" runs were generally around 13.7. Hard not to be happy with that. I was eliminated on the first racing round by a real quick rotary, but I was real happy to get 4 runs in. This time there were heeeaaaappppsss of people coming over to see what's in the engine bay, or yarns about it. One young lady asked me if I'd sell it to her. Was lots of fun, and a real cool atmosphere at nightspeed again. I rounded out the evening by cruise control smug facing back home in luxury. A++ would drag race an Echo again Big thanks to Andrew and Cullam for coming along and helping / support
    5 points
  21. Chucked some primer on and then it was time for a quick test fit to check gaps and alignment. Uncle Google told me that the easiest way to line the doors up is to start off by getting the bottom and back gaps uniform with the fixed rear quarter and rocker panel and then to tweak the front fender to suit. So off came both front fenders which left the poor old Muzzy looking decidedly bare. Looks like someone has been here before as both splash panels have been replaced with Scott Drake replicas still sporting their labels. Date stamps say 2013 so must have been fitted two owners back. The chassis legs and inner panels look nice and solid with signs of the original Nightmist Blue factory paint.
    4 points
  22. So heres my idea. Thinking the irony of a electric petorl can is too funny Outta random bits and bobs laying around. So far ive done. •chopped floor outta jerry can •chopped up a swing arm to work on the can •chopped up a small bmx welderd on a front •Also have a cool little seat I have a electric motor here that ill mount up and see how well it goes other wise ill go to a petrol motor but thought for shigs and gigs ill try the electric 1st
  23. Sooooooo, I purchased a running and legal burgman from a chap in Te Puke, as that seemed easier than fixing the first one. The Te Puke one runs well, and rides ok, but is a bit rough around the edges. It's been dropped a few times, so the front plastics were pretty haggard, and had been repaired with cable ties/fiberglass/bog/screws and steel brackets etc. The plan was to put all the good plastics from bike no1 onto bike no2, and have one running tidy-ish bike, and sell off what I don't need/use to recoup some cash. But bike no1 is a much lower k bike, so I've decided to do an engine swap rather than a body swap. Some of the features of bike no2, Barry spec back rest, The ruff-as-guts plastic repairs, The sanded windscreen, apparently he was trying to polish it? And for whatever reason it has a later model rear wheel, and muffler from the skywave (I also got a 2004 EFI skywave with bike no2, more on that later) I rode this thing back from Te Puke, and to work once, and it goes pretty well. The 0-80ish acceleration is crazy good, and it tops out at 130, but gets there pretty quickly. The only problems I have is my height, I need to get my bum back a bit, and the windshield is exactly the right hight to direct all the air into my helmet, so it sounds like you're going 300kmh at 100kmh. Duck down behind the shield, and it's crazy quite, so I'll get an extension for it. Having not had a big scoots before, I thought the rear wheel set up is slightly interesting, and different between the burgman and the later model skywave. Burgman has splined disc and wheel, skywave spec is splined hub with bolt on disc and wheel. Anyways, I ripped the motors out of both, cleaned up the good bike and motor, and will soon slap them back together. I will whip the rocket cover off the new motor and just make sure it's not about to have a cam-tastrophe like the dead engine. Also, note wrecker writing on engine, this is not the first time this bad boy has played around. Regards, V-AN250s are my life now-G. Edit: I just clicked, the rear wheel will have come on the wrecker engine, hence it being different/from a later bike.
  24. @Roman More lightness inspiration, surprised no dimple dies used however
  25. These come up on trademe for reasonable price couldn't resist It's eibach street series so not fully adjustable just height adjustable,still ment to be semi compliant on road too. Should help the semi slicks dig in
  26. Still getting lots of wheel spin off the line, so a lower launch rpm might be beneficial. However it's amazing compared to street tyres how these just hook up and go anyway!
  27. So I'm basically set on using a 1.8L. The 4g93 is known to be able to make good power, but it also has weak rods. So my thinking is to find a 4g93 block for bugger all, then put some put H-beam rods in it. Apparently Ca18Det rods are an upgrade and you can also using 4agze pistons since they are both 81mm bore, but you have to heavily shave the skirts. Then for the head, I want to find a 4g92 1.6 dohc Mivec head so it flows like a mofo. That way it kind of justifies not just using a 4g63 and sticking with the 1.8 block. Apparently some Mitsi ECU's are programable, I wonder what the limitations are versus using a link or even Speeduino? Should be fun and I've never owned an AWD turbo performance thing. The question is, do I make it look like an Evo 5 when it isn't one? Technically it could easily be faster than one with more power or what ever. Or do I keep it looking like a boring Lancer? Problem there is if I change my mind later, I'd need a cert to cut the rear arches etc.
  28. I then decided bugger it I'll go get this gearbox anyway and had a nice Sunday 4hr round trip with my 7 year old boy. Ice cream, BP pie and all. Took the runaround Celica and hoped it would be happy with a gearbox in the back. Arrived and bought two identical gearboxs and two matching transfer cases, some driveshafts and a flywheel for a 4g15. Back home and wife helps me lift them onto a couple of wheel dolly's
  29. Definitely room for improvement in that 60ft. I dont know anything about making fwd hook up. But I've run slower than that, with a slower trap speed but a quicker 60ft. (Same displacement engine, with a huge parasitic loss at the crank) Itll be hugely interesting how a decent exhaust effects your trap speed too. They say the mph is the telling for how much hp you have, and the ET says more about your chassis. (Maybe it was you who said that?)
  30. Ahh not really necessary for an NA motor. I've been watching one of the videos of the launch, and I can see my rear suspension is punishing me a bit. The rear shocks are completely flogged, if I push the car down it bounces about 3 times before coming still. So it's squatting heaps and unloading the front. So maybe some 60ft improvements with some stiffer / solid rear
  31. I got the chaly registered and road legal and took it out for its first shakedown run a few weeks back around the hills and through Lytellton to Wunderbar. Those side boxes I got from the swapmeet last year were on the back of my mind so I pulled the pin and started making some brackets for them The boxes themselves are pretty rough and have a few cracks and pieces missing, so I'll address them, paint them and maybe add some gas struts.
  32. when I got home from work yesterday I started again and rerouted the wires.. I just need to add ignition +from the fuel box to the engine bay side for the main relay.... and the signal and positive for the boost solenoid out the drives side.... but that is all the engine bay wires run..... I am really starting to get my head around it and the HP academy videos have helped a lot...
  33. Good to see you've worked out the modern Dell'orto and lumpy cam setup for your modern starlet
  34. I had forgotten how bad cut springs ride, so didn't really drive the car much at all between December to March. Had a busy time with house stuff over most of the summer months and once the house sold I began hassling the Mrs for some $$$ to buy an adjustable set up. She caved and I picked up some BC adjustables, (took Clint's advice re quality in comparing similar priced adjustable set ups), they're the FC rx7 model, and they bolt right into the HB which is super cool. Out of the box they slammed the shitout of the front though, so I've been fine tuning the height I want. Cosmo's have a really low underbelly, whilst not actually looking that low. Guard lip rub, inner guard rub, and crossmember clearance of 40mm meant I had to raise it up quite a bit. (2nd pic is showing underbelly with out of the box height - could drop it quite a bit lower if I wanted to for shits n giggles). Have only fitted the front's thus far, and man it makes a hell of a difference to the drive, much nicer even with rusty old shocks and cuts still in the back. Did the drive from Auckland to Tauranga the other day with only one scrape in a silly hump in the road. I'm happy with how it's sitting now, and will chuck the rears in soon. It's the first car I've owned that's had adjustables and geez I'm sold, such a silly gimmick of being able to play around with ride height so easily, but I love it. 15ish mins each side and I can muck around with height.
  35. this stuff even comes in different colours https://caswellplating.com/epoxy-gas-tank-sealer.html seems to set hard like plastic (says can also be used to pot electronics etc)
  36. Please 3d print a new exhaust soon. The suspense is killing me.
  37. got a few things done this week. 1st was the oil filter .. the pinto one hots the plug end of the IACV. so I did some professional googling and found the xflow has the same 70mm diameter seal but is only 80mm in diameter and the pinto was 92mm. getting to the oil filter is a weeeee bit harder now .. just need to get in from the aide behind the passenger front wheel also filled it with new oil... the new cam belt turned up with the filter and oil so I I put that on with all the timing marks spot on......that then allowed me to be able to bolt the crank and home triggerwheels on. I had noticed a few things when I was under the car... one of them being the drive shaft wasn't sitting right and the rear drifeshaft hoop needs modification to be able to get an exhaust past it...... so out they came ( luckily out and back in without having to remove the full interior to get to the bolts ). once I had the hoop out I tacked it to some steel cut a section out and remade it... the bottom section can still be removed and bolted back on... and that should allow some room for a sneaky exhaust. the issue with the drivshaft was the flange on the front section close to the center bearing was hitting the center bearing ... I made new slotted tabs and welded them back on. I then left those bolt lose while the rest of the drive shaft was in place . and I jacked the diff up and from full drop to all the way up the center bearing moves about 20mm... so with the diff all the way up I tightened the center bolts and that flange had about 5 mm clearance and on full drop about 10mm ..so that seems to of fixed that. back to the motor I bolted the trigger sensors on and gapped them I had to tighten them up and had bugger all room so I modified a old spanner with a fucked socket. and with the sensors now on I can put the fan and shroud back on ( still waiting on a smaller fan belt tho) made a bracket and mounted the coil packs started working out ht lead length and tried the heat sleeves and today I started on the eco harness. apart from mounting the Map sensor I'm pretty sure everything is all in the engine bay. this is about all I need I believe.... ( I am excited and nervous about doing this but I want to have a go and I've got some knowledgeable people I can ask when stuck). removed all the wires from the harness I don't need I untangled the loom so it's clean sorted and none crossed over.... I also found a spot in the firewall for a hole and started to run the loom out. still got to mount relays and run powers and earth's.. ect ect but I'll take my time
  38. 1 point
  39. so after work today I got the fuel lines fixed to the shell and the fuel feed and return fubber hose parts done by the fuel tank.... I was about to start looking at making heat shelds ....... and then much like the sound of the ice cream van to my girls...... I heard the sliding door of a courier....and in her hands was the trigger wheel I've been waiting for ..... so I stopped what I was doing and had a look to see if it will fit and not hit on anything.......pretty fucking sweet. found some washers to center it on the idler pulley bolt.. had to move one sensor out... and one sensor in (that also needed the bracket to be cut out so I can use lock nut). I will be able to tack it on ....on the inside edge. but all in all I'm happy with that looks like it will work .... so I can look at getting it all tacked up and on the motor.
  40. I'm almost at my 10k budget But didn't allow for stuff like tints audio Think I'm going to go over by about $1500 after it's been tuned. Doing it all proper though and everything that needs replacing will be done, because think I hold on to it for a while. It's still will be alot cheaper than the mazda mps 3 I was considering at the time that wasn't as tidy either and about equal performance
  41. Done the engihe and dsg oil and filters then done dsg ecu reset Still waiting on my fan temp sensor then I'll service the cooling system After doing a bit of research while I've got the front off to upgrade intercooler and clean the intake ports,(it's a while your in there) I'll take the injectors out and get them serviced and flow tested for piece of mind with the extra ponys it will produce Also recommended is new spark plugs and coil packs before tune Alot of guys seem to buy r8 coil packs Ive got a invoice that says coil packs and spark plugs were replaced by vw 2 years ago,so I gona roll with that cause genuine coil packs + spark plugs ain't cheap.
  42. I opened up the petrol tank which has been sitting around for awhile. To my suprise it was like brand new inside. Cleaned it inside and out, and installed. The fuel filler neck was a bit odd. It didn't quite sit flush to the side of the van. I ended up removing some of the floor with a die grinder to lower the fuel filler and get it all lined up. Potentially it was this poor from factory. New gasket, a lick of paint and its done. From the outside, the fuel cap covers the entire filler neck face. I went so far as to even replace the fuel cap screws which hold the locking tongue on from self tappers to stainless caps.
  43. I ended up repairing the heater fan resister with a new board and 1 new pin. Tested the heater box core, had to straighten the pipe ends and fix 3 small holes. All reassembled. Have made a few odd parts as I go along such as new tab washers for the front hubs.
  44. Got new brake hoses, tube nuts, brake pipe clips, some copper nickel pipe, made some hose brackets and joined toyota parts to plymouth ones
  45. Had a bit of a cockup When I pulled the motor out of the white car and stored it, I put a rag in the dizzy hole to stop shit getting in there Being so long ago, I forgot how big it was I also forgot to remove it when I set the rockers It appears the oil pump drive went om nom nom on the rag . It was quite hard to get out and it was a bit chewed When I got it out there was one bit missing out of the rag that I could not find . I mucked around for ages with the vacuum down the dizzy hole and got a bit of fluff out I deemed getting the rag out to be an essential service so went to work and got my snake camera and grabby thing, found the offending bit of rag hiding in the sump next to the oil pump and did a doctor spec cottonectomy Phew
