CUL8R Posted August 12, 2022 Share Posted August 12, 2022 You could make thicker body & camper mounts - that would give you increased clearances. Also taller tyres to help with ratio a little even with your diff ratio change Quote Link to comment Share on other sites More sharing options...
HumberSS Posted August 16, 2022 Author Share Posted August 16, 2022 @Otodat Yeah i did get the Delta. I swapped it for a diff as the one in it wasnt the go...i kept a few bits, mint doors and a few other tidbits. Can still raid some bits if hes quick..Let me know if hes after anything. Ill update on the full story soon. 1 Quote Link to comment Share on other sites More sharing options...
yoeddynz Posted August 31, 2022 Share Posted August 31, 2022 Great reading Also... "I think a few less doobies would have helped.." But so fun Quote Link to comment Share on other sites More sharing options...
ThePog Posted December 30, 2022 Share Posted December 30, 2022 Fucking pic-less update like a useless cunt. And worse you didnt take my advice about the mechanical fan. Quote Link to comment Share on other sites More sharing options...
HumberSS Posted December 30, 2022 Author Share Posted December 30, 2022 11 minutes ago, ThePog said: Fucking pic-less update like a useless cunt. And worse you didnt take my advice about the mechanical fan. I left my charger at work. Did I mention you were a cunt? 1 Quote Link to comment Share on other sites More sharing options...
ThePog Posted December 30, 2022 Share Posted December 30, 2022 Just now, HumberSS said: I left my charger at home. Did I mention you were a cunt? You shouldnt drink so many beers. Or be such a cunt. 1 Quote Link to comment Share on other sites More sharing options...
HumberSS Posted December 30, 2022 Author Share Posted December 30, 2022 1 minute ago, ThePog said: You shouldnt drink so many beers. Or be such a cunt. I've had 1.5 beers since Xmas. I feel surprisingly good. I will investigate mechanical fan if needed but I think its an easy last minute addition. I also haven't got a fan or fan mount clutch thingy, and it's not common to other yotas so I need to scour tardme for a bit 1 Quote Link to comment Share on other sites More sharing options...
browndog Posted January 9, 2023 Share Posted January 9, 2023 Nice reading, looks like an interesting conversion! If I may offer a couple of observations, (and I really hope not to offend here) ........ 140 amp alternator will take a lot of hp at full load. A single V belt may struggle, you might find it will eat belts, or slip unless it is very tight. Or both. The engine mount cradle might give problems. Engine mounts welded to the middle of that rectangle box section are imparting quite a big bending load right in the middle. I think they will bend/sag downwards once you hit a few bumps and potholes in our fine NZ roads, of which there are many. Maybe some triangulation will help. I probably would have made a cradle bolted through chassis rails, downwards to pickup engine mounts, then underneath engine, in a U shape. Will be infinitely cooler than it was, keep up the good work! 1 Quote Link to comment Share on other sites More sharing options...
HumberSS Posted January 9, 2023 Author Share Posted January 9, 2023 Thanks @browndog. I never thought about the alternator load/belt slippage it's a good point. The triangulation of the cradle has crossed my mind also. It's heavy wall tube, but you are right perhaps there will be a 'hammering effect' from the weight over time. Welding the mounts on has actually bowed those tubes ever so slightly which has made me wonder about long term strength. I'm going to get the cert guy in this week so will run it by him, but I think you are right, a bit of triangulation would definitely help. Appreciate the feedback mate. 2 Quote Link to comment Share on other sites More sharing options...
Mr.Mk1 Posted February 10, 2023 Share Posted February 10, 2023 Love watching this evolve, good shit! 1 Quote Link to comment Share on other sites More sharing options...
HumberSS Posted February 10, 2023 Author Share Posted February 10, 2023 2 hours ago, Mr.Mk1 said: Love watching this evolve, good shit! Thanks dude appreciate the props Quote Link to comment Share on other sites More sharing options...
Tiger Tamer Posted April 21, 2023 Share Posted April 21, 2023 I am no expert on exhaust design but have done a a few myself so I will just add my 2c worth. I see you have already built your own 4 into 1 headers which is what i probably would have done . They are supposed to make the best overall power in a performance engine but I have read that 4 into 2 and then to one is better for torque. Of course the tube dia there is the most important. A large collector like you have done is good and I think going down to 2in would be ok to the mufflers. After the mufflers you can drop the dia of the exhaust down without hurting power as when the exhaust gases cool they don't need a large tail pipe, though adding another muffler in the tail pipe section is supposably restrictive. This mainly on what i have read and some of what i have done myself. When I restored my Tiger I replaced the 260 with a 5.0l (302) and increased the power output by about another 100hp. I made my own headers and to get it up and running used the old twin pipe exhaust that was on the car for the 260. I can't remember the size of the exhaust but I think it was about 1 1/2 in and had fairly normal mufflers on it, nothing loud. I bought some straight through glass pack 2in mufflers for it and redid the entire exhaust in 2in expecting a seat in the pants feel of extra power but didn't. It does sound cool though. You are probably just wanting I nice V8 burble out the rear and no drone in the vehicle. Hopefully this is of some help. Cheers TT 1 Quote Link to comment Share on other sites More sharing options...
HumberSS Posted April 21, 2023 Author Share Posted April 21, 2023 4 hours ago, Tiger Tamer said: I am no expert on exhaust design but have done a a few myself so I will just add my 2c worth. I see you have already built your own 4 into 1 headers which is what i probably would have done . They are supposed to make the best overall power in a performance engine but I have read that 4 into 2 and then to one is better for torque. Of course the tube dia there is the most important. A large collector like you have done is good and I think going down to 2in would be ok to the mufflers. After the mufflers you can drop the dia of the exhaust down without hurting power as when the exhaust gases cool they don't need a large tail pipe, though adding another muffler in the tail pipe section is supposably restrictive. This mainly on what i have read and some of what i have done myself. When I restored my Tiger I replaced the 260 with a 5.0l (302) and increased the power output by about another 100hp. I made my own headers and to get it up and running used the old twin pipe exhaust that was on the car for the 260. I can't remember the size of the exhaust but I think it was about 1 1/2 in and had fairly normal mufflers on it, nothing loud. I bought some straight through glass pack 2in mufflers for it and redid the entire exhaust in 2in expecting a seat in the pants feel of extra power but didn't. It does sound cool though. You are probably just wanting I nice V8 burble out the rear and no drone in the vehicle. Hopefully this is of some help. Cheers TT Thanks mate that's def helpful. Cool that you have a Tiger btw. I did consider a 4-2-1 design but wasn't sure on primary lengths etc and kinda just ended up going 4-1 for ease. Although not much is easy about building headers. I put a separate thread up in the tech section and kpr said glass pack straight throughs were also the jam. I am just after a nice burnle, definitely nothing offensive or loud. I think between what the two of you have said I'm getting a good picture of the direction I'll head. Quote Link to comment Share on other sites More sharing options...
Roman Posted April 21, 2023 Share Posted April 21, 2023 There's no point in a 4-2-1 on a V8, and a 4-1 doesn't achieve the same scavenging effect as a 4 cyl engine. A 4 cyl motor has an evenly spaced 4-3-2-1 (or whatever) firing order. But the v8 firing order means there isnt an even spacing. Which is what gives it that V8 sound rather than sounding like 2 4cyl motors. V8 is more like it fires in pairs quickly together, a gap, then pairs quickly together (shortly after each other) There's still benefit to having a tuned length runner though, you'll probably want them as long as is practical. One benefit of long primaries is that any difference in length between the pipes gets reduced as a % of overall pipe length. 4 Quote Link to comment Share on other sites More sharing options...
yoeddynz Posted April 22, 2023 Share Posted April 22, 2023 On 22/04/2023 at 07:46, Roman said: sounding like 2 4cyl motors. But once he fits the cerbera engine with its flat plane crank.... 1 Quote Link to comment Share on other sites More sharing options...
Raizer Posted April 23, 2023 Share Posted April 23, 2023 Set of 180° headers and 3" pipe. Sorted. 4 2 Quote Link to comment Share on other sites More sharing options...
HumberSS Posted April 24, 2023 Author Share Posted April 24, 2023 On 22/04/2023 at 07:46, Roman said: There's no point in a 4-2-1 on a V8, and a 4-1 doesn't achieve the same scavenging effect as a 4 cyl engine. A 4 cyl motor has an evenly spaced 4-3-2-1 (or whatever) firing order. But the v8 firing order means there isnt an even spacing. Which is what gives it that V8 sound rather than sounding like 2 4cyl motors. V8 is more like it fires in pairs quickly together, a gap, then pairs quickly together (shortly after each other) There's still benefit to having a tuned length runner though, you'll probably want them as long as is practical. One benefit of long primaries is that any difference in length between the pipes gets reduced as a % of overall pipe length. Yeah I didn't really have much room to play with length wise so just couldn't get the runners as long as would be optimal, mostly owing to the engine set back. Quote Link to comment Share on other sites More sharing options...
tortron Posted June 19, 2023 Share Posted June 19, 2023 Also in blue Or red Or orange Or on upside down With body colour stripes on the camper bit looks good I think 3 Quote Link to comment Share on other sites More sharing options...
HighLUX Posted June 19, 2023 Share Posted June 19, 2023 Factory Toyota cream with stripes just swap hilux to say Dyna 5 Quote Link to comment Share on other sites More sharing options...
HumberSS Posted June 20, 2023 Author Share Posted June 20, 2023 2 hours ago, HighLUX said: Factory Toyota cream with stripes just swap hilux to say Dyna I like the thinking. This is definitely on the vibe. Quote Link to comment Share on other sites More sharing options...
