westy Posted September 1, 2022 Share Posted September 1, 2022 Can a front chassis arm/leg thingie be massaged slightly for clearance to air conditioning pump or similar? It’s a ‘96 bmw 328. This is frontal impact age? Quote Link to comment Share on other sites More sharing options...
AllTorque Posted September 1, 2022 Share Posted September 1, 2022 Frontal impact is from 1999, but I would fail due to 1. a) https://vehicleinspection.nzta.govt.nz/virms/in-service-wof-and-cof/general/vehicle-structure/structure-incl2.-frontal-impact Quote Link to comment Share on other sites More sharing options...
datlow Posted September 1, 2022 Share Posted September 1, 2022 On 27/08/2022 at 13:58, tortron said: assume they don't send you a bill anyways Lols Death and taxes always Quote Link to comment Share on other sites More sharing options...
tortron Posted September 1, 2022 Share Posted September 1, 2022 22 minutes ago, datlow said: Lols Death and taxes always Reading more it sounds like they do. Pretty rude to cancel for not paying and then demand payment for it. Also it looks like if rego was out and you sell you get sent the bill for that. Pretty funny as I have bought quite a few things with rego nearly about to lapse and the sale price wouldn't have covered it 2 Quote Link to comment Share on other sites More sharing options...
datlow Posted September 1, 2022 Share Posted September 1, 2022 Yeah, but you inherit any owing rucs so gotta make sure they havent fudged the window card Quote Link to comment Share on other sites More sharing options...
tortron Posted September 1, 2022 Share Posted September 1, 2022 Yes I paid very many when I got datds truck 1 Quote Link to comment Share on other sites More sharing options...
westy Posted September 1, 2022 Share Posted September 1, 2022 1 hour ago, AllTorque said: Frontal impact is from 1999, but I would fail due to 1. a) https://vehicleinspection.nzta.govt.nz/virms/in-service-wof-and-cof/general/vehicle-structure/structure-incl2.-frontal-impact You’d probably fail it on the swap to a v8 too ha. But for cert? Quote Link to comment Share on other sites More sharing options...
yetchh Posted September 4, 2022 Share Posted September 4, 2022 Hey @cletus is cutting an extra hole in the side of the engine bay a no no? There is already one there but about 80mm off center for my needs. For intake inlet.. Quote Link to comment Share on other sites More sharing options...
cletus Posted September 4, 2022 Share Posted September 4, 2022 If its a single skin, thru the rad support or the panels forward of the strut mounts then probably OK for cert What car? Quote Link to comment Share on other sites More sharing options...
yetchh Posted September 5, 2022 Share Posted September 5, 2022 Hilux 2wd so on a ladder chassis with no towers.. Quote Link to comment Share on other sites More sharing options...
cletus Posted September 5, 2022 Share Posted September 5, 2022 Probably OK but would need to be certified Quote Link to comment Share on other sites More sharing options...
yetchh Posted September 5, 2022 Share Posted September 5, 2022 Yeah thought as much.. Thanks. 1 Quote Link to comment Share on other sites More sharing options...
RXFORD Posted September 7, 2022 Share Posted September 7, 2022 On 05/09/2022 at 14:20, cletus said: Probably OK but would need to be certified That seems a bit silly needing cert for that when rust holes don't need cert. 2 6 Quote Link to comment Share on other sites More sharing options...
Abarth Posted September 18, 2022 Share Posted September 18, 2022 Can brake calliper brackets be made from alloy instead of steel and still pass a cert? Quote Link to comment Share on other sites More sharing options...
cletus Posted September 18, 2022 Share Posted September 18, 2022 Yes, but thickness usually needs to be greater Quote Link to comment Share on other sites More sharing options...
Abarth Posted September 18, 2022 Share Posted September 18, 2022 Sweet cheers Quote Link to comment Share on other sites More sharing options...
Nominal Posted September 18, 2022 Share Posted September 18, 2022 45 minutes ago, cletus said: Yes, but thickness usually needs to be greater Saw an alloy driveshaft loop the other day, was pretty thicc Quote Link to comment Share on other sites More sharing options...
MRWEST Posted September 19, 2022 Share Posted September 19, 2022 Hey @cletus . Mates got a VE Commodore factory LS2 Series 1 car, has done a single turbo and manual conversion on it, is this going to need a cat in the exhaust for a cert? Quote Link to comment Share on other sites More sharing options...
cletus Posted September 19, 2022 Share Posted September 19, 2022 If it's registered in nz prior to 2010, no cat required If it's post 2010 it gets complicated 1 Quote Link to comment Share on other sites More sharing options...
MRWEST Posted September 19, 2022 Share Posted September 19, 2022 57 minutes ago, cletus said: If it's registered in nz prior to 2010, no cat required If it's post 2010 it gets complicated Sweet its a 08 NZ New so allgood. Quote Link to comment Share on other sites More sharing options...
