64Valiants 1969 low light kombi
64valiant
@Roman my kit for the front beam has a bunch of extra bolts in it so it can be raised 40mm to add more slamm
i would need to remove the vivid mark of steel out
83130197_2926369447384294_26750415762536
add more steel
82227516_2926369487384290_18539902275137
and weld it all up. you can see the height difference in this image from the bolt holes to the top of the modified one and the one not modified on the other side
82122454_2926369537384285_21283475071120
this is from the company who supplied the kit
  • Replies 138
  • 3 months later...
  • 1 year later...
53 minutes ago, 64valiant said:
Shes been a while now since the engine has been out, hopefully it's like muscle memory when she goes back in the hole.
Order some of these before it goes in, might save 5 minutes next time lol
  • Haha 3
Problem is I had all the tools out on the bench ready to go last couple of times. Since then we have moved and I've had to put them all way.
Can't be to hard. Lest I know none of them had locktight on them haha
1 hour ago, igor said:
Just caught up on the last two years of your build thread. That hammock bunk thing over the driver's position is pure genius.
Yeah she's pretty cool, factory options for them.
Haven't used it yet, hope to get out this winter and use it
  • 9 months later...
17 hours ago, Nominal said:
You seem to be getting good at dropping the engine/box out. Practice makes perfect?
Sweet ride though.
Yeah pretty sweet skill set to have.
Becomes helpful to lest know my car in and out so when it does fall apart I know what to do.
