chris r Posted September 9, 2017 Posted September 9, 2017 I'm too lazy/tired to read it but are you running positive earth or negative earth? Do the vibrator or trembler points still work? If you were keen you may be able to fit a modern internal coil and ignition module out of a dizzy and use the "trembler" points to trigger it Quote
Ghostchips Posted September 9, 2017 Author Posted September 9, 2017 The points are old but kind of work. The wood they mount on is soft and has borer so i'd have to replace it or stiffen it with something to give the points a steady pressure. The thing with the points is they're activated by the pole of the coils winging core so putting a small bike coil in might work, but i'll have to have the end of the coil sticking out of the wood. I'll see what a coil expert i know thinks about this. He might have some tricks. Quote
SOHC Posted September 10, 2017 Posted September 10, 2017 Some bike coils use the inner laminated core to mount the coil to the bike frame so you could possibly attach some thing to that Quote
BlownCorona Posted September 12, 2017 Posted September 12, 2017 thats a luggage strap not a belt lol Quote
Ghostchips Posted June 14, 2018 Author Posted June 14, 2018 So i'm not driving a dark shape without any lights on it. Battery goes flat fast with incandescent bulbs. 1 Quote
igor Posted July 24, 2019 Posted July 24, 2019 Some years ago I found a four cylinder Ford manifold with a Holley carb on it lying in the grass behind one of my sheds. Looks like it's off a T or an A. Don't know enough about them to pick the differences. No idea if it has any usable parts left on it but if it's any use to you you're welcome to have it. 3 Quote
tortron Posted July 24, 2019 Posted July 24, 2019 I did similar to one of my carbs. Used jewelers rouge to lap the tinned shaft in 1 Quote
Ghostchips Posted July 25, 2019 Author Posted July 25, 2019 3 hours ago, igor said: Some years ago I found a four cylinder Ford manifold with a Holley carb on it lying in the grass behind one of my sheds. Looks like it's off a T or an A. Don't know enough about them to pick the differences. No idea if it has any usable parts left on it but if it's any use to you you're welcome to have it. NH holly is T. The A often have a different carb', tillerston X is the aftermarket ones, that aren't as good at the updraft zenith Updraft zenith pictured. Quote
SOHC Posted September 2, 2019 Posted September 2, 2019 Didn't the pinion gear come from under a macrocarpa tree and the crown wheel was missing a tooth anyway? all those skids and drifting would have been a pit hard on it. Quote
SOHC Posted September 12, 2019 Posted September 12, 2019 Do you think you have made a successful ignition system? I have noticed everyone on fordbarn is ignoring me now, 2 Quote
Ghostchips Posted September 12, 2019 Author Posted September 12, 2019 7 minutes ago, SOHC said: Do you think you have made a successful ignition system? I have noticed everyone on fordbarn is ignoring me now, I have successfully made something that gives me 4 times as many shocks as a single ignition coil. Those sad old squares ignore me too. 2 1 Quote
ThePog Posted September 13, 2019 Posted September 13, 2019 This is great, I love the low tech implementation of high tech ideas. 2 Quote
a.craw4d Posted September 17, 2019 Posted September 17, 2019 Fark what a cool project. Love the ignition system made from plastic bottles. This rocket science is way over my head but I'm loving the diy. Keep up the good work. 2 Quote
flyingbrick Posted October 30, 2019 Posted October 30, 2019 lol, dude, you are definitely not dumb!!! Had a good laugh at this Quote
igor Posted October 30, 2019 Posted October 30, 2019 I love the way you are utilising so much modern electronic shit on such a dinosaurus car. You truly are some kind of genius. 2 1 Quote
MACKAZ Posted October 30, 2019 Posted October 30, 2019 ^^Hardcone, know your self worth, you're a frigging genius in my book. 2 Quote
SOHC Posted November 28, 2019 Posted November 28, 2019 I gave you like 7 carburetors and you lost them all, did you find the brass ones? 1 Quote
Ghostchips Posted November 28, 2019 Author Posted November 28, 2019 I picked through a bucket of parts & found them. Should be enough parts for 1 good one. I think the parts carb' was one you gave me too. Do you need a giant 3 litre lawnmower engine carb? 1 Quote
