si
  • Replies 9k
Looking at getting a set of coil overs like these for my x61 but questioning getting cert for them, as its a ?McPherson? setup and the single bolt into the body probably wasn't designed to hold the weight of the whole car through the springs? And can get a set for the front but I'm assuming I would need some sort paper work with them saying they're built to some sort of standard?
Rear setup im looking at:
http://page2.auctions.yahoo.co.jp/jp/auction/b143840667
if that replaces the rear shock ie the weight of the vehicle now goes thru the shock mount- might be possible with strengthening, i havnt seen it done on your sort of car only lighter stuff like starlets, corollas etc.
IMO from what i can see in the pic they look like a bit of a cockup anyway, that spring would coil bind at that adjustment height, looks like lowering the spring platform would result in it being uncaptive so you would need keeper springs, cant see any bumpstops unless they are up in the mount tube thing but then they wouldnt be doing anything.
i dont rate bilsteins much either, i have found a few issues with them
http://i841.photobucket.com/albums/zz340/michael0008/cutty_zpsacb06be9.jpg
http://i841.photobucket.com/albums/zz340/michael0008/cuttystyle_zps60542fa1.jpg
http://i841.photobucket.com/albums/zz340/michael0008/cuttystyle1_zps6b7f67f5.jpg
ok cut the front off like so am i able to do the above (non certificated welder)
any size thin tube steel ok?
and how much are structural cert normally for doing the above?
cheers
Hey man
So, I have bought a length of flat steel to make some loops
but I cant seem to find any real details on what you can and cant do
Can I make the loop in two pieces
and what size bolts?
I have made this diagram to show what I was planning on doing
Blue is the drive shaft
Black is the loop in two pieces
green is the floor
and red are the bolts.
However, this is the plan without having a look under my car
I have another option, as the crown is solid chassis, if i make the loop in two pieces, and bolt halfs together with two bolts, would i need to use to bolts at each end also?
Pink are the chassis rails
And when you say two bolts each side, can they be side by side? as in across the width of the steel as opposed to the length?
Sorry for all the questions
I just want to do the job once haha
and also is this sheet still valid?
http://www.lvvta.org.nz/documents/infosheets/LVVTA_Info_09-2011_Drive-shaft_Safety_Loop_Requirement_Clarification.pdf
As if it is, It would make the mounting of my loop much easier if the length from the universal to the loop is able to be max of 250mm
As 150 is right on a welded in cross member that is not going to work at all
cheers
can be done on a pre frontal impact compliant vehicle
you cant make it weaker, or significantly stronger than it was originally
cost wise, depends on what else is modified and who is certing it, there isnt a set price
Hey man HELLO ALLAN
So, I have bought a length of flat steel to make some loops SPLENDID
Can I make the loop in two pieces YES YOU MAY
and what size bolts? MINIMUM 10MM OR 3/8 BOLTS X4 TO ATTACH A LOOP TO THE VEHICLE, 2 EACH SIDE
I have made this diagram to show what I was planning on doing  GOOD WORK. THE TOP PART OF THE LOOP CAN BE BOLTED OR WELDED TO THE BOTTOM BIT SO YOU DONT HAVE TO DOUBLE UP THE LONG BITS. IF YOU ARE BOLTING DIRECTLY TO THE CHASSIS YOU COULD HAVE THE BOLTS SIDE BY SIDE BUT IF YOU ARE GOING THRU THE FLOOR THEN SPACE THEM APART A BIT MORE. IF YOUR CHASSIS RAILS ARE FAR APART OR LOW TO THE GROUND I WOULD BOLT IT TO THE FLOOR,THE SHORTER THE WHOLE THING IS THE STRONGER IT WILL BE. USE A 100X50 PIECE OF STEEL TO MAKE A 'WASHER' LIKE IN YOUR DIAGRAM AND ALL WILL BE JUST SWELL.
green is the floor
It is still valid, if you have a 2 piece shaft then its usually no good because they are short sections, the loop needs to be at the front of the shaft. that 150mm measurement is only the MAX distance from the u-joint, you can go closer to it, that might make it easier?
Oh having a look at the under side of the car it is still very much forward of the center point of the shaft
and with the design I will have, the drive shaft wont drop lower than the chassis rails anyway
thanks mate :)
Edit, also clint
you were in a dream I had last night
Along with the QCR
Steelies
and assorted other OS members
Was very good dream
Is it legal to modify the mounting points on a set of struts, like I want to remove (cut off) the lower part of my OEM shock where it bolts to the knuckle and weld it to another shock.
If it is allowed then would it require a cert (if it was obvious enough to get picked up).
It may sound odd but it's the simplest option in my situation.
Cool, if I do get to this point I'll hunt out a set of hubs and see what kinda meat is behind there.
I'm guessing the general rule is 'Not allowed to be thinner than it is where the studs are meant to be?'
Cause I'm pretty sure it is.
