Roman Posted April 23, 2020 Share Posted April 23, 2020 So is that with 2 injector drivers, so in pairs? Quote Link to comment Share on other sites More sharing options...
ajg193 Posted April 23, 2020 Share Posted April 23, 2020 2 hours ago, Roman said: So is that with 2 injector drivers, so in pairs? Yeah, so basically wasted spark of injection Quote Link to comment Share on other sites More sharing options...
Popular Post Roman Posted April 25, 2020 Popular Post Share Posted April 25, 2020 I've been doing some work on making a crude engine simulator, so if I'm using something else that I want to test that has Canbus I can just hook them up to each other and expect similarish results that my engine would give. So it needs an airflow model, so far using these factors to determine how much airflow the engine could potentially be consuming RPM How much air per cyl at 100% VE (And from this and RPM, mass air flow) How max VE tapers each side of max torque RPM based friction losses A potential horsepower number based on Mass Air Flow Then I've modelled a throttle body too, which has a flow rate based on angle. So if the angle allows you to flow more air than what the engine is trying to consume, it stays at 101kpa and the engine can reach its full throttle VE value. But if the throttle is closed further than this, then it shows the number as dictated by throttle angle but also generates a map sensor value. Which then generates a pumping losses number based on MAP and RPM.  So to add more features I basically add more things which potentially take away from max power if they are non optimal. So I still need to make an AFR model, so that you'll make less power as you go further away from peak power AFR. Then make an ignition model which has an ideal ignition number (in milliseconds to 15 ATDC so it generates a fairly sane number across the rpm range) But then has variables to account for different amount of ignition needed when you run richer or leaner, or less engine load. Then from there, I'll make a road load simulator where the car is requiring a varying load as it travels along ups and downs. So the simulation of cruise control is a bit more accurate as in real life the test conditions go out of bounds a lot if the road gradient changes too much across the course of a single test. So obviously this wont be a 100% accurate simulation of my engine or any other engine. But it will react to changes in hopefully a similar way a real engine does, and be capable of being tuned like a real engine does. The eventual idea is that I'll be able to test and troubleshoot my cruise control ignition trim system using this instead of needing to drive the car every time I need to test something. So this virtual motor will have an ideal ignition table which I currently dont even know what it is. But it will be my other things job to figure that out. This will be able to whizz through 1000s of iterations much faster than how it can process in real time when you're waiting for fuel samples to generate and conditions to stabilize. So hopefully I'll be able to get a fairly decent starting point back in the car without too much in the way of bugs or troubleshooting.  12 Quote Link to comment Share on other sites More sharing options...
Yowzer Posted April 25, 2020 Share Posted April 25, 2020 Neat! Quote Link to comment Share on other sites More sharing options...
Willdat? Posted May 5, 2020 Share Posted May 5, 2020 Has anyone done small engine EFI? I enquired with Ecotrons and they want US$1599 for a kit suitable for my FT500, Aliexpress has a similar looking kit for about 1/3 the price from the Super Turbo store which is a lot more appealing. Quote Link to comment Share on other sites More sharing options...
yoeddynz Posted May 5, 2020 Author Share Posted May 5, 2020 12 minutes ago, Willdat? said: Has anyone done small engine EFI? I enquired with Ecotrons and they want US$1599 for a kit suitable for my FT500, Aliexpress has a similar looking kit for about 1/3 the price from the Super Turbo store which is a lot more appealing. Pm sending... 1 Quote Link to comment Share on other sites More sharing options...
chris r Posted May 17, 2020 Share Posted May 17, 2020 so I've found a cheap ems stinger on facebook which has nudged me in the direction of injecting the 202. I know tbi or single point injection is shit but its less shit than a carb. Will be keeping a eye out for a EA falcoon TBI module. Any suggestions on alternative tbi units? The other option would be figure out how to mount 3 individual injectors on the runners without looking like shit 1 Quote Link to comment Share on other sites More sharing options...
shrike Posted May 17, 2020 Share Posted May 17, 2020 @chris r know anyone with a 3dprinter? Get a space plate made with injector bosses in it along with points to mount a rail onto Quote Link to comment Share on other sites More sharing options...
kyteler Posted May 17, 2020 Share Posted May 17, 2020 The problem with that is the 202 is non crossflow so the intake and exhaust share clamping forces, if you were to make a spacer plate it would have to be for all of the ports so likely need to be steel but then would potentially increase the probability of leaking due to increased bolt length requirements. It would also be a massive ballache to install.   1 Quote Link to comment Share on other sites More sharing options...
chris r Posted May 17, 2020 Share Posted May 17, 2020 @shrike the issue with using any (cheap) 202 9 port manifold is the third runner is mega short and gives zero room for a injector let alone a fuel rail. I'd need to chop and do a forward facing plenum or similar   Quote Link to comment Share on other sites More sharing options...
yetchh Posted May 17, 2020 Share Posted May 17, 2020 https://sonicinjection.com.au/product/sim002-holden-9-port-efi-intake-manifold/ Quote Link to comment Share on other sites More sharing options...
chris r Posted May 17, 2020 Share Posted May 17, 2020 21 minutes ago, yetchh said: https://sonicinjection.com.au/product/sim002-holden-9-port-efi-intake-manifold/ oooh thats nice! Pity its about 700 dollars over budget hah  I could butcher a stock manifold and use some of this https://www.aliexpress.com/item/32902865173.html?spm=a2g0o.productlist.0.0.42836db8U7fNTJ&algo_pvid=8943ecd3-dfd3-4b56-8cdd-5495bc20379a&algo_expid=8943ecd3-dfd3-4b56-8cdd-5495bc20379a-4&btsid=0ab6d67915896941077311896e58ad&ws_ab_test=searchweb0_0,searchweb201602_,searchweb201603_  Edit #3 Could also go down the hoolly sniper 2 barrel or Fi tech route if I wanted to spend lots lol.   Quote Link to comment Share on other sites More sharing options...
Transom Posted May 17, 2020 Share Posted May 17, 2020 3 hours ago, chris r said: so I've found a cheap ems stinger on facebook which has nudged me in the direction of injecting the 202. I know tbi or single point injection is shit but its less shit than a carb. Will be keeping a eye out for a EA falcoon TBI module. Any suggestions on alternative tbi units? The other option would be figure out how to mount 3 individual injectors on the runners without looking like shit Read my comments a few pages back re ems stinger but if you buy one I have a whole stinger v4 a very short loom and a brand new long loom and new ford wasted spark 6 cyl coil pack + a Bosch 4 plug narrow/wideband that the stinger can read directly - yours for cheap if you go down that rabbit hole also a laptop old enough to read the help files and a serial connection 2 Quote Link to comment Share on other sites More sharing options...
chris r Posted May 17, 2020 Share Posted May 17, 2020 Just now, Transom said: Read my comments a few pages back re ems stinger but if you buy one I have a whole stinger v4 a very short loom and a brand new long loom and new ford wasted spark 6 cyl coil pack + a Bosch 4 plug narrow/wideband that the stinger can read directly - yours for cheap if you go down that rabbit hole also a laptop old enough to read the help files and a serial connection What are you wanting for that lot? My plan initially was tbi and a Honda ignitor (becaue I've got lots of them) driving a dumb coil bank through the stock dizzy. Or I have also got a est dizzy so can connect that either directly to the ecu or through a gm hei module (and use that for coil control too) I'm very aware wasted spark and sequencial injection is muuuch better. At the end of the day it's a crappy holden 6 and the heads/intake manifolds are garbage for flow so I'm unlikely to benefit from sequencial injection or wasted spark and I'd like to keep it as stock as possible in appearance because barry  I do have access to a xp laptop with serial port so that'll work well enough for what I need Quote Link to comment Share on other sites More sharing options...
Transom Posted May 17, 2020 Share Posted May 17, 2020 200 entire package + courier ? / negotiable Long loom cost me over that Have had ecu live and tracking crank trigger then got to no spark/ prob ignitor issues and gave up went coil on plug and link so no guarantee on whether the ecu is fully functional... Dell Laptop has the ems software and basemaps on it -not sure if there is a Holden 6 map on there  dead battery just plugged it in to my hp cord 2 Quote Link to comment Share on other sites More sharing options...
chris r Posted May 22, 2020 Share Posted May 22, 2020 Not quite diy level because (not my racecar) Set up is link g4+ storm. Vss wired up and Canbus to a dash (dash to be purchased). We want to know fuel used over x distance so can calculate fuelling levels prior to stage so its not over full and sloshing around and stinking We are wondering if there is any option of a fuel used over x distance or even a average fuel usage over a trip time function that the link can do? Or would that all be on the dash side of things. Would prefer not to fill tank then do 100km of touring, then 100km of rally pace to get data  Quote Link to comment Share on other sites More sharing options...
nzstato Posted June 16, 2020 Share Posted June 16, 2020 Think I've only been able to read through 50% of the thread but this is gold.... I'm going to do some logging/tuning on my boat and need to hook up a wideband. Jetties have advised the only way to really do this in marine manifolds is to drill/tap right next to a single exhaust port where it's not water jacketed. Realistically a widebands only going to be there during the period where I need to log/tune, I'll have it running open map 99% of the time. What problems am I going to run into? Will the AFR be bias lean/rich, how will heatsoak affect numbers? I'm sure the sensor wouldn't last too many hours to be left in that position anywho. Quote Link to comment Share on other sites More sharing options...
Yowzer Posted June 16, 2020 Share Posted June 16, 2020 Can you shove it through the rubber Flexi? Quote Link to comment Share on other sites More sharing options...
nzstato Posted June 16, 2020 Share Posted June 16, 2020 Just now, Yowzer said: Can you shove it through the rubber Flexi? She gets pretty wet in there.... Quote Link to comment Share on other sites More sharing options...
Yowzer Posted June 16, 2020 Share Posted June 16, 2020 Oh yes, of course hahha Quote Link to comment Share on other sites More sharing options...
