kws
KwS's TVR
51 minutes ago, Dell'orto said:
Potentially not ethanol compatible hose? Would have not expected to crumble that badly!
Internet says its good for E85, or even methanol. I can't imagine the previous owner running anything with an ethanol content though.
Share this post
Link to post
I love TVRs for the exotic-ness and the fact that they were always so hard to drive on Playstation1, I didn’t realise that there were affordable models around until reading this post. I had never heard of the Tasmin but now when I win lotto tonight I am going to buy one. Keep at it man, this thing is so damn cool.
Share this post
Link to post
On 15/10/2019 at 18:11, kws said:
Yeah, it'd be great if I could drive the damn thing though!
Keep chippin' away at it, it's the only way to get closer to driving it!
Share this post
Link to post
I'm well fascinated by your play with Robert Bosch's remarkable CIS MFI. I have the same motor as you in my sierra xr4x4 and plan a reconditioning of the fuel system next year after a trip to Europe for bits. Would you suggest a professional cleaning of injectors or just jumping into a new set?
Share this post
Link to post
The merc ones are cheap enough that I would just grab a set of them unless you're wedded to keeping your original set.
I believe there are filters in the original injectors that cannot be accessed, so even a decent cleaning may not bring them back as good as new.
Share this post
Link to post
That's the plan. Being British though, it's either going to fix it, make it worse, or cause it to burst into flames.
Share this post
Link to post
Whenever I take one of my seldom movers for a warrant the guys will ride the brakes on the rollers for a bit until it comes good.
Share this post
Link to post
Just seeing Michael San's coments above...
Be careful driving with the handbrake on, as it can cause the pads to rip out (sounds like a fail i know). But they are a pretty fragile thing, designed to keep the car still. Not for e-brake drifts. So just be mindfull of that. Cos it will be misery to change the pads...
Share this post
Link to post
^ That's just what I was gonna say. Jaguar Barry warned me so many times not to drive with the handbrake on - it either rips the pads out or heats them up and melts the glue holding the pad material to the backing plates.
Another problem my handbrake had (which is hopefully unique to the XJ-S / Jaguar installations) was the handbrake cable going rusty inside its sheath. This increased the effort required to apply the handbrake, but more importantly made it tricky to release it fully and quickly every time. That in turn put me at risk of ripping the pads out. It's all fixed now but I had to endure many Barry sharns to get to this point.
  • Haha 1
Share this post
Link to post
Good point. I'm hoping driving with the bled rear brakes should be enough to knock most of the rust off the rotors, but I'll go easy on the hand brake.
Share this post
Link to post
Awesome result!  I can wholeheartedly relate with your issues when I had my Audi - I never personally got as balls deep into playing with the control pressure as you have, I sent the car to a chap that knows more about the system than Bosch do...
Share this post
Link to post
Thanks for the very detailed info, very useful to me...eventually. I have the same donk in my Sierra and although it hasn't been touched since new, just regular servicing, it's running faultlessly. Having said that, I feel it's a good idea to recondition the fuel distributor and check WUR etc so your input is valuable. Thanks again.
Share this post
Link to post
