danger Posted April 19, 2012 Share Posted April 19, 2012 5th gear reverse donuts? Quote Link to comment Share on other sites More sharing options...
KKtrips Posted April 19, 2012 Share Posted April 19, 2012 Different g/box or are you flipping the crownwheel? Quote Link to comment Share on other sites More sharing options...
fuel Posted April 19, 2012 Share Posted April 19, 2012 Quote Link to comment Share on other sites More sharing options...
peteretep Posted April 19, 2012 Share Posted April 19, 2012 shits looking awesome, i dont want to hear that this got too hard Quote Link to comment Share on other sites More sharing options...
Spencer Posted April 19, 2012 Share Posted April 19, 2012 This makes me want a racecar instead of a restoration lol, good shit dude Quote Link to comment Share on other sites More sharing options...
My name is Russell Posted April 19, 2012 Share Posted April 19, 2012 More details of plans please Looking good! Quote Link to comment Share on other sites More sharing options...
Truenotch Posted April 19, 2012 Share Posted April 19, 2012 Awesome. Gearbox? Quote Link to comment Share on other sites More sharing options...
mikuni Posted April 19, 2012 Author Share Posted April 19, 2012 Different g/box or are you flipping the crownwheel?Flipping crown wheel. I need to enlarge the diff housing and probably run a smaller clutch on a custom flywheel. But it's not too bad really considering the other options to ensure I don't have 5 reverse gears.So far I haven't run into any deal breakers, just a few slight issues. I'll list a few things so people don't need to ask. Firewall - cut away Gear shift - convert to cable Mounts - rear of the engine lines up perfectly with subframe, front I'll have to run a little crossmember but should be straight forward Steering - this used to be on the firewall, so it's long gone.. along with the power steering that was on the "front" of the engine. I'm going to run a non-powersteer rack with an adjustable EPA if required Chassis - have cut away, will reinforce with plate steel where I can, as per SS2000 rules (I can't go tubular/space frame) and will tie suspension and subframe into the cage to strengthen - I have an onto-it engineer helping me with fabrication/cage, so I'm not going it alone on the tricky stuff Exhaust - it's going to be so sweet, no longer need to go under or around the engine, just straight down the firewall and out the back/side Intake - this is probably going to be the biggest issue initially and may mean a custom ITB setup right away, which I was hoping I wouldn't have to do due to cost/difficulty. This will set me back 6 months or so if I can't get it running on factory setup. Then there's still suspension, cage, interior, windows, etc etc etc to figure out, but that will all happen in time.. hopefully.. Quote Link to comment Share on other sites More sharing options...
Truenotch Posted April 19, 2012 Share Posted April 19, 2012 Makes sense. going to use the trailer guards? They're nice and strong. Quote Link to comment Share on other sites More sharing options...
xsspeed Posted April 19, 2012 Share Posted April 19, 2012 Oh my Quote Link to comment Share on other sites More sharing options...
durty Posted April 19, 2012 Share Posted April 19, 2012 Love it man. Can't wait for more progress Quote Link to comment Share on other sites More sharing options...
chees- Posted April 19, 2012 Share Posted April 19, 2012 Quote Link to comment Share on other sites More sharing options...
drtdvl Posted April 19, 2012 Share Posted April 19, 2012 Intake - this is probably going to be the biggest issue initially and may mean a custom ITB setup right away, which I was hoping I wouldn't have to do due to cost/difficulty. This will set me back 6 months or so if I can't get it running on factory setup. Why? Quote Link to comment Share on other sites More sharing options...
Spencer Posted April 19, 2012 Share Posted April 19, 2012 Aftermarket ECU and the $$ I would guess?? Quote Link to comment Share on other sites More sharing options...
drtdvl Posted April 19, 2012 Share Posted April 19, 2012 i mean as in the biggest problem... why is it a big problem? Quote Link to comment Share on other sites More sharing options...
Spencer Posted April 19, 2012 Share Posted April 19, 2012 Sets him back 6 months getting the ECU money together? I doubt getting them on the car is the actual problem But outboard injectors and a lush plenum sucking aire from behind the grill plz Quote Link to comment Share on other sites More sharing options...
Simon Posted April 19, 2012 Share Posted April 19, 2012 Slide throttles with outboards would make lots of This is an epic task. Like mine, everything is easily possible. It's just getting it done is so tedious haha Quote Link to comment Share on other sites More sharing options...
mikuni Posted April 19, 2012 Author Share Posted April 19, 2012 i mean as in the biggest problem... why is it a big problem? The engine leans forward about 7° in it's original position, meaning the intake sits higher at the back of the engine bay. When I spin the engine around and lift it up, the intake now sits even higher but is now on the side of the engine bay where the bonnet slopes down. I'm still retaining the same 7° lean of the engine so that I don't have to modify the sump also. So I'm anticipating issues with trying to retain the factory intake, and even if I go to ITB's it will have to be a well thought out design to make everything fit. I would like to get a lower, wider radiator and run the intake into the grill as Spencer suggests. I kind of need a new radiator anyway, because I've switched the in/out around the opposite way for the existing one. It's all of these little things that add up and begin to make it a massive undertaking. Slide throttles with outboards would make lots of Slide throttles are dumb everywhere except wide open and even then offer little to no gain. Just sayin' Quote Link to comment Share on other sites More sharing options...
Vintage Grumble Posted April 19, 2012 Share Posted April 19, 2012 After all this, the engine is still going to be in the wrong way ............ Shits awesome Sir, shits awesome. Quote Link to comment Share on other sites More sharing options...
sheepers Posted April 19, 2012 Share Posted April 19, 2012 I do feel I've taken on a little more than I can manage, but I'm having a lot of fun with it. everyone in the whole world, read the above and learn from it. take on more than you can manage, do it often. sometimes it might not work out perfectly but you'll be better for it every time. Quote Link to comment Share on other sites More sharing options...
