dmulally Posted January 30, 2024 Posted January 30, 2024 5 hours ago, cubastreet said: Always been happy with my XA welders. You can borrow for a hoon if you like. Probably over ten years old now, but similar to this one maybe. https://tradezone.co.nz/welding/razorweld-mig200-mig-mma-inverter-welder-package-200a-230v-single-phase-c-w-3mtr-mig-torch-arc-set-4m-regulator Ta. Looks like they are sold from that tool shop just past ITM in Masterton. Quote
mjrstar Posted January 30, 2024 Posted January 30, 2024 I have the older model of that XA200, which has been faultless for 10+ years now.. 1 Quote
Raizer Posted January 30, 2024 Posted January 30, 2024 Keep an eye on SCA for XA welders, they clearanced out all Cig stock a few months ago and I've just seen my local has stocked up with Xcel-Arc accessories, asked and they said they'll have welders etc soon. 1 Quote
Dudley Posted January 30, 2024 Posted January 30, 2024 Can confirm xcel arc welders fuckin hisssssssssss 1 Quote
dmulally Posted March 9, 2024 Posted March 9, 2024 Finally got into my local welding supply shop today and was about to pull the trigger on an Xcel-Arc but thought I'd ask the brains trust first. My current mig is a transformer one. The two I have narrowed it down to are a 200amp transformer one for $2300 and an 180amp inverter variant for about $1200. The last inverter mig I had shat the bed just after warranty ran out and it was unrepairable. Hence going back to a 30yo transformer mig which has served me well but is getting a little long in the tooth now. Anybody got any opinions on either? I don't need to transport it so I don't care about weight. Just reliability and doing a good job. Quote
Bling Posted March 9, 2024 Posted March 9, 2024 Might have just been bad luck? My inverter welder must be ~10 years old now, doesn't get thrashed but has always done a good job for me on MIG stuff. Aren't both those inverter? Might have wrong link posted. 1 Quote
cubastreet Posted March 9, 2024 Posted March 9, 2024 Not sure if it's in my head, but I seem to get cleaner welds and less spatter from inverter mig. They even weld nice and clean on pure co2, I'm currently using argoshield but it doesn't seem any better whereas transformer migs seem to weld cleaner with argon in the mix. You don't have the huge inrush current needed to saturate the transformer core with electromagnetics either so they're easier to run off generator or inverter. 1 1 Quote
dmulally Posted March 9, 2024 Posted March 9, 2024 39 minutes ago, Bling said: Might have just been bad luck? My inverter welder must be ~10 years old now, doesn't get thrashed but has always done a good job for me on MIG stuff. Aren't both those inverter? Might have wrong link posted. That has to be a typo on the heading surely. A 60kg inverter welder? Is that a thing? Old mate in the shop said it was a transformer and it looks like one. Quote
cubastreet Posted March 9, 2024 Posted March 9, 2024 https://www.xcelarc.nz/wp-content/uploads/2019/08/XA-MIG200WRZ-K_-Info-Sheet.pdf It's an inverter, I don't think I've seen a multiprocess transformer welder. MIG needs constant voltage and TIG constant current and that's easier with electronic trickery. 1 Quote
dmulally Posted March 9, 2024 Posted March 9, 2024 I wonder what causes it to be that much heavier. Even accounting for 10kg difference in spool size. Might go for the cheaper one. Cheers gents. Quote
westy Posted March 9, 2024 Posted March 9, 2024 The Viper is the home workshop line and the Razor is the commercial grade. 57 kgs must be a mistake. My 205 ss is 18 kgs. 1 Quote
rusty360 Posted March 9, 2024 Posted March 9, 2024 We just brought one of these for a portable for work, ill try and give it a hoon next week and report back. We have there AC/DC tig and it's awesome 1 Quote
rusty360 Posted March 9, 2024 Posted March 9, 2024 Just now, rusty360 said: We just brought one of these for a portable for work, ill try and give it a hoon next week and report back. We have there AC/DC tig and it's awesome 3 Quote
dmulally Posted March 17, 2024 Posted March 17, 2024 Ended up getting the floor model which has been superseded for a hefty discount. I gave it a quick whirl and the welds come out very smooth indeed. I have a bit of panel work to do on some thin stuff so I'll see how it likes that. Thanks for the hot tip, gents. 4 Quote
NickJ Posted March 17, 2024 Posted March 17, 2024 3 minutes ago, dmulally said: Ended up getting the floor model which has been superseded for a hefty discount. I gave it a quick whirl and the welds come out very smooth indeed. I have a bit of panel work to do on some thin stuff so I'll see how it likes that. Thanks for the hot tip, gents. Oooh, I have the same Cebora, any chance the front panel writing is still visible, wouldn't be able to put up a picture if it is? Mine is all worn off. Good enough machine but now just a heavy trolley for the tig Quote
dmulally Posted March 17, 2024 Posted March 17, 2024 1 hour ago, NickJ said: Oooh, I have the same Cebora, any chance the front panel writing is still visible, wouldn't be able to put up a picture if it is? Mine is all worn off. Good enough machine but now just a heavy trolley for the tig I'm using mine as a trolley too. Does this work for you? Quote
NickJ Posted March 17, 2024 Posted March 17, 2024 55 minutes ago, dmulally said: I'm using mine as a trolley too. Does this work for you? Hell yes! Yours has the spot timers which mine doesn't but the article number has now given the right search term to finally get a wiring diagram, epic! Thanks heaps! 2 Quote
Geophy Posted March 25, 2024 Posted March 25, 2024 On 03/09/2023 at 17:10, Nominal said: 0.9 is a weird size too, mainly gasless wire? 0.9mm is quite a common compromise wire size. Do alot of solid core mig at work and its my go to for a little bit of everything. Would have gone through over half a ton of it over the last 3 years. I do find its quite lacking at anything big but if I do have 10 and 12mm work to do ill chuck a roll of 1.2mm on for the occasion. 0.9mm can do comfortably about 2mm to 8mm with correct prep all day. 3 Quote
cubastreet Posted March 26, 2024 Posted March 26, 2024 When I was at tech, some rep brought in a roll of Flux core wire that also used shielding gas. It's party trick was the beautiful welds in all positions even with me holding the torch. Anyone know this voodoo wire? Quote
tortron Posted March 26, 2024 Posted March 26, 2024 5 minutes ago, cubastreet said: When I was at tech, some rep brought in a roll of Flux core wire that also used shielding gas. It's party trick was the beautiful welds in all positions even with me holding the torch. Anyone know this voodoo wire? gas-shielded flux-cored wires. https://www.thefabricator.com/thewelder/article/consumables/all-about-gas-shielded-flux-cored-arc-welding-wires 1 Quote
