Showing content with the highest reputation on 12/30/15 in all areas
Discussion thread //oldschool.co.nz/index.php?/topic/51310-rhubarb77s-1970-escort-coupe/ Here's a few recent pics of my Escort that I've owned for the last 5 or so years. I'm the second owner so most of the body and interior is untouched except the RS front end, some gauges, new carpet etc. I first took interest in Escorts growing up in Central Otago. I think my first car, bought for $100 was a MK1 four door with house paint all over it. Lots of gravel roads = lots of great memories So now, 20 years on I have this escort. It took a long time to find the right car as I didn't want to do any bodywork. The current engine, 2.0L Pinto was professionally built at an Escort performance shop here in Queensland. It pushed out 150rwhp on the rollers and runs a 14.5sec 1/4 mile with standard diff and standard Sierra 5 speed. A few weeks ago I stumbled across a custom Pinto turbo exhaust manifold when I was buying some escort spares. So that's kicked off a whole new chapter. I've crunched the numbers for the turbo route and it looks expensive. So my MK2 Escort project will have to go and the 150HP motor is up for sale. Going turbo with the car is going to change it. A lot. Fuel injection, big diff, big brakes etc. I'm in two minds about going ahead with it really as the car is so well balanced & very original. That's partly why I started the thread, to get some opinions about it so please place a vote in the discussion thread. Cheers Turbo project- T28 ball bearing Turbo on custom stainless manifold, Sierra EFI inlet manifold, YB pistons, YB rods, YB distributor, Holden LS1 coils, Toyota Supra W55 gearbox with adaptor bellhousing. Shopping list is still huge.13 points
Have got someone making me some new tie rods which take a factory inner tie rod end, and a commodore outer tie rod end which has the pivot point lower, which should reduce the amount of bump steer. and i went to OS drag day also, big surprise, if you do skids for ages, brake drums dont like it and get shuddery. luckily i have a spare set, put those on today. it did a 14.28 @98mph. it did have a couple of runs where it had a splutter- its either running out of fuel (it has a stock fuel pump) or the lifters are pumping up. i have an old camera that i "improved" the battery door on by bolting a bit of steel to it, which also makes quite a good mount when combined with 3 strong magnets, its interesting to video the suspension and whats going on when you drive it. Quite surprising to see the amount of movement- eg 0.37 there is 2 reasonably heavy applications of brake, you can see the caliper rotating the spindle- this is mostly movement in the brake reaction rod bushes, but the upper arm bushes move as well, and if you study it closely, you can see the whole inner guard deflecting. in this one the camera is mounted to the bumper iron looking back at the left front wheel13 points
im not sure how much longer i can keep this up. 2015-12-30_03-19-36 by sheepers, on Flickr 2015-12-30_03-18-51 by sheepers, on Flickr 2015-12-30_03-18-37 by sheepers, on Flickr8 points
i have used them, best to set your gun on low/1, give it some nungas nungas , then set your torque wrench on like 80 nm, check it and wind it up till you find where its actually torqueing the nut to. and adjust your rattle gun setting to the best position. I did find when I went to a much better quality rattle gun I had to dumb it down to the lowest setting to get the right torque i went away from using them in the end because for my own peace of mind knowing that you torqued the nuts up helped me to sleep at night. especially on them long as days were your doing 14 jobs and you cant get of to dream land cause you cant remember if you did up the nuts on the last rush wheel bearing job. thankfully that has never happened to me, but as i said peace of mind knowing its right was worth the extra 2 mins . I do things the same way every time , so if I haven't put the torque wrench back in the draw I know I haven't torqued the nuts, its a good system, same goes for sump plugs, and brake caliper bolts, all ways put the spanner on the drainer, or ring end on the hub, if the spanner is on the drainer/hub then the plug/bolts aren't tight. I may be a little ocd but I have never left wheel nuts loose or fucked an engine cause the plug fell out . my 2 cents , got a little of topic sorry6 points
Well I am off to Motunau for new years. I was going to take the Anglia but it is not charging. The alternator provides 14.4 V for the first 5 min of running then stops charging. So the work wagon will be towing the teardrop up. It has the spearfishing gear, shotgun, .22 and AK fitted so should be sweet for a fun evening.6 points
Putting a cortina back together isn't as easy as i thought it might be. It's been a month since It came home and its been a battle in almost every respect. It dosent help that my search for perfection gets in the way, making sure every lil bit is cleaned and in mint working order or brand new looking. I know at the end of the day I will sit back with a giant smirk on my face bathing in the glory that is my cortina but even I know I have gone quite insane. Anyway for the fickle few who enjoy my update here she goes. 1.Today I finished my under dash wiring. I have installed some fuses for stereo and need one for main power feed. 2. I have made my rear parcel tray and back seat cover upholstered it my self.looks good. super happy. 3. Put engine in and installed battery and new coil + electronic ignition. Just have to install alternator and sort out radiator and fuel lines. Thanks peps that will do for now.6 points
4 points
Thanks for the comments and compliments guys. It is a great car and the poll results are overwhelmingly in favour of leaving the car the way it is. Thanks for the votes. Brockzila the MK2 coupe is a 1980 2.0GL Denim pack. Not sure if I want to cut this one up either. But if I sell it who knows what would happen to it? It was a bit rough when I first got it. The interior is shagged. I've had a bit of rust cut out & repaired but overall it's a pretty solid car.3 points
I have started fiber glassing the body, it is a lot harder than I thought it would be to go around edges... The first batch had quite a few air bubbles near the 90 degree bends in the cloth, I cut them out once dry and tried again.... I think I have it sorted now though.3 points
rear suspension, from the back of the car looking back at the spring/diff and another one of the front3 points
After a play this afternoon, the engine bay went from this To this guards and front back on, just need to sand and paint the bullbars and do a quick service and it will be ready for re-reg . Oh, and cut the rest of the paint to match the guards.2 points
I love your home vids! How old are your upper arm bushes? I'm amazed how much free castor you get under braking. Also, how hard does it hook up with the rear leaves so flat? And I thought that blocks had to be boxed in at the ends? I couldn't quite see the inner guard deflection you spoke of. Might have to watch those vids more. pretty riveting viewing.2 points
I say big turbo. It stopped being an original car the minute the Pinto went in, so just go the whole hog and turbo the bejesus out of it.2 points
Shit those videos show how much of a hiding factory suspension gets. Might spend a bit more time on my Cedric's going over all the front end!2 points
Hi You could possiably have one of the niceest period modified cars in the country. Please do not take it any further, as you said it took along time to find. You have a mk2 project?? Keep the mk1 as is and drive it. And turbo the mk2 .2 points
this one is looking back at the brake reaction rod, if you watch carefully you can see the front crossmember flexing under braking loads, and the engine moving around under braking2 points
things went well and now its beer o'clock. 2015-12-29_03-58-30 by sheepers, on Flickr 2015-12-29_03-58-40 by sheepers, on Flickr 2015-12-29_03-58-52 by sheepers, on Flickr 2015-12-29_04-13-24 by sheepers, on Flickr 2015-12-29_04-13-39 by sheepers, on Flickr2 points
today was a good day, now it goes again. neighbors may have been wondering WTF i was doing with it sitting in the driveway for 20 minutes at 2000rpm. fired up first crank, runs well and seems quite responsive. took it for a tutu round the block a couple of times. needs a few finishing touches, set timing etc etc, put the bonnet back on, couple of small exhaust leaks. it will need a quieter exhaust, curently has 2 straight thru mufflers (3'') so ill probably put a 2 1/2 triple pass muff right at the back2 points
got the block back, ended up with a bit more doing to it than originally planned. block tanked, bored, decked, rods resized, crank bead blasted and journals polished, all balanced. state of play at the end of today= also, this happened. photography was done by Richard/Snoozin, jolly good show old chap.2 points
Well, the bug bit again. I guess you could also call this thread "I lost my marbles and imported another shitty old car from Japan! Ask me (almost) anything!" Originally I wasn't planning on buying another AW11 for a couple of years... if at all. After owning five of them over the course of the last ten years and getting sick of repairing botch jobs on hacked-up local examples I firmly told myself not to bother anymore unless it was a truly tidy one, which meant most likely having to import one from Japan. Then a series of fortunate events including a career change, the sale of my Mazdaspeed Axela to a family member earlier this year (which freed up garage space and capital), and a strong dollar to yen ratio at the time all led me to engage Ewan from Stacked to check out a few nice looking AW11s on my behalf. Yeah, I'll admit that six months after selling my last AW11 the itch inevitably came back, so I'd been keeping a surreptitious eye on the car sites over in Japan for the last year to see what the market was like! After a few hits and misses I settled on a midnight blue hardtop from a yard near Tokyo called Marumi Auto which had low kms, very little rust, one careful owner, and had been quite well looked after. It wasn't cheap, and blue was never my first choice of colour (I was angling for either a Sherwood tone, white/grey, or white/gold example this time), but for the price nothing in NZ came close in terms of quality and condition, and after owning my last one the colour eventually grew on me. By some stroke of luck, this particular one had been specced with the much more aesthetically pleasing black interior instead of the default eye-watering blue that 99% of the midnight blue cars had! It arrived at Stacked's yard in Osaka around mid-May, having made its way across the country from Tokyo on a transporter, and Ewan made arrangements to load it on a RORO carrier departing in late May. Around the end of June the export certificate and some other documentation arrived, followed by a notification from Stacked's NZ based customs brokers in Tauranga that the car would be arriving on 11th July. The AW11 then spent the next week and a half on the wharf while Customs, MPI, MAF, and Land Transport NZ all poked around and carried out their various inspections in the name of bureaucracy. I was heartened by the fact that during the border check the car wasn't flagged for rust issues nor underbody damage! Then, finally, once all the Is were dotted, Ts crossed, and palms greased in the form of invoices paid, the car left the wharf on a transporter headed to North Shore Compliance and spent a few days there before I drove it a short distance up the road to the panelbeater where it now currently sits, and will undergo further inspection to pass a Repair Cert. Compliance revealed that the left rear quarter had been subject to a minor impact in the past (20 years ago or thereabouts), and because you could still buy replacement TGP panels at the time the entire section had simply been replaced. There are no marks to indicate the chassis had to undergo straightening, there isn't any cancer creeping in around the seams, and all the spot welds look good - but there are a couple of areas where surface rust has started bubbling (the join around the left hand tail light, for example) that will need to be cleaned up once the repair certifier completes his check. I've had very limited time to spend foaming over the car because of other commitments, so it was a nice surprise today to discover that it already sports a set of incredibly rare TRD lowering springs. I'd bid on some in Japan as the car was making its way over here and just barely lost the auction, so had been feeling a bit despondent about ever finding another set. So where to from here? I'm not all that interested in making the AW11 stupidly fast, but will eventually perform a few judicious tasks such as sprucing up the suspension further, now that I know it has TRD springs (some good Bilstein struts and a rear swaybar would be nice), adding a LSD, fitting a set of extractors I did manage to win ex-Japan, transplanting a few bolt-on bits I'd hung onto after selling the first '80S KID, and tidying up all of the little interior and exterior blemishes I come across. May even pull my Buddyclub P-1s out of storage, paint them a nice shade of bronze, and fit them to the car, and also hit up Yahoo Japan for any oddball accessories such as driving lights and roofracks that might pop up. Still undecided whether I want to go for a full period-1980s look similar to what I'm planning to do with squid (my Skyline sedan) but overall I'm hoping for a nice "clean-slate" build - not concourse spec but tastefully tidy and done up without a hundred things wrong or fucked with! Stay tuned for more. Discuss: //oldschool.co.nz/index.php?/topic/49412-80s-kid-part-ii-eds-aw11-sc-chit-chat/1 point
Right. not sure if this should be in here or in other projects. I'm sure the mods will move it if it doesn't belong here. After the sale of the family farm in Kaikoura , I managed to get the farm ute . So last weekend my good lady and I shot up on Sunday and picked it up . It's a 1985 L200 , Grandad was the second owner from about 88, and it has a massive 75,000 kms . Thats the only 2 good points, as rust and rats have moved in, and fuck me does it stink inside. Not sure on the plans for it at the moment. A big part of me is thinking about trying to find a wellside for it and slamming it. not sure how well that would work with it being 4wd. Or fully restore it as a bit of a dedication to my grandad . //oldschool.co.nz/index.php?/topic/51221-wldrx2s-85-l200/1 point
Credit to Rumrum for the idea So I was considering getting a spa, but they're so damn expensive And I'm so damn cheap So I made this Then started on the heating Scored a flue from the Father-in-law and made a choke for it And welded the flue to the drum...uh firebox Old gas bottle for the water, spacers welded to the sides to keep it in the middle And mounted Rebar fire grate Hooked up So it turns out gas bottles have a coating on the inside, which flakes off and fills my tub with crap. The top pipe had some holes in it so I welded them shut. But the weld in the inside caught some of the crap and blocked the pipe OH CRAP! I noticed the lower pipe was getting a bit warm, the top pipe was fucking hot, and the hot water had stopped going into the tub. so woops put the fire out quick. Cleared the block and god damn the water was hot! Also it's not so good at heating. So, I'm going to scrap the bottle and back to the drawing board. So far the cost, about $30ish ha1 point
Wow, beautiful car! Keep it na and driving I reckon. If you are going to turbo and efi it then use a more modern dohc turbo powerplant. Just my opinion. Love it though!1 point
Catch up update...... Finished the Rotisserie - stands had bigger castors mounted & more supports added. (also had to heighten them a bit more as I stuffed up my measurements) EURON8 came and cast his professional eye over my welds to put my noobie nerves at rest............all good!! Just need a few of my Samoan brothers to come over and I'll have the shell up on the spit!! And after much "ummmming and ahhhhing" I have bought some paint stripper to save some $$ and get a bunch done myself first discuss here http://oldschool.co....4-ke25-corolla/1 point
This morning I got the car out of the sauna/shed and continued with the task at hand. Things now look like so IMG_7471a by Richard Opie, on Flickr IMG_7503 by Richard Opie, on Flickr The loom is pretty simple, even though it looks scary as fuck but I'll stil going to need some expert assistance to sort that one out. And that rank furry firewall liner stuff was full of sand from past panel repairs, and also fucked in general so I took the liberty of throwing it all in the bin - perhaps I'll put some kind of dynamat on the firewall later on. Or just deal with the noise/heat... I've ended up with a big old pile of interior - most of which needs a decent clean up before it goes back in really. Also looking out for a non-aircon vent arrangement for the LHS (the fresh air inlet and the pipe that runs to the fan unit) so if anyone has those bits, I'm keen to purchase them off you. IMG_7495 by Richard Opie, on Flickr Cheers!1 point
My sisters friend reckons a place exists where you can get a new chassis laser cut.1 point
Car is officially now worthless. Time to scrap it or trade in for an Audi S4. Discuss: http://oldschool.co....1-sc-chit-chat/1 point
Shit yarn #2. Factory AW11 boot mat. Apparently these are rare, and foamers foam over them. Gonna hit it with some Jif and Simple Green then it should be mint, mayte. Discuss: http://oldschool.co....1-sc-chit-chat/1 point
I'm just going to throw another suggestion out there. HBI Engineering in Chch make up/rebuild tie rod ends etc, they make up new tapers and balls for them. You could contact them and get a new longer ball and taper made up to space it down again. it would save you drilling out the steering arms, buying rose joints and so on.1 point
In more exciting valiant front steering geometry news in just now- changing the idler actually made the bump steer problem worse, 25mm now with the idler in the right place. Which means the outer tie rod ends need to be moved down. Which also means the caster is not a problem. I put a 14mm spacer under the tie rod ends and checked it again and got 9mm over the full travel of the suspension. So now I need to make some new heim joint steering arms1 point
Obligatory service time. Now that I've clocked up a few hundred km I've noticed the occasional misfire and general lack of oomph below 3000rpm, especially when loading it up in the lower gears. This is usually where you discover certain things about the previous owner(s); for example the bloke who owned this particular AW11 wasn't much of a stickler for replacing ignition-related components, even though he seemed to change the oil and coolant regularly (and the paper air filter that I replaced with a K&N was fairly new). First indication of this was the state of the spark plugs. Honourable previous-owner-san, what even is this?! From the way the bodies and electrodes look it's probably about time they were replaced even if they are considered "long-life" iridiums. I suppose it didn't help that when the car underwent fumigation and steam cleaning in NZ the spark plug valley filled up with water - as you'll notice a few photos down, the cover is missing - John did mention it was running like a bag of shit when it was first dropped off to compliance, but he managed to clean it out. A new set of iridium plugs has now been fitted, you can just see the box in the background. Should I be worried about the shit on the threads? Second indication that the dude was behind in his servicing schedule, off came the dizzy cap and uhhhhh... Let's compare old versus new. It would seem this is the original dizzy cap, as the two top posts (for cylinders 3 and 4) were worn down almost beyond the point of recognition (yes they are a slightly different design from the Bosch replacement). Hmmm, guess that could explain the misfire under load! The last few photos demonstrate how much of a pain in the arse it is to work on a mid-engined car sometimes. My worklight blew up, so I had to use the desk lamp from my soldering station instead. Not visible in the shot: the old rim I was using as a stepladder... To reach the dizzy cap you have to fold your upper body around the drivers' side C-pillar and lean right over the engine. (If this were a front-engined AE82 FX-GT or even an AE86, access would be trivial.) There's just barely enough room to get a small ratchet in between the firewall and dizzy cap to tighten up the bolts. Someone with larger hands is gonna have a bad time. You also have to be careful not to snap off the plug on the very right, or it's game over. All done... I just need to track down a 4A-GZE valley cover now. To the previous owner's credit, he did replace the ignition leads with those chunky SplitFire things. Or perhaps it was the dealer he sold it to who fitted them? Nearly at that magical 100,000km milestone. Good news, the misfire is gone, and there's a lot more pull from down low. I need to bleed the clutch next, those who have driven the car all remark it feels a bit spongy from lack of use. Discuss: http://oldschool.co....1-sc-chit-chat/1 point
Being a ricer faggot. Sometimes it's justifiable! Discuss: http://oldschool.co....1-sc-chit-chat/1 point
Pulled out the factory double-DIN stereo this evening and set it aside for now. It's not the original one, but from a late model Toyota (the markings indicate it was manufactured in or around the year 2000) so it can sit on the shelf until I find a use for it. This is the first AW11 I've owned that has working rear speakers, albeit with busted cones that rattle and make all sorts of hideous noises, which sucks because they look quite nicely constructed and even have the correct factory plug for an AW11. Fortunately I have some replacement OEM ones in my hoard - who knew they would come in handy one day! The OEM speakers are 10 watts, phwoar! Luckily they're used for rear fill, and not much else. Also have a passive Pioneer subwoofer that slots in nicely behind the passenger seat - another item that's outlasted a bunch of previous AW11s Because all of the factory plugs were still uncut behind the centre console it took a total of 5 minutes to plug the new modern headunit into the Pioneer-ISO-Toyota loom, then slightly longer to run the cabling, wire the subwoofer into the rear speaker channels, and find a suitable spot for the Bluetooth microphone. End result: It means that it'll also take 5 minutes to swap in this original AM/FM receiver and coin tray which I rescued from one of my old AW11s many moons ago, if I ever feel the need to go full retardoriginal. Also, obligatory: And before anyone asks - the white thing is a DIY cupholder I fashioned from a block of polystyrene a while back, which slots into a little moulded piece just in front of the shifter, complete with old coffee stains and everything. Richy made a great suggestion that I should get a new one 3D printed. Discuss: http://oldschool.co....1-sc-chit-chat/1 point
fin. Discuss: http://oldschool.co....1-sc-chit-chat/1 point
So close I can almost taste the victory. First order of business: take a photo of the new front bumper support to prove it's on the car (and for future reference if compliance comes knocking). The weird flecks are a combination of rustkill and Brunox. Then reassemble the entire front end in the reverse order of disassembly. Carefully. Wash off a heap of accumulated dust and grime, then make the most of the afternoon sun. Much better! Discuss: http://oldschool.co....1-sc-chit-chat/1 point
New bumper support ordered from Toyota, cheers Mark! I ended up buying two in the end because stocks are running low. Now I can emulate those foamers who throw brand new parts into the attic and forget all about them for 30 years. (Then some other guy comes along, buys it all for cheap in an estate sale and posts about it on Facebook.) P/N 52021 in the above image. You can also see the dumb foam insert (i.e. water trap) that's sandwiched between the bumper support and bumper cover. Also dug around in the shed and found all of the spare refurbished retaining rails (P/N 52521, 52522, 52525, 52535, 52536) left over from when I did the rustwork on the last AW11 and sent a heap of things away for blasting and re-coating. Knew those would come in handy one day... Discuss: http://oldschool.co....1-sc-chit-chat/1 point
This is what happens when you open Pandora's Box. CH-WOP-WOPPPPP. The front bumper support, she is toast. To be honest, I was expecting to see something like this, so it wasn't that big a surprise... front bumper supports on AW11s are hideous water traps, no two ways about it, and I would have been an even bigger idiot if I'd pulled the front apart to fix the crossmember but neglected to check behind the bumper. Again, compare with the one from the previous AW11 - which, as mentioned previously, wasn't all that rusty elsewhere. But at least that satisfies my curiosity, and it shouldn't come back to bite me in the arse further down the track. Guess I'll be getting hold of Mark from Toyota on Monday. Elsewise, the rest of the front is now off, so work can start on the crossmember. Discuss: http://oldschool.co....1-sc-chit-chat/1 point
Nearly forgot... I scored an AW/AE/KP long boss kit from Richy at this month's Burgerboes, which now gives me the option of fitting an aftermarket steering wheel to the New Kid. Cheers dude! And after wanting a Twos R Us engine cover gas prop kit for ages, buying one for the previous car, and being quietly impressed by its simple yet functional design it became a mandatory upgrade for the new AW11. Also in the same shipment: a K&N drop-in filtercharger (on special) and TGP key blank (cheap). Discuss: http://oldschool.co....1-sc-chit-chat/1 point
An update from Wheel Fix It: Three of the four Buddyclub P-1s are still bent, and they've quoted a very reasonable price for repairing as well as machining the beads. Have given them the go-ahead to do the work and hopefully the wheels will be ready Monday or Tuesday. In the meantime, more elusive treasures have been obtained from Zebra: '89 spec (final facelift) LED rear spoiler. '89 spec wing mirrors, with bonus 4A-GE valley cover to replace the one that's missing from my engine (oddly enough). Anyone who followed my previous AW11 build thread will know these are merely cosmetic upgrades, but I'm quite chuffed as I wasn't expecting to find another updated spoiler and wing mirrors this early on. Now I just have to gamble on the likelihood that repainting these blue won't balloon the total cost above that of my original plan, which was to import the bits out of Japan in the correct colour. On the flip side the rear quarter is getting resprayed anyway as a result of the repair cert signoff, and if I get the LED on the new rear spoiler working before the car goes back to compliance I'll save further coin by not needing an aftermarket high stop light fitted anymore. Discuss: http://oldschool.co....1-sc-chit-chat/1 point
While the car's in the paint booth I've taken the chance to revisit this old chestnut. Back in 2011 (when I had the other blue AW11) I'd had good intentions of restoring and fitting this set of Buddyclub P-1s that Markku and Richy found for me, but ended up just buying a set of factory ZZW30 alloys instead. Fast forward four years and I've finally decided to revisit this idea, aided by the fact I'm getting the New Kid painted at the same time, and the tyres on the car failed compliance anyway, so it hopefully won't be too much of a stretch to tack this extra task on the end and just swap the wheels over when it's ready for its new tyres. There has been one small setback though - it turns out the original place I'd taken the P-1s to back in 2011 didn't actually fix them (even though I got charged a nice hefty sum for the privilege), so they are now in the care of Wheel Fix It, who will straighten them up and also machine the beads before handing them back for painting. What colour, you may ask? BMW do a nice Moccabraun bronze metallic, which should provide just the right amount of "pop" in the sun. But I'm still busy looking through swatches for ideas. Discuss: http://oldschool.co....1-sc-chit-chat/1 point
out with that one, put other one in. got a reasonable amount done today despite having a 2 hour battle with the oil filter pipes, what a stupid arrangement, they never seem to go on the same as they come off. ended up having to modify a spanner to get one of the nuts tight, then the driver side header didnt want to play ball either. have decided to flag fitting a cat as i had a yarn to someone who knows a bit about such things. one reason oils have bugger all zinc in them now is because it clogs cats. i want lots of zincs in my oil because of dinosaur spec cam1 point
So now we have a house with a bigger garage, ive got this at home. Stripped the interior out today as it was FULL of rat poos, old rubbish from the 80s, pictures of jeebus, pencils and 2c coins, and a rug with a tiger on it. floor looked good from underneath, and even better on top, its like a new one, sweet!1 point
i like skids. so when i get the chance to do skids without fear of license removal, i grasp that opportunity.1 point
