kyteler Posted August 31, 2013 Share Posted August 31, 2013 I have about 3.3m slab to rafter gap at the lowest point and if the outside height of the slab the shed it on is consistent across the width I have roughly 210-225mm. Should be pretty okee dokee, yeah? Quote Link to comment Share on other sites More sharing options...
Bling Posted August 31, 2013 Share Posted August 31, 2013 Only guessing as can't see how it's formed, but i'd 'guess' the pad will be thinner. Only 100% sure way is to drill a hole for depth. Perhaps they did slabs differently back in the day though. But everything i've ever seen has footings around the edge for the weight of the walls / roof that sits on it. http://images.doityourself.com/stry/g-a.gif 1 Quote Link to comment Share on other sites More sharing options...
kyteler Posted August 31, 2013 Share Posted August 31, 2013 Yeah, planned to drill down regardless just for peace of mind. Quote Link to comment Share on other sites More sharing options...
evil_si Posted August 31, 2013 Share Posted August 31, 2013 My old garage slab was 200mm on the perimeter footing /where the concrete had overflowed, and only 50-60mm over the pad it self It wasn't thick enough to secure my linisher properly, and cracked around it after some decent use Quote Link to comment Share on other sites More sharing options...
thorburnville Posted September 1, 2013 Share Posted September 1, 2013 I purchased one of the cheapy single phase peak clear floor hoists from gdc. Hasn't disappoint me yet(apart from 19mm dynabolts, good luck trying to find a 19mm masonary drill)The instructions recommend 200mm of a certain density. GDC said 100mm would be fine and so did the installer I spoke to.Lift time isn't noticeably longer then any 3 phase hoist. Quote Link to comment Share on other sites More sharing options...
Rookie Posted October 16, 2013 Author Share Posted October 16, 2013 Seeings as I put this in spam. Decided to go with the Waikato Shed Company. Consent is underway as we speak. 2 Quote Link to comment Share on other sites More sharing options...
Vintage Grumble Posted October 16, 2013 Share Posted October 16, 2013 YOU HAVE A FIRST GEN SWIFT? Quote Link to comment Share on other sites More sharing options...
Rookie Posted October 16, 2013 Author Share Posted October 16, 2013 AND YOUR MUM APPARENTLY. Quote Link to comment Share on other sites More sharing options...
Vintage Grumble Posted October 16, 2013 Share Posted October 16, 2013 IS THAT HER IN THE CARDEY? Quote Link to comment Share on other sites More sharing options...
Rookie Posted October 16, 2013 Author Share Posted October 16, 2013 INDEED. Quote Link to comment Share on other sites More sharing options...
Vintage Grumble Posted October 16, 2013 Share Posted October 16, 2013 HI MUM! Quote Link to comment Share on other sites More sharing options...
stillway Posted October 16, 2013 Share Posted October 16, 2013 had a quick skim through - only thing I'd add is I wish I put few extra power points on the hoist side of the shed when it was built. other than that looks solid. Quote Link to comment Share on other sites More sharing options...
HighLUX Posted October 16, 2013 Share Posted October 16, 2013 electric winch mounted to the concrete against the rear wall would be a sweet idea for when you have a shitty old car with half flat tyres semi seized brakes/wheelbearings and nobody around to help push it in the shed 4 Quote Link to comment Share on other sites More sharing options...
Rookie Posted October 16, 2013 Author Share Posted October 16, 2013 I try to avoid cars like that tbh. Quote Link to comment Share on other sites More sharing options...
ryanfels Posted October 16, 2013 Share Posted October 16, 2013 Dont you own an alfa? 4 Quote Link to comment Share on other sites More sharing options...
KKtrips Posted October 16, 2013 Share Posted October 16, 2013 9 Quote Link to comment Share on other sites More sharing options...
Rookie Posted October 16, 2013 Author Share Posted October 16, 2013 3/10 for that iceburn. Quote Link to comment Share on other sites More sharing options...
xsspeed Posted October 16, 2013 Share Posted October 16, 2013 8.5/10 you have a conflict of interest with that rating there handsome Dave 1 Quote Link to comment Share on other sites More sharing options...
Rookie Posted October 16, 2013 Author Share Posted October 16, 2013 Hardly, my Alfa has never broken down. Quote Link to comment Share on other sites More sharing options...
CaMpylobacter Posted October 16, 2013 Share Posted October 16, 2013 JINXED IT LOOKS LIKE A DOPE AS SHED. TRY GET A DRAIN PUT IN THE FLOOR SOMEWHERE LIKE A HOTEL BATHROOM. I OFTEN WISH I HAD THAT STZ. EVEN IF IT'S A SUMP THAT YOU PUT A LITTLE SUBMERSIBLE PUMP IN. Quote Link to comment Share on other sites More sharing options...
