johnnyfive Posted October 1, 2014 Share Posted October 1, 2014 Why the hell aren't there more Turbo VLs you mean? They are the best. 7 Quote Link to comment Share on other sites More sharing options...
durty Posted October 1, 2014 Share Posted October 1, 2014 why the hell are there so many turbo VLs? or was that just the one camera car making all the chooo choo cho cho cho chos Because RB army WAT Quote Link to comment Share on other sites More sharing options...
Vintage Grumble Posted October 1, 2014 Author Share Posted October 1, 2014 Turbo VL with sleepy eyes, the pinical of automotive engineering. 4 Quote Link to comment Share on other sites More sharing options...
Snoozin Posted October 1, 2014 Share Posted October 1, 2014 Sleepy eyes? Fuck cunt, that's a legit Calais front I'll have you know. Sleepy eyes are for 180SX's and FC's you heathen. And probably AE86 Truenos. 5 Quote Link to comment Share on other sites More sharing options...
beachlander Posted October 1, 2014 Share Posted October 1, 2014 Should sell the ute and get a VL. 4 Quote Link to comment Share on other sites More sharing options...
Vintage Grumble Posted October 1, 2014 Author Share Posted October 1, 2014 1 Quote Link to comment Share on other sites More sharing options...
ODB Posted October 1, 2014 Share Posted October 1, 2014 ^^ you read my mind haha Quote Link to comment Share on other sites More sharing options...
Vintage Grumble Posted October 1, 2014 Author Share Posted October 1, 2014 One day. Once i've spent heaps of time and money on the hilux, i'll no doubt sell it moments after finishing it. Its kinda my thing. Quote Link to comment Share on other sites More sharing options...
tortron Posted October 8, 2014 Share Posted October 8, 2014 make it look like dis. thats straight mexi-stance 5 Quote Link to comment Share on other sites More sharing options...
ODB Posted October 8, 2014 Share Posted October 8, 2014 I don't know if I care for your tone young man. Anyways, I bunged a poost gauge on it, its poosting 12psi, so could safely go 2-3 psi more. I also found the front is sitting on the bump stops, and the rear is about 10mm away, they have also removed the load spring, puhuhuhuhu. If anyone has a set of bog std rear springs laying about, i'll be ken on those. My side shed will be empty in 2 weeks, so will get stuck into it then, have also taken a week off to get it done. Oh, it runs around 2 psi at 100kmh, it it normal for turbo cars to run a little poost on the open road, or is it best to be completely off poost? Regards, VG. Pic of mine cruising at 100km/h Quote Link to comment Share on other sites More sharing options...
Vintage Grumble Posted October 8, 2014 Author Share Posted October 8, 2014 In the negative pressures ayyyy, interesting. I'll have to work out why mines boosting a little then. Guess it could be the added weight/aerodynamics/ratio of the lux causing it. I've done a small amount of tinkering with this, spent ages cleaning all the chips and melted lollies out of it, and then set about getting the speedo and tach to work. The speedo cable had snapped off behind the dash (which is odd) so have purchased a new one. My bro-in-law helped me work out how to get the lux rev counter working off the nissan ecu, so that should be all go soon. I have also purchased a set of tail (ones on it are buggered) and bumper lights (has gay balls clear ones on it now), i'm loving how cheap after market lux parts are. Scoping out the wiring, puhuhuhuhuhu. Some new bits. Also, while the dash was out, I thought i'd slap a poost gauge in. One of the few times i've got a bargain off TM, picked the little bugger up cheap. It juuuuuuuuuuuuuuuuuuuuust fits in, looks a bit silly, but hey, that's what the flat peak lyfe style is all about. I also decided, to cut down on costs, to run the 17's its already on, so will probably get it certed on them. I have next week off, so will swap out the rusty doors for pink ones, jack it back up, and make drive shaft hoops. And if they can take it, maybe drop it at panel beaters to get pillars done. Mean. Regards, VG. Quote Link to comment Share on other sites More sharing options...
Yowzer Posted October 8, 2014 Share Posted October 8, 2014 Smaller churbro / lower A/R turbine housing will allow it to spool with less exhausts, so it's probably all gee 1 Quote Link to comment Share on other sites More sharing options...
Spencer Posted October 8, 2014 Share Posted October 8, 2014 Get a black face/bevel boost gauge you show pony. 3 Quote Link to comment Share on other sites More sharing options...
ODB Posted October 8, 2014 Share Posted October 8, 2014 If aimed at me was sitting in the garage unused so chucked it on. If aimed at VG I agree: show pony lols Quote Link to comment Share on other sites More sharing options...
LWL1FE Posted October 8, 2014 Share Posted October 8, 2014 I have a courier with a standard SR20DET T25 engine/turbo. At 100kmh it sits well into the vacuum so I doubt its a weight or aerodynamics issue your having. Even if your ratio had your rpm at around 4k (being generous) at that speed, you should still be seeing some vacuum. I'm running BB T28 on both my SR20det silvia and 1ggte Cressida and both of those are also running vacuum at cruising speeds (around 3200ish rpm). Sorry I can't actually tell you what might be causing yours to run pressure. Dud gauge maybe? Quote Link to comment Share on other sites More sharing options...
Vintage Grumble Posted October 8, 2014 Author Share Posted October 8, 2014 Get a black face/bevel boost gauge you show pony. It was $1 reserve though/didn't think about the colour tbh. I have a courier with a standard SR20DET T25 engine/turbo. At 100kmh it sits well into the vacuum so I doubt its a weight or aerodynamics issue your having. Even if your ratio had your rpm at around 4k (being generous) at that speed, you should still be seeing some vacuum. I'm running BB T28 on both my SR20det silvia and 1ggte Cressida and both of those are also running vacuum at cruising speeds (around 3200ish rpm). Sorry I can't actually tell you what might be causing yours to run pressure. Dud gauge maybe? I need to do some research, I don't understand churbros well enough to figure it out. I'm not expecting it to be great on gas, but assume it will be better if its off boost. The gauge I was using was quite a flash Wika industrial gauge, so should be accurate. Will sort it out in the future, its not a huge concern, but thanks for the info, very handy to know. Also, in reply to my parts request, "Are you still interested over this item placed for wanted,i have it for sales,in a good working condition,let me know your interest and i will forward you pictures of the item, Greeting from Belarus, Mrs Hannah." Seems legit ......... Quote Link to comment Share on other sites More sharing options...
Yowzer Posted October 9, 2014 Share Posted October 9, 2014 Check where the gauge is tapping its pressure feed from. Sometimes people plug them in before the throttle body / off the waste gate line, instead of the manifold. Quote Link to comment Share on other sites More sharing options...
Vintage Grumble Posted October 9, 2014 Author Share Posted October 9, 2014 Oh. That may be my problem. It was connected to the waste gate line. Derp. Cheers boss! 1 Quote Link to comment Share on other sites More sharing options...
ODB Posted October 9, 2014 Share Posted October 9, 2014 Think it should be on the vac line that goes to the FPR. Quote Link to comment Share on other sites More sharing options...
Duddley Posted October 9, 2014 Share Posted October 9, 2014 Plug a duck call on the BOV OOOOORRRR a dog whisle. then dogs will go nuts and annoy their owners and they will be super annoyed and the world will be a better place 4 Quote Link to comment Share on other sites More sharing options...
