kyteler Posted August 23, 2021 Posted August 23, 2021 Fuck I love the wellside versions of the cab chassis Liteaces.. So sick. 1 Quote
RXFORD Posted August 24, 2021 Posted August 24, 2021 Just chiming in on your driveshaft dilemma... About a month ago I had Russel at Driveshaft Specialists shorten, assemble and balance a customers shaft for me. I prepped, painted and fitted new universals in the front half (d21 navara 2pc), and he shortened the rear section, then added a hilux slip joint that I supplied, then fitted new universals which I also supplied. It only cost $250ish for his portion of work. And the 3 new uni's that my customer supplied cost less than $100 for the lot. What I'm getting at with that novel, is that if you buy and fit your own uni's, getting the shaft shortened then balanced once you assemble it would only be a couple hours work for the shop doing it. 2 Quote
Jeffs_Emporium Posted August 24, 2021 Posted August 24, 2021 I understand where you are coming from but I do not have the tools or expertise, you also mention 'for a customer' so my guess is they paid you atleast $80+gst per hour to do so? All in all it seems like a lot of work when I can pay similar money to have one delivered to my house when all shops are likely to be closed for month and a driveshaft isn't something I'm keen to throw together in my shed 1 Quote
63Ragtop Posted September 1, 2021 Posted September 1, 2021 Tailgate looks like it's might be a nightmare, any replacement available for these or what? Quote
Jeffs_Emporium Posted September 1, 2021 Posted September 1, 2021 25 minutes ago, 63Ragtop said: Tailgate looks like it's might be a nightmare, any replacement available for these or what? Listing for a new one is about $1600 not sure it's actually available. It will get sorted at the very end. Rust hole is just on the edge of the seal not all the way up to window flange 1 Quote
87creepin Posted September 3, 2021 Posted September 3, 2021 Who did you get the driveshaft through? Mlracing no longer do yahoo auctions Quote
Jeffs_Emporium Posted September 3, 2021 Posted September 3, 2021 20 minutes ago, 87creepin said: Who did you get the driveshaft through? Mlracing no longer do yahoo auctions Jesse streeter Quote
87creepin Posted September 3, 2021 Posted September 3, 2021 4 hours ago, dspec_tt131 said: Jesse streeter cheers! Quote
tortron Posted September 9, 2021 Posted September 9, 2021 Just wants a few patches or a whole lower part? Quote
Jeffs_Emporium Posted September 9, 2021 Posted September 9, 2021 Lots of dents in the whole lower section. Mostly 5mm filler 10mm some spots. It's been flapped to bare steel with filler straight over. Quote
piazzanoob Posted September 15, 2021 Posted September 15, 2021 After removing sound deadening in a 80s Toyota myself during the lockdown i didn't find any rust but did found some under the seam sealer as such but its a shit and painful task. i just did it with a sharp chisel and tapped away. tried with heat gun and its easier to get off but leaves much more residue and the fumes really get to your head. was going to do dry ice but now BOC gases have a minimum order of 10kg and require it to be ordered before 12pm the day before for a saturday pickup. and wanted 100 or so dollars. but that's BOC gases for you i then cleaned all the small bits remaining off with chisel and used a brush and rags with petrol and works well. Quote
tortron Posted September 28, 2021 Posted September 28, 2021 i reckon you could cut that bit of the carb casting off, depnds whats under it, looks like a blanked off port from the manufacture process, nub it down atleast 1 Quote
Valiant Posted September 29, 2021 Posted September 29, 2021 Can you not cut the engine cover and re weld it? Quote
Jeffs_Emporium Posted September 29, 2021 Posted September 29, 2021 I could but it's the seatbelt mount and seat mount landing on it that makes me afraid regarding certification 1 Quote
cletus Posted September 29, 2021 Posted September 29, 2021 Is dropping the carb side of the engine down a bit and raising the other side an option? 1 Quote
Jeffs_Emporium Posted September 29, 2021 Posted September 29, 2021 I have tried that and my gearbox mount was thanking me but it pushes the end of carbs back to the sheet metal between engine bay and battery (reason why I had 10mm taken off the carb manifold) I think I will push on as if it does fit, complete wiring, get it started up and make sure everything else is fine and then with a bit of luck a floor shifter van will be at pickapart or something otherwise drop the lid off somewhere that can reproduce it with the space I need to certification spec. 1 Quote
Jeffs_Emporium Posted September 30, 2021 Posted September 30, 2021 If the section outlined in pen is raised to match the section the rail sits on it will work 2 Quote
4age 20v liteace Posted November 4, 2021 Posted November 4, 2021 Malaysia Toyota liteace km36 swap 4age 20v blacktop 2 Quote
