Truenotch Posted November 25, 2013 Share Posted November 25, 2013 You can definitely pedal the thing though. I'm impressed that you're able to skid the last corner in it's entirety! Shame about the twack, but that shit happens. Get to work because I really want to see this at Drag day . Quote Link to comment Share on other sites More sharing options...
kpr Posted November 25, 2013 Share Posted November 25, 2013 don't worry it'l make it. may not look too pretty though! Quote Link to comment Share on other sites More sharing options...
Stu Posted November 25, 2013 Share Posted November 25, 2013 I hope you used the Safari and a chain to straighten it? Quote Link to comment Share on other sites More sharing options...
kpr Posted November 25, 2013 Share Posted November 25, 2013 That was the first thing that came to mind, hook the pto winch on!. luckily had to drop it off early that morning. retaining wall, some carefully placed eyes welded to the front of car and some h/d tie downs, worked mean Quote Link to comment Share on other sites More sharing options...
Stu Posted November 25, 2013 Share Posted November 25, 2013 And some sledge hammer work to feather out the dents? Quote Link to comment Share on other sites More sharing options...
mjrstar Posted November 25, 2013 Share Posted November 25, 2013 If you are consideing a COP setup I think either the 1NZ corolla coils I used in my evo or the K20 coils finding thier way into the my Mazda build Could be suitable contenders... the K20 coils are a tad longer but fairly similar other than that... Quote Link to comment Share on other sites More sharing options...
Furai Posted November 25, 2013 Share Posted November 25, 2013 Was the most disheartening thing seeing you hit the wall in my rear view mirror. Quote Link to comment Share on other sites More sharing options...
kpr Posted November 26, 2013 Share Posted November 26, 2013 Yeah It looked pretty retarded on the in car vid too! ah well its not hard to fix. just having to respray pretty much the whole front of the car, is annoying. mjrstar: yeh i think the 1nz stuff works with 4age. i just happen to have a corolla here i can pinch some off for a test fit. but can't see it happening anytime soon Quote Link to comment Share on other sites More sharing options...
Escorto. Posted November 26, 2013 Share Posted November 26, 2013 I was there watching. A few mates had entered. Was a good day. Your kp went way better then the 4agze turbo one. Did I see you make it all the way over the hill once? Quote Link to comment Share on other sites More sharing options...
ANT Posted November 26, 2013 Share Posted November 26, 2013 Where is the crash incar?+1 for making over hill. Guess high entry speed is key? Quote Link to comment Share on other sites More sharing options...
kpr Posted November 26, 2013 Share Posted November 26, 2013 those last 2 clips, is about as far as i was getting over the hill. pretty much over the other side i guess. its kinda hard in a low power car since the first corner is shaper. it seems more to do with the line, rather than entry speed. can only go so fast before have to srubb off speed or fall off the corner. i was entering the same pretty much all day. but trying to leave the switch later as day went on. entering late on the first corner and hitting the apex later would make it easyer, but boring. The blue kp didnt seem to have much power on me. plus i had more grip. was catching up mid drift when following him. Quote Link to comment Share on other sites More sharing options...
Roman Posted December 18, 2013 Share Posted December 18, 2013 Oh hello 2 Quote Link to comment Share on other sites More sharing options...
1977jdm Posted January 4, 2014 Share Posted January 4, 2014 The 03's look pretty sharp the tyres aren't bad either haha 1 Quote Link to comment Share on other sites More sharing options...
ANT Posted January 5, 2014 Share Posted January 5, 2014 A motherfucking plus (A+) Gold looks totes amazeballs on a red kp. 1 Quote Link to comment Share on other sites More sharing options...
eke_zetec_RWD Posted January 19, 2014 Share Posted January 19, 2014 Can you match the uj angles with a shaft that short and with how low you have it? One option is to make a second shaft with cv joints. Lots of rwd/4x4 cars use them now. Bloke at work made one for his notched hilux. Works mint, but you do need a steel boot protector to stop them expanding and falling apart from high speed loads. Quote Link to comment Share on other sites More sharing options...
kpr Posted January 20, 2014 Share Posted January 20, 2014 should work out pretty good actually. main problem before was matching the angles, rather than the over all angles being too much. the engine and box, had an angle down. so the nose of the diff had to point up. wasn't too far out in the end. but to get it spot on. the front of the engine had to come down. sump ground clearance is already an issue, so that wasn't going to happen. or raise the whole tunnel. also unkeen with the 2 piece, the first section off the box, aims towards the ground slightly. which gives a bit more tunnel clearance for the rear section. only other thing i may have to do, is raise the last 300mm or so of the tunnel to the nose of the diff. to get the diff pointing where it needs to be. Quote Link to comment Share on other sites More sharing options...
eke_zetec_RWD Posted January 20, 2014 Share Posted January 20, 2014 Sweet you have it Sussed! Yea they a cunt to set up, or do you have adjustable 4 link? Quote Link to comment Share on other sites More sharing options...
kpr Posted January 20, 2014 Share Posted January 20, 2014 Has adjustable 4 link now. I did cut and weld the factory arms a few times! no one was spose to know that though.. Quote Link to comment Share on other sites More sharing options...
Stu Posted June 26, 2014 Share Posted June 26, 2014 Swooon Quote Link to comment Share on other sites More sharing options...
oldmatedan Posted September 17, 2014 Share Posted September 17, 2014 Your engineering skills are amazing man!! Some very inspirational stuff in this build thread Love the car mate keep up the top notch drifting too Cool to see a car built not bought and raped also Dan Quote Link to comment Share on other sites More sharing options...
