xsspeed Posted December 2, 2013 Share Posted December 2, 2013 oops bit late, yeah H1 calc is all about the buildings thermal envelope, you just add some better r value insulation to compensate for single glazing if required. (H1 requirements for insulation is easily achievable too btw) It's not like you have a shit load of glazing anyway. Quote Link to comment Share on other sites More sharing options...
lowlancer Posted December 2, 2013 Share Posted December 2, 2013 In SHGWAG's defence, from BRANZ"For designers to show compliance using the schedule method of NZS 4218: 2004 Energy efficiency – Small building envelope, they are now required to use double glazing in all the climate zones of New Zealand. Because the Building Code is a performance-based rather than a prescriptive code, the use of double glazing cannot be made a mandatory requirement, but its use is recommended as the most cost effective solution to reduce heat loss through windows and the likelihood of condensation forming on the glass. Designers choosing not to use double glazing will need to prove that the single glazing complies with the Building Code through the calculation method or the modelling method of NZS 4218, or by using the BPI method." Quote Link to comment Share on other sites More sharing options...
xsspeed Posted December 2, 2013 Share Posted December 2, 2013 Yeah was going to ask what is awning roof construction material? calculation method is easy btw, with such little glazed area I'd say this will cruise in. Don't see the point in double glazing in most residential installs tbh (at least coastally on the north island) - such a wasted cost. Plus it means you will need to open windows in summer or fry (or run an AC unit = use more energy) Quote Link to comment Share on other sites More sharing options...
CaMpylobacter Posted December 2, 2013 Share Posted December 2, 2013 roof will = novalite = weedthugs grow area Quote Link to comment Share on other sites More sharing options...
xsspeed Posted December 2, 2013 Share Posted December 2, 2013 greenroof/hothouse you say 1 Quote Link to comment Share on other sites More sharing options...
Testament Posted December 2, 2013 Share Posted December 2, 2013 I hear staining ply can be a bit iffy with it not staining evenly and causing blotches but apparently some prep and good stain product can overcome it. A wood beard would be able to give you the right advice. Can talk to my old man about it he has done stained ply exteriors on 2-3 houses now. although roughsawn finish marine ply I think so maybe a little different. I think the big one with the floor is getting the thing sanded up mint before the polyurethane. maybe a bit easier with ply vs. particle board type stuff though Quote Link to comment Share on other sites More sharing options...
AllTorque Posted December 2, 2013 Share Posted December 2, 2013 Just wondering why you didn't take the dirt away between the drive and the old shed? Quote Link to comment Share on other sites More sharing options...
kyteler Posted December 2, 2013 Share Posted December 2, 2013 That dirt is a nice wee Tree't. 1 Quote Link to comment Share on other sites More sharing options...
SHGWAG Posted December 3, 2013 Share Posted December 3, 2013 Yeah was going to ask what is awning roof construction material? calculation method is easy btw, with such little glazed area I'd say this will cruise in. Don't see the point in double glazing in most residential installs tbh (at least coastally on the north island) - such a wasted cost. Plus it means you will need to open windows in summer or fry (or run an AC unit = use more energy) Yeah, a bit late to the party Steve, previously covered. Quote Link to comment Share on other sites More sharing options...
xsspeed Posted December 3, 2013 Share Posted December 3, 2013 You quoted the wrong post, Mike Quote Link to comment Share on other sites More sharing options...
lowlancer Posted December 3, 2013 Share Posted December 3, 2013 Ooooooooo QS fight is brewing. Throw all the nails you're no doubt counting at each other pls 2 Quote Link to comment Share on other sites More sharing options...
xsspeed Posted December 3, 2013 Share Posted December 3, 2013 I'm not a QS but you shouldn't be insulting Mike's profession - those in glasshouses and all Anywho - trying to be helpful to Manu, so he doesnt have a panic and think he needs double glazing. Still keen to know what awning roof is made from, clear or shaded? 1 Quote Link to comment Share on other sites More sharing options...
Steelies Posted December 3, 2013 Author Share Posted December 3, 2013 yeah keep your QS/etc shit, no disrespect but it rages me out roof is coloursteel, probably green/grey. similar profile to container walls. might go for clear over the deck/verandah to let some valuable light in yes double glazed from the get-go. i'm not that jammy Tara, services will come through the floor and up through internal walls where needed. walls will be built on site. so basically, i have no real idea. Roger, i wanted as much dirt there as possible for trees. also limited in driveway surface for drainage etc. also driveway opening width maximum without getting another consent for it. already have to call the garage a 'workshop' and may need to build a curb in front of it so it doesnt count as vehicle access or some such. but yeah really i wanted to keep that pohutokawa and the other trees which are now gone. /replant idea was to move as little dirt/trees as possible for the job. $$$ and aesthetic etc. 1 Quote Link to comment Share on other sites More sharing options...
rot808 Posted December 3, 2013 Share Posted December 3, 2013 roof will = novalite = weedthugs grow area No doubt there's another container buried underneath this one full of gun magazines for such nicnacs Cameron puhuhuh 7 Quote Link to comment Share on other sites More sharing options...
Steelies Posted December 3, 2013 Author Share Posted December 3, 2013 i'm not here to fuck spiders stephen. 1 Quote Link to comment Share on other sites More sharing options...
My name is Russell Posted December 3, 2013 Share Posted December 3, 2013 Not even the dead ones? Quote Link to comment Share on other sites More sharing options...
Testament Posted December 3, 2013 Share Posted December 3, 2013 manu doesnt fuck, he makes sweet sweet love 1 Quote Link to comment Share on other sites More sharing options...
AllTorque Posted December 3, 2013 Share Posted December 3, 2013 Roger, i wanted as much dirt there as possible for trees. BLOODY TREE HUGGING HIPPIE 1 Quote Link to comment Share on other sites More sharing options...
Steelies Posted December 3, 2013 Author Share Posted December 3, 2013 i'll need the trees to attract delicious native birds, among other city-chicken sources. off the grid zombie survival etc 3 Quote Link to comment Share on other sites More sharing options...
sentra Posted December 3, 2013 Share Posted December 3, 2013 Real gains are had through argon filled Out of curiosity (not a builder), why are all double glazed windows not argon filled? it is not like argon is expensive and seems like it would be pretty easy to seal? Quote Link to comment Share on other sites More sharing options...
