Adoom Posted August 24, 2021 Posted August 24, 2021 2 hours ago, Roman said: Also invaluable is a good depinning tool You can buy some but I've got a piece of piano wire that's sharpened at one end, with a little handle on the other and it's brilliant. Sometimes a bit tricky to see how plugs come apart until you've done a few Mine is one of those WTF does this even fit super skinny allen keys ground to a long chisel tip. I found that it works better than wire because it's stiff and won't easily bend. Quote
gibbon Posted August 24, 2021 Posted August 24, 2021 3 hours ago, Taistorm said: You can get a 'good enough' keychain of depinning tools off wish cheap as chips. Aw sweet something new to buy on aliexpress. See you in an unknown amount of working weeks you good thing Quote
Taistorm Posted August 24, 2021 Posted August 24, 2021 https://www.wish.com/product/upgrade-41pcs-auto-terminals-removal-tool-set-car-electrical-wiring-crimp-connector-pin-extractor-kit-for-car-repair-car-crimp-connector-pin-extractor-5dbaa48b0b61670deb7c4ed0?hide_login_modal=true Quote
vk327 Posted August 24, 2021 Posted August 24, 2021 highly recommend these if your ordering connectors from ballenger motorsports get a couple, they work well for depinning most connectors https://www.bmotorsports.com/shop/product_info.php/cPath/111_113/products_id/366 the key ring ones work well too just wear out quickly Quote
Muncie Posted August 30, 2021 Author Posted August 30, 2021 Found this site, it's a little clunky but pricing seems good. Look familiar to everyone? https://www.kiwiconnectors.com/kiwi-motorsport-electronics-sensors/atm-connectors Quote
sheepers Posted August 30, 2021 Posted August 30, 2021 what a rip off. just do what that guy is doing and buy the kits off aliexpress. Quote
Muncie Posted August 30, 2021 Author Posted August 30, 2021 4 minutes ago, sheepers said: what a rip off. just do what that guy is doing and buy the kits off aliexpress. Cheers man its good to know where things have come from. I wouldn't have known as I'm not quite looking in huge detail yet. Quote
Adoom Posted August 30, 2021 Posted August 30, 2021 If anyone has links to part numbers for common OEM connector terminals, that would be super handy. I know you can get them from places like RS components, but it's often hard to identify them from the one image they show you. Quote
Lord Gruntfuttock Posted August 30, 2021 Posted August 30, 2021 Yeah I've got some Kawasaki switchgear I'd like to put on the Hardly. Be nice to be able to wire in corresponding bits so it's plug & play... Quote
Adoom Posted August 30, 2021 Posted August 30, 2021 Actually, this looks promising. https://www.aliexpress.com/item/1005002602810952.html?spm=a2g0o.productlist.0.0.257d6ddekfRGNd&algo_pvid=d840d349-13ad-42b0-a9bb-c5aa26c06c47&algo_exp_id=d840d349-13ad-42b0-a9bb-c5aa26c06c47-11 Quote
vk327 Posted August 31, 2021 Posted August 31, 2021 3 hours ago, Adoom said: Actually, this looks promising. https://www.aliexpress.com/item/1005002602810952.html?spm=a2g0o.productlist.0.0.257d6ddekfRGNd&algo_pvid=d840d349-13ad-42b0-a9bb-c5aa26c06c47&algo_exp_id=d840d349-13ad-42b0-a9bb-c5aa26c06c47-11 be wary of chinese terminals on anything critical, have seen it several times after a couple cycles plugging in they lose tension and end up with bad contact as they are made of way thinner material than genuine ones, can really notice the difference with the Chinese LS looms from VPW and aeroflow vs OEM even the connector bodies are made of sub par plastic and cant handle the heat of an engine bay and go real brittle, the old saying you get what you pay for, common terminals are pretty easy to ID, GM its all generally Delphi/Aptiv metripack 150/150.2 or GT150, most japanese stuff is sumitomo, can generally figure out parts crossover to RS from ballenger, waytek, eficonnection or nzefi listings Quote
Roman Posted August 31, 2021 Posted August 31, 2021 3 hours ago, Adoom said: If anyone has links to part numbers for common OEM connector terminals, that would be super handy. I know you can get them from places like RS components, but it's often hard to identify them from the one image they show you. Almost everything in a toyota from 90ish is onwards is these https://www.msel.co.nz/epages/motorsportelectronics.sf/en_NZ/?ObjectPath=/Shops/motorsportelectronics/Products/TER51151 Quote
dmulally Posted May 1, 2024 Posted May 1, 2024 BUMP. Not worth starting a new thread but I have to re-wire a couple of cars. Namely a series landy and a 67 econoline. I'm not a fan of those wiring kits although I did enjoy using the American Auto Wire model specific one for my Chev. It was rather pricey however. Does anybody know where I can get bulk wiring for cheap? I like the look and feel of the SXL wiring and the last one I got was from Amazon here. Does anybody know where I can get it in bulk for cheap? Temu? Ali Baba? Jaycar? I use this as my fuse/relay block seeing as I'm lucky to even have a heater fan let alone a stereo. I don't need much. Quote
Bearded Baldy Posted May 2, 2024 Posted May 2, 2024 Nice link, gives me an idea to ditch all 10!! of the glass fuses in the falcon. Quote
vk327 Posted May 2, 2024 Posted May 2, 2024 Can supply those boxes in disassembled form so crimp your own adventure to suit, with 4 or 5 pin relays Quote
dmulally Posted May 2, 2024 Posted May 2, 2024 18 minutes ago, Bearded Baldy said: Nice link, gives me an idea to ditch all 10!! of the glass fuses in the falcon. Don't you enjoy reaching under there and giving the glass fuses a gentle rub between the fingers to get it going? 1 Quote
Bearded Baldy Posted May 2, 2024 Posted May 2, 2024 I can't fucking fit under there anymore! Hahaha Quote
shrike Posted May 8, 2025 Posted May 8, 2025 Thread revival, have decided based on other reading milspec bulkhead connectors aren't worth the effort/cost and to just have a grommet I can pull loom plugs through etc However been thinking about injector/coil looms that can be detached from the main engine loom Does anyone have a recommendation on a male/female plug kit with pins? Injectors 9 or 10 pin plug (1x12awg power split to 8x22awg, 8x22awg switched ground) allows for staged injectors 5 pin plug (1x12awg power split to 4x22awg, 4x22awg switched ground) and id wire two up and have two 4x injector looms so it doesn't need to be plugged in to start Coilpacks 6pin (12awg power split into 4 x 20awg, 1x12awg gnd wired to head split to 4x 20awg, 4x20awg signals from ecu) Quote
Roman Posted May 8, 2025 Posted May 8, 2025 I quite like the Sumitomo plugs, just google "Sumitomo 12 way connector" or whatever and heaps of things come up. Have used these to make sub looms on mine. 3 Quote
shrike Posted May 8, 2025 Posted May 8, 2025 15 minutes ago, Roman said: I quite like the Sumitomo plugs, just google "Sumitomo 12 way connector" or whatever and heaps of things come up. Have used these to make sub looms on mine. Do you have a known good supplier or are the aliexpress connectors ok? Quote
