No intake leak I am aware of but I I'll take a detailed look
Idle has settled at 13.5" after tuning.
Saying that, I am running excess air through at idle and using the ECU to control the timing to pull idle speed down to 1000 rpm, just stops the speed undershooting 1000 when coming off throttle with headlights on. Timing needs to constantly jump around between 5 and 18 degrees to give it a smooth idle, with a bit of offset depending on if electrical loads are active
  • Replies 6.8k
Na but keen to get one as I sometimes work right next to the largest uranium source discovered in nz so far - to aliex to look for one now
what are the utes you sometimes see with the radiation hazchem Symbol on the dg placard ? Rad source and counter for pipe testing ?
see them a bit / one got stolen last year and they had a wee panic
yeah for measuring how compact the roads are. was gona do it for a summer jerb once
@RUNAMUCK, i like old stuff. The 1950s and earlier were a H&S wasteland.
I know its radioactive just cos of its age, i wanna know if i want to store it in the shed or in my undie drawer
19 minutes ago, Beaver said:
Looks like it needs a key? So smash the shit out of it with a screwdriver? Or there are some that need magnets.
Oh yeah, that's a key slot. I thought it was a name or something. I don't have the key so will resort to brute force/grinder
Put your glasses on old man
21 minutes ago, AllTorque said:
Should be the same key as the ignition
Winner, thanks Rogee! Modern vehicles are so flash.
Now, any tips on removing aluminium valve caps that have been soaked in sea water?
I think I'll have to get new valves fitted to all 4 wheels.
theres a tool that installs valve stems without taking the tyre off the bead. you sidecutter the old ones off, poke them inside. then this thing slams the new one in real hard, dry
