Plastic headlights - gone cloudy
rusty360
Used to just cut and polish my merc, lots of kits on trademe , some with uv protectant? To help them stay clear for longer apparently.
there was also a company that would clear coat them and warranty it for a few years but was pricey (cheaper than merc headlights tho)
If you want results that are decent and last you have to put some work in. Start with sanding, depends how bad it is but you can usually start at 600 (sometimes lower) and work your way up, then finish with any decent car polish, if you can take them off the car and use a DA and paint cutting compound it saves lots of labour. The clear coat is a good idea as the UV protection of the plastic is completely gone if you clean these up with abrasives, you really want to use 2k clear and cut that smooth also. Or instead of clear-coat you can just keep them waxed and polished with your car cleaning routine.
SOme are fucked on the inside also if they have been leaking so you may need to pull them apart to sort that
