So I was browsing TradeMe one night and came across this, which I eventually won the auction for a measily $1000. I've always wanted one, but finding one in this condition is hard as most of them ended up in the junk yards over a decade ago.
Introducing my 1991 F26A Diamante 30R-S. This particular example is NZ-new and is one of the few that were specially ordered already built up from Japan, as opposed to the Australian assembled Magna/V3000, or the used Japanese import models that came flooding in a few years later. Being an F26A it misses out on 4WS, it also doesn't have a sunroof, rear wiper or half as many electric gizmos as the JDM 30R-SE does. Oh, and it's AWD with a 3.545 viscous LSD rear end which makes it that extra bit special. You can definitely see where it's a stretched and widened E39A platform (firewall, strut towers, front subframes etc) but you can also see some key GTO parts in there too (V6 drivetrain, rear subframe/trailing arms, brakes).
My short term plans are to tidy it up and complete a bit of a restoration finding the original OEM wheels (or similar) as those Reflex's have to go! My long term plan is to swap in a 6G74 3.5L bottom end with some MIVEC 30M heads that I have, and possibly twin turbo conversion with 5 or 6 speed manual gearbox - but this will be a pipe dream for a while no doubt as I'm still living in Canada. My first steps are to fix up a broken exhaust and get it down to my parents place in Taumarunui.
Feel free to discuss my failings!
  • Replies 75
years ago I had a later model black 2nd gen 30M diamante, it wasn't a bad old barge went semi hard (for what it was), perhaps a bit ahead of it's time being mid 90's with a 5 speed tiptronic  trans. (i think my 2004 wagon still has a pretty similar trans too)
Interior of your machine looks pretty similar to how I remember mine.
I had a jdm 2.5 also. Was an amazing car. It was one car I regret selling. Looked like the black one above.
Good luck with it. It looks like its worth keeping
Must have been an expensive car when it was new?
My dad had a 2.6 povo spec one for a company car. I think it was the first car dad did a max speed run with me
Apparently it was over $90k when new (which I find hard to believe myself!) The previous owner's brother bought a GTO brand new but found it impractical so traded it in some months later on this.
The 2.6L Magna is so weaksauce compared to the Diamante - 120hp vs 220hp, beam axle rear suspension vs multilink (for JDM FWD) or double wishbone for AWD, shit Aus built low quality interior etc. The 1st gen Magna I had in Aus was noticeably not as well built as the JDM or even Todd built Galant/Sigma equivalents I had in NZ.
Saw this on Trademe too, as a typical Mitsubishi foamer I, had too take a noesy at the listing. I have always liked the shape of the early 90s Diamante's. There ain't no 30R-S examples like this around now.
Glad that it has gone too a good home.
Ok now this is where things get a bit more serious.
Myself and Damien just collectively bought this, a flood damaged 1992 GTO twin turbo - he wants the engine and I want the rest of the driveline. It has all I need to convert to 5 speed manual (would have preferred 6 speed but they are harder to come by, especially for this price), large 4 pot brakes up front, bigger vented brakes in the rear, larger turbo diff and axles and the 17" OEM wheels which I like the look of. It looks to be lowered too so those struts could be swapped over.
Now I just need to book a trip back to NZ some time soon.
  • 9 months later...
So I finally came back to NZ in December and gave the car a bit of a clean up, found some original 15" wheels (that I probably wont end up using now), and then put it on gen 1 GTO 16" wheels:
Took the 17" wheels off the parts GTO including Enkei alloy spare and extra 17" as spare
Obtained some gen 2 GTO brakes along with the gen 1 GTO front brakes from parts car (rear gen 1 brakes are same as stock Diamante). Also large plenum 380 manifold obtained to modify.
  • 10 months later...
I definitely have a problem.
This one is an Aus assembled but JDM Diamante 30R-SE wagon, so full spec with sunroof, leather, driver's airbag, ABS brakes. It's a higher trim grade than my 30R-S sedan but being Australian assembled it only has a SOHC engine, not as fancy climate control etc etc. It was cheap, and is another oddball so yeah.... had to have it.
