Benno Posted April 12, 2015 Report Share Posted April 12, 2015 Yup, that sounds about right. Never done an FA so I could be wrong, but many of these small bikes don't have a regulator, only a rectifier. Basically this means that instead of having something that converts the AC to DC then 'chops' the voltage to ~14v it only converts it from AC to DC. At idle the voltage will probably be really low, high revs really high. The battery basically acts as a regulator, absorbing these voltage spikes and providing voltage when it is too low. This is why those motobatt batteries can burn out kinda quickly with these sorts of bikes, they don't love the spikes. Quote Link to comment Share on other sites More sharing options...
Benno Posted April 12, 2015 Report Share Posted April 12, 2015 Make sure you keep the battery connected to even this out, otherwise you will blow bulbs all day Quote Link to comment Share on other sites More sharing options...
Beaver Posted April 12, 2015 Report Share Posted April 12, 2015 Make sure you keep the battery connected to even this out, otherwise you will blow bulbs all day Yeh this, pretty sure the battery acts like a regulator of sorts. 2 Quote Link to comment Share on other sites More sharing options...
tortron Posted April 12, 2015 Report Share Posted April 12, 2015 Can confirm battery is the rwgulator Quote Link to comment Share on other sites More sharing options...
Shakotom Posted April 13, 2015 Author Report Share Posted April 13, 2015 This things 6v though. I thought it wouldve run between 6v-8 or 9 v max? @guypie how do you figure out exhaust port duration? Powerband would be all of it preferably But really, mid range up Goes okay on flat as is, but wouldn't mind more go for hills And if I removed/blocked the oil system on this and ran premix would that cause any problems? Quote Link to comment Share on other sites More sharing options...
Beaver Posted April 13, 2015 Report Share Posted April 13, 2015 Just ride it, stop worrying about the finer details. If it runs then nothing is wrong Quote Link to comment Share on other sites More sharing options...
Shakotom Posted April 13, 2015 Author Report Share Posted April 13, 2015 But I need to get the basics sorted first (you know what I'm like ) Then I can start changing things Quote Link to comment Share on other sites More sharing options...
Beaver Posted April 13, 2015 Report Share Posted April 13, 2015 Also user manual if you dont have one http://mob50.fr/doc/manuel-atel-suz-fa50-1980-engl.pdf 1 Quote Link to comment Share on other sites More sharing options...
Guypie Posted April 14, 2015 Report Share Posted April 14, 2015 This things 6v though. I thought it wouldve run between 6v-8 or 9 v max?@guypie how do you figure out exhaust port duration?Powerband would be all of it preferably :)But really, mid range upGoes okay on flat as is, but wouldn't mind more go for hillsAnd if I removed/blocked the oil system on this and ran premix would that cause any problems? Take the exhaust off so you can look in the port, turn it til the piston uncovers the exhaust port. Mark the flywheel and a mark somwhere adjacent on the engine casing at the point the port is first uncovered. Rotate it til reached the point of closing and mark this point. Get a protractor and measure how many degrees the port was open for. Should be about 120 at a guess, possibly less. Well thats how I usually do it anyways, others might have better ways. Quote Link to comment Share on other sites More sharing options...
Benno Posted April 14, 2015 Report Share Posted April 14, 2015 Alternatively, find something like this and print it off. http://www.flatheadv8.org/degree.htm Stick it to something solidish, a CD works well (might need to scale down). Attach your degree wheel to the flywheel somehow. Tape or bluetak would work well. Figure out the point at which the port is first opened, either as above or by looking from the exhaust port, or by taking the head off and looking at it in the bore. Line the degree wheel up with something fixed to the crankcase (a mark, fin etc or can attach a bit of wire or something) and set to TDC or 0 degrees. Rotate the engine slowly until you can see the exhaust port close. Take the measurement from the degree wheel to the point at the start, and you're sorted! Quote Link to comment Share on other sites More sharing options...
kicker Posted April 14, 2015 Report Share Posted April 14, 2015 I ran premix on one of mine, fairly easy to do, remove the pump and make a blanking plate for the hole then seal the oil port on the crankcase. Not sure if I'd bother doing it again, the auto-oiler works well and dumps it straight onto the crank. Quote Link to comment Share on other sites More sharing options...
Ghostchips Posted April 15, 2015 Report Share Posted April 15, 2015 If you keep the auto oiler and add a tiny bit of oil to the fuel you should be ok, if you remove the auto oiler it might seize going down steep hills? Not 100% sure on that though. Quote Link to comment Share on other sites More sharing options...
SOHC Posted April 15, 2015 Report Share Posted April 15, 2015 Avoid engine braking going down hills and blip the throttle on the over run often to keep the oil coming in. Also if you disconnect the autolube system and premix your oil/petrol it can cause them to run lean as the oil displaces the petrol. 1 Quote Link to comment Share on other sites More sharing options...
Shakotom Posted April 16, 2015 Author Report Share Posted April 16, 2015 So this manual I found says that these things run a PEI ignition? and so there should be a CDI unit somewhere aswell according to the wiring diagram.... Mines a 1986 model and doesnt appear to have this box. It runs but Is it missing something? because the electrics on this are all over the show So over this damn thing. Quote Link to comment Share on other sites More sharing options...
The Dude Posted April 16, 2015 Report Share Posted April 16, 2015 Don't remove the Autolube, its a pain in the crack getting the mixture right, and I have no idea why but mopeds always seem to sieze on premix (I am awful with premix tho!) Quote Link to comment Share on other sites More sharing options...
felixx Posted April 16, 2015 Report Share Posted April 16, 2015 Like the other chap said ride it like it's hayholes mum! Quote Link to comment Share on other sites More sharing options...
ODB Posted April 16, 2015 Report Share Posted April 16, 2015 Like the other chap said ride it like it's hayholes mum! Do you mean give everyone else a burn??? 1 Quote Link to comment Share on other sites More sharing options...
tortron Posted April 16, 2015 Report Share Posted April 16, 2015 Hey mate. Probably the coils in the mag-totally-neato have gotten fuel on them/are just old and have lost their insualtion coatings. This will give you over charging. Can rewind these by hand if you are totally.keen. Have to find a supplier of the correct wire then put exactly.the same number of turns on each one. Be a good idea to inspect and check them out with a multimeter Quote Link to comment Share on other sites More sharing options...
tortron Posted April 16, 2015 Report Share Posted April 16, 2015 That said. Can you confirm.what the electical issues are? Quote Link to comment Share on other sites More sharing options...
Shakotom Posted April 28, 2015 Author Report Share Posted April 28, 2015 Maaaaan have I waffled on about this piece..I fixed the hard starting issue, I stripped and cleaned out the carb and removed the two blocked up plastic filter things jammed in the fuel pipes. Starts first pop now always. Electrical: still over charging (i think), but all lights work ect and it rides sweet so that will do for now. will do 45kmh on the flat! Been riding it to and from work. Goes good and carrier on the back works good at carrying my tool bag, Also been doing your nomal scooter things like: Going to coffee shops Going on 'gang' rides with mates. ( rode about 60km on this ride round trip) and running out of gas and pushing it to the gas station... Oh... also I got this..... a Honda NF'50' Its got something wrong/broken related to the kick start Im told... I dunno, I couldn't bear to see it end up scrapped and it was too good to pass up on, but mostly hopefully it will stop me modifying my FA50 while Im trying to daily it.... 5 Quote Link to comment Share on other sites More sharing options...
