Spencer Posted June 9, 2016 Share Posted June 9, 2016 No, buy a wideband a re-tune. Quote Link to comment Share on other sites More sharing options...
bigfoot Posted June 10, 2016 Share Posted June 10, 2016 It is on the cards once its running. A 800kg car with leaf springs doesnt need 18psi Quote Link to comment Share on other sites More sharing options...
UTERUS Posted June 10, 2016 Share Posted June 10, 2016 Wat, just turn the boost down and don't accelerate so hard if you don't want skids. Why make more work for yourself? 3 Quote Link to comment Share on other sites More sharing options...
Spencer Posted June 10, 2016 Share Posted June 10, 2016 Yea man just make it work as is, get the rear end sorted if it already isn't. Quote Link to comment Share on other sites More sharing options...
bigfoot Posted June 10, 2016 Share Posted June 10, 2016 Also has semi fucked turbo and only half the intercooler piping. Il get it running n/a then boost later Quote Link to comment Share on other sites More sharing options...
Roman Posted June 11, 2016 Share Posted June 11, 2016 Sort of/maybe. Factory ecu or tunable? Quote Link to comment Share on other sites More sharing options...
kicker Posted June 11, 2016 Share Posted June 11, 2016 Theoretical question coming here: If I were to convert my Cb650 motorbike to fuel injection, could the existing slide carbs be used as throttle bodies? And could a micro squirt handle the revs? (12k redline I think) Â Â I'm sure their manual has the info, I'm too lazy. But you can probably adapt some real nice bike throttles off something EFI and do it way easier, I bought a few sets of bike trottles in the past off ebay (US) for a couple hundy each. They came with TPS and injectors mounted in them which if you can find some with the correct spacing (should be easy, you have some leeway with rubber runners etc) makes this a much simpler swap. Â CB650 will be CV won't they? If the butterflies are used as the throttle what do you do with the slides? I'd be tempted to use some efi jobbies as Spence said Quote Link to comment Share on other sites More sharing options...
bigfoot Posted June 11, 2016 Share Posted June 11, 2016 Sort of/maybe. Factory ecu or tunable? Tunable. Its a stinger ems Quote Link to comment Share on other sites More sharing options...
Transom Posted June 11, 2016 Share Posted June 11, 2016 Tunable. Its a stinger ems  this is relevant to my interests- DIY EFI gurus ... tell me all about stinger EMS v4 Quote Link to comment Share on other sites More sharing options...
Transom Posted June 11, 2016 Share Posted June 11, 2016 looking for an easy cheap way to do ignition for v6 wasted spark - thinking of the std mazda/ford 6cyl wasted spark coilpack    running one of these as an ignition module its from a mitzi v3000 v6   three inputs three coil outputs tacho ground what would the terminal marked "VB" be for  EMS has 4 ignition outputs - i want to run v6 wasted spark off 3 outputs is this the way or are there better options??   Quote Link to comment Share on other sites More sharing options...
yoeddynz Posted June 11, 2016 Author Share Posted June 11, 2016 For your V6 setup you could try running the whole stock ecu and sensors etc. I reckon that even with short runners and the varis system not in place it will still probably be pretty good.  If I do end up making a manifold for you we can try to get the runners as long as possible and then see how far off they are from the factory 'short' runner length. The Mazda ECU will probably adjust fueling to suit.  But I might be wrong...im still learning heaps. Quote Link to comment Share on other sites More sharing options...
Transom Posted June 11, 2016 Share Posted June 11, 2016 No room for distributor = no can use mazda stock efi so thats out the window Stinger seems to be setup to play nicely with stock sensors Can buy the 36-1 wheel pulley off later 626 cheap as  If i cant get the ems stinger to work it will be link atom or ms3 Quote Link to comment Share on other sites More sharing options...
Yowzer Posted June 11, 2016 Share Posted June 11, 2016 I'm pretty sure DIYautotune do a plug n play MS for those engines Quote Link to comment Share on other sites More sharing options...
Transom Posted June 11, 2016 Share Posted June 11, 2016 Yes they do but it's for the distributor version in a ford probe or 626 So a pnp won't work in a conversion Quote Link to comment Share on other sites More sharing options...
Yowzer Posted June 11, 2016 Share Posted June 11, 2016 Ah yep I thought it was MS3 based. They only make the MS3 PNPs for the MX5s, which is a bit lame. Quote Link to comment Share on other sites More sharing options...
Yowzer Posted June 11, 2016 Share Posted June 11, 2016 Actually you could use it as it gives you 4 spark outputs. Quote Link to comment Share on other sites More sharing options...
Transom Posted June 11, 2016 Share Posted June 11, 2016 I'm a bit beyond a pnp system now -my old engine loom and ecu and ecu plug went to a better place in maxteds b1600 Have heard odd things about using pnps on things beyond their design I have whole v6 loom sensors and ecu but the no room for dizzy makes it easier to start from scratch So anyone run an ems stinger? Or tried a mitzi v6 3 channel ignitor rather than using 3x single ignitors? Other option is to use the EDIS System but I don't know if the stinger will play nicely with that Quote Link to comment Share on other sites More sharing options...
yoeddynz Posted June 11, 2016 Author Share Posted June 11, 2016 I just used a mitsi gtslow coil unit and ran my ignitors externally from the MS to keep excess heat plus higher currents external (not that it probably matters)  Holy shit those ems units are spendy. You could buy an MS2 and build it. Its fun, you'll learn heaps and save $500 Quote Link to comment Share on other sites More sharing options...
Transom Posted June 11, 2016 Share Posted June 11, 2016 Got one 2nd hand cheap v4 stinger Cheaper than landing an ms 2 kit Have done lots of old vehicle wiring and high powered RC car electronics but this efi stuff is new to me Quote Link to comment Share on other sites More sharing options...
anglia4 Posted June 11, 2016 Share Posted June 11, 2016 CB650 will be CV won't they? If the butterflies are used as the throttle what do you do with the slides? I'd be tempted to use some efi jobbies as Spence said Nah mine is pre CV 1 Quote Link to comment Share on other sites More sharing options...
