tortron 64,383 Posted November 10, 2020 Report Share Posted November 10, 2020 https://www.storagebox.co.nz/jerry-cans 2L an option? 1 Quote Link to post Share on other sites
tortron 64,383 Posted November 10, 2020 Report Share Posted November 10, 2020 im assuming they are food grade hdpe, so wont melt you wanna tape the caps on though incase they vibrate off Quote Link to post Share on other sites
HighLUX 32,891 Posted November 10, 2020 Report Share Posted November 10, 2020 Good option if it will like holding fuel without dissolving Quote Link to post Share on other sites
Truenotch 9,071 Posted November 10, 2020 Report Share Posted November 10, 2020 I bought my smaller one from Bunnings. I think it’s a bit under 4L. Quote Link to post Share on other sites
RUNAMUCK 29,081 Posted November 10, 2020 Report Share Posted November 10, 2020 Grab a 2ltr thinners style tin? I got given a 2ltr thinners style tin with inbuilt funnel before the '18 ride. I meant to ask the guys I got it off where it was from. Quote Link to post Share on other sites
RUNAMUCK 29,081 Posted November 10, 2020 Report Share Posted November 10, 2020 bit like this https://www.stihl.com.au/STIHL-Products/Oils-Lubricants-Fuels/Fuel-Cans/22154-1643/Fuel-Can-2-litre.aspx Quote Link to post Share on other sites
Beaver 8,667 Posted November 10, 2020 Report Share Posted November 10, 2020 I rode my bike 6km to work this morning for the first time in a long time. Pretty sure it's ready for eastcape now. 6 Quote Link to post Share on other sites
anglia4 1,882 Posted November 10, 2020 Report Share Posted November 10, 2020 Thats what I said about mine. Then the wiring shit itself on the ride home and while it was apart I started "fixing" other things... 1 Quote Link to post Share on other sites
tortron 64,383 Posted November 10, 2020 Report Share Posted November 10, 2020 and your work is 8km away? almost done a full tank since rings and cam on mine, so probably its ok 1 Quote Link to post Share on other sites
GuyWithAviators 9,023 Posted November 10, 2020 Report Share Posted November 10, 2020 (edited) I did an hour nangs thru some forestry roads. Job done. Edited November 10, 2020 by GuyWithAviators It was steep 4 Quote Link to post Share on other sites
Beaver 8,667 Posted November 10, 2020 Report Share Posted November 10, 2020 45 minutes ago, anglia4 said: Thats what I said about mine. Then the wiring shit itself on the ride home and while it was apart I started "fixing" other things... Ive also done the raglan ride, some hectic bush bashings, and some backyard racing over the last couple of months. So I'm reasonably comfortable in its ability haha. 2 Quote Link to post Share on other sites
MopedNZ 10,403 Posted November 10, 2020 Report Share Posted November 10, 2020 40 minutes ago, Beaver said: Ive also done the raglan ride, some hectic bush bashings, and some backyard racing over the last couple of months. So I'm reasonably comfortable in its ability haha. Did you hoon the narrower tyre? Quote Link to post Share on other sites
RUNAMUCK 29,081 Posted November 10, 2020 Report Share Posted November 10, 2020 I guess I should ask, What's the shift pattern on the NBC @Vintage Grumble? Changing gears will be a new experience. I rode a step through in 1989 around a DEKA carpark after hours. That was one up, two down. Long time ago now though. Quote Link to post Share on other sites
Tumeke 6,274 Posted November 10, 2020 Report Share Posted November 10, 2020 NBC? Bart you changed. Haven't seen a lifan swapped NBC yet tho Quote Link to post Share on other sites
Beaver 8,667 Posted November 10, 2020 Report Share Posted November 10, 2020 5 minutes ago, MopedNZ said: Did you hoon the narrower tyre? Yeh they are on there now. No rubbing so far, and normally I would have an hour excited gooch even going to work. The work down headstud some nuts will thank me I'm sure! Quote Link to post Share on other sites
MopedNZ 10,403 Posted November 10, 2020 Report Share Posted November 10, 2020 4 minutes ago, RUNAMUCK said: I guess I should ask, What's the shift pattern on the NBC @Vintage Grumble? Changing gears will be a new experience. I rode a step through in 1989 around a DEKA carpark after hours. That was one up, two down. Long time ago now though. Either all up or all down. Pretty sure they have a neutral light. Easy as. A small putter down the road and you'll be allgood to go. Quote Link to post Share on other sites
tortron 64,383 Posted November 10, 2020 Report Share Posted November 10, 2020 more gumboot will sort out being in the wrong gear Quote Link to post Share on other sites
HighLUX 32,891 Posted November 10, 2020 Report Share Posted November 10, 2020 We can get the nbc off VG on the way down if you want Bart? Then you can spend Thursday avro getting used to the power Quote Link to post Share on other sites
Vintage Grumble 25,138 Posted November 10, 2020 Report Share Posted November 10, 2020 1 hour ago, RUNAMUCK said: I guess I should ask, What's the shift pattern on the NBC @Vintage Grumble? Changing gears will be a new experience. I rode a step through in 1989 around a DEKA carpark after hours. That was one up, two down. Long time ago now though. Its four up from neutral, and has a N light, so pretty plush. Its also semi auto, so no clutch to worry about. It got a clean sheet WOF yesterday, dude even commented on how "tight" it felt, so it may or may not be pregnant. You can collect it from mine, or I can drop it off at J5's for ya, no probs either way. There's also a camping fridge for @UTERUS that I assume he wants at J5's, so I was going to strap that on the tray, or if @HighLUX has room might be able to take it out if ya'll are swinging past. 1 1 Quote Link to post Share on other sites
RUNAMUCK 29,081 Posted November 10, 2020 Report Share Posted November 10, 2020 Dropped at J5s please Thomas. 1 Quote Link to post Share on other sites
