Ghostchips Posted September 3, 2015 Author Share Posted September 3, 2015 So where would i obtain white metal, lead free, pure engine bearing spec white metal? Quote Link to comment Share on other sites More sharing options...
tortron Posted September 3, 2015 Share Posted September 3, 2015 Alloybearings.com ex aussie 1 Quote Link to comment Share on other sites More sharing options...
tortron Posted September 3, 2015 Share Posted September 3, 2015 Il.pick some up in the usa if you like/you order some and have it sent to the place im stashing my bike you probably.dont want more than a kg? 1 Quote Link to comment Share on other sites More sharing options...
Ghostchips Posted September 3, 2015 Author Share Posted September 3, 2015 Il.pick some up in the usa if you like/you order some and have it sent to the place im stashing my bike you probably.dont want more than a kg? No idea. i'm used to picking out old shells an melting them but that's poor practice/contaminated so i hear. i'll see if i can get someone to order some and see what happens. 2 Quote Link to comment Share on other sites More sharing options...
tortron Posted September 3, 2015 Share Posted September 3, 2015 Cool let me.know. Bunch of old stationary engine enthusiasts over there so must be a few good sources 1 Quote Link to comment Share on other sites More sharing options...
SOHC Posted September 3, 2015 Share Posted September 3, 2015 There was some on trade me a wile ago, the guy also had the mandrills for the model t and a 1 Quote Link to comment Share on other sites More sharing options...
SOHC Posted September 9, 2015 Share Posted September 9, 2015 I have a valve grinding machine your welcome to use, I use it for setting the tappets in the ford v8s 2 Quote Link to comment Share on other sites More sharing options...
Honda Ass Dragger Posted September 9, 2015 Share Posted September 9, 2015 Your starter motor switch is very Adams family spec IMO 3 Quote Link to comment Share on other sites More sharing options...
SOHC Posted September 9, 2015 Share Posted September 9, 2015 I love the home made piston rings 2 Quote Link to comment Share on other sites More sharing options...
tortron Posted September 16, 2015 Share Posted September 16, 2015 Oldclassiccar.co.uk has all the brass fittings for making fuel lines, they also.have cloth covered cables incase you need some in.the future 1 Quote Link to comment Share on other sites More sharing options...
SOHC Posted September 19, 2015 Share Posted September 19, 2015 I like the map light, mine has a red diamond peace of glass in the end, I have set it up to be the high beam warning lamp. 2 Quote Link to comment Share on other sites More sharing options...
SOHC Posted October 10, 2015 Share Posted October 10, 2015 Do you have a set of coils for this project? I was thinking if you had 4 burnt out coils you could put 4 motorcycle coils inside the box and use the old Ford buzzers to make them work. 1 Quote Link to comment Share on other sites More sharing options...
Ghostchips Posted October 10, 2015 Author Share Posted October 10, 2015 Do you have a set of coils for this project? I was thinking if you had 4 burnt out coils you could put 4 motorcycle coils inside the box and use the old Ford buzzers to make them work. i have 3 coils that sort of work, bought as "old electric fence energizers". The buzzers were operated by the magnetic field in the coil itself, the pole actually protruded. Hence i figured using bike coils with the points buzzers attached would have lost some of the magnetic field by the point it reaches the outside of the case, and coil gauss saturation is important for a good spark. But yes, i see we think alike in some things. Quote Link to comment Share on other sites More sharing options...
SOHC Posted October 10, 2015 Share Posted October 10, 2015 How about if you used 4 of those buzzers dairy's use with the points inside and wired them in series with each coil. 1 Quote Link to comment Share on other sites More sharing options...
SOHC Posted October 10, 2015 Share Posted October 10, 2015 we used a old door buzzer taped to a 6v battery for timing magnetos at my old work and when it was hooked up the plugs would spark at the same rate as the buzzer. 1 Quote Link to comment Share on other sites More sharing options...
SOHC Posted October 10, 2015 Share Posted October 10, 2015 i have 3 coils that sort of work, bought as "old electric fence energizers". The buzzers were operated by the magnetic field in the coil itself, the pole actually protruded. Hence i figured using bike coils with the points buzzers attached would have lost some of the magnetic field by the point it reaches the outside of the case, and coil gauss saturation is important for a good spark. But yes, i see we think alike in some things. I have one coil box on an old oxyacetylene welding trolley, it was used for lighting up. An old trick was to wrap a light bulb in tinfoil but leave a space open at the top, then connect + to the light bulb filament and the - to the tinfoil and power it with the T coil, when you hold your hand over it they say you can see the bones. Quote Link to comment Share on other sites More sharing options...
Ghostchips Posted October 10, 2015 Author Share Posted October 10, 2015 i tried that, didn't work for me. Might work if i had an old camera that used film but i don't have one. Would you try it & see if it works? 1 Quote Link to comment Share on other sites More sharing options...
kempy Posted October 10, 2015 Share Posted October 10, 2015 Hey Rusti, is it one of these? I have this one and don't use it apart from shocking unsuspecting victims, yours if you want. 3 Quote Link to comment Share on other sites More sharing options...
Ghostchips Posted October 10, 2015 Author Share Posted October 10, 2015 Hey Rusti, is it one of these? I have this one and don't use it apart from shocking unsuspecting victims, yours if you want. Yes it is. i have a couple of dead ones if you want to pull them apart and fix them. For..you know, shocking people and maybe connecting to a car or metal bench with multiple people on it. Quote Link to comment Share on other sites More sharing options...
UTERUS Posted October 22, 2015 Share Posted October 22, 2015 WWW.alldatasheet.com is handy to figure out what components purpose in life is. 1 Quote Link to comment Share on other sites More sharing options...
