kurt. Posted November 13, 2016 Share Posted November 13, 2016 Hey guys, just after some advice. This has been driving me crazy. My headunit picks up alt whine. The higher the revs the higher pitch. I've tried Different alt Playing around with founds on alt headunit amp amd battery, I've tried grounding my headunit to my rca I've been to an audio shop and they had no idea, said they could try a lot of things but would be trial and error Whine gets a lot worse when I also charge my phone in cigarette lighter. I'm sick of driving around with a Bluetooth speaker. Please help Car is a 1990 skyline r32 Quote Link to comment Share on other sites More sharing options...
Yowzer Posted November 13, 2016 Share Posted November 13, 2016 Are you running an external amp? Run a new power feed direct from the battery if you haven't already, make sure you have a solid earth direct to the chassis (don't use whatever is in the wiring loom). Trial connecting the ACC supply to the B+ as well. If you are still getting whine then you may have to fit a noise filter, or get a new headunit. Quote Link to comment Share on other sites More sharing options...
Goat Posted November 13, 2016 Share Posted November 13, 2016 Sounds like your ignition leads? you may have non suppressed leads on the car? Or something weird with your coil wiring. 2 Quote Link to comment Share on other sites More sharing options...
morkster Posted November 13, 2016 Share Posted November 13, 2016 Use NGK plugs with R on them? 2 Quote Link to comment Share on other sites More sharing options...
Muncie Posted November 13, 2016 Share Posted November 13, 2016 Coil on plug with these things ? Surprised your having this problem i used to get it 20 years ago in my teenage days shitter. Try another head unit once you have run your power back directly to the battery on your existing one. If your using an amp your RCA leads might not have sufficient shielding or a broken wire internally. Quote Link to comment Share on other sites More sharing options...
nvmyvl Posted November 13, 2016 Share Posted November 13, 2016 is it a pioneer head unit? Quote Link to comment Share on other sites More sharing options...
sleeektoy Posted November 14, 2016 Share Posted November 14, 2016 Have u got suppressors in the alternator and ignition systems? Â https://www.howacarworks.com/accessories/identifying-and-suppressing-radio-interference These are often overlooked but do reduce/remove the electrical/RF interference, especially from the alternator. Â 2 Quote Link to comment Share on other sites More sharing options...
danger Posted November 14, 2016 Share Posted November 14, 2016 Check your 6 Quote Link to comment Share on other sites More sharing options...
sidewaysickness Posted November 14, 2016 Share Posted November 14, 2016 Another problem is running the amp power wire directly beside the rca leads. Usually the whine is only for amp driven speakers though. Quote Link to comment Share on other sites More sharing options...
kurt. Posted November 14, 2016 Author Share Posted November 14, 2016 Hey, thanks for all the helpful replys so far. First I'm running an external amp, pretty sure I've tried removing that and running speakers straight off headunit. Same problem. I've tried a few different head units. A new Bluetooth etc one is a lot worse than my old one that only does cd and radio It's a rb25det so is running cool on plug I believe? My old man suggested suppressors the other day, that's what got me thinking about this problem again. I've played around with a million earths. Headunit to Rca cable new earth on block on alt on battery, Battery is in the boot so Rca and power supply aren't together. Quote Link to comment Share on other sites More sharing options...
chris r Posted November 14, 2016 Share Posted November 14, 2016 What is the alternative like? Charging OK? Blown or fucked diodes could cause hunming Quote Link to comment Share on other sites More sharing options...
flyingbrick Posted November 14, 2016 Share Posted November 14, 2016 Put battery back into engine bay and see if problem goes away Quote Link to comment Share on other sites More sharing options...
SOHC Posted November 15, 2016 Share Posted November 15, 2016 I had a similar problem, it was a bad earth on the altnator to the body, 1 Quote Link to comment Share on other sites More sharing options...
kurt. Posted November 15, 2016 Author Share Posted November 15, 2016 altanator seems iffy. Goes flat if I don't drive every couple of days.but that could also be battery. Is the second alt I've tried. I tried another head unit today(first time in months) and it's doing something I forgot about. When you take the volume down to 0 or change radio station, it makes the sub do a big pop. Quite loud. Does that help at all? Cheers for all the help though guys! Quote Link to comment Share on other sites More sharing options...
SOHC Posted November 15, 2016 Share Posted November 15, 2016 The amp might be shitty? Quote Link to comment Share on other sites More sharing options...
4AGEMAD Posted November 18, 2016 Share Posted November 18, 2016 Im going through the same delema man. My headunits brand new, tried different amps etc I did find my radios earth a bit dogey so fixing that helped but didnt fix it. Im running two amps though and one of my rcas is running beside the power wire from memory so thats one thing for you to check as its a no-no. And i need new rcas so see how it goes Quote Link to comment Share on other sites More sharing options...
SOHC Posted November 19, 2016 Share Posted November 19, 2016 They say earthing the bonnet and exhaust close to the tail pipe can help, also some of those ferrite beeds round the power cables Quote Link to comment Share on other sites More sharing options...
Mof Posted November 19, 2016 Share Posted November 19, 2016 Have u got suppressors in the alternator and ignition systems? https://www.howacarworks.com/accessories/identifying-and-suppressing-radio-interference These are often overlooked but do reduce/remove the electrical/RF interference, especially from the alternator. Did you try this? I thought this would be the answer 1 Quote Link to comment Share on other sites More sharing options...
