mad_max Posted September 14, 2011 Posted September 14, 2011 My van is just about due for a WOF and the reverse lights dont go, I havent really looked at them as not a problem but do you need them for a wof. And could I hook them up to a switch if theres something wrong with whatever makes them go when put into reverse. The previous owner got it a wof with them as is but think it was a bit dodgy as is a few things that needed doing even just after it got a WOF. Quote
KKtrips Posted September 14, 2011 Posted September 14, 2011 When I was doing WOF's they needed to either both go or neither go.. Weird rule I know.. I have a funny feeling now that if they are fitted they have to go so if you remove them then you shouldn't have a problem. Though I guess this wouldn't work if the reverse lights are part of the taillights.. Quote
ke70_83_dx Posted September 14, 2011 Posted September 14, 2011 Applicable legislation • Land Transport Rule: Vehicle Lighting 2004 Permitted equipment 1. One or two reversing lamps fitted at the rear of the vehicle. 2. A retrofitted pair of reversing lamps must be symmetrically mounted as far towards each side of the vehicle as practicable. Condition 3. A reversing lamp must be in good condition. Performance 4. A reversing lamp must operate in a way that is appropriate for the lamp and the vehicle. 5. A reversing lamp, when operated, must emit a diffuse light or a dipped beam of light that is substantially white (Note 3). 6. A reversing lamp must emit a steady light. 7. A reversing lamp may operate only when the reverse gear is engaged or the headlamps are turned off. 8. Where a reversing lamp comprises an array of light sources (eg LEDs), at least 75% of these must operate. Modifications 9. A reversing lamp that is affected by a modification: a) must meet equipment, condition and performance requirements, and does not require LVV specialist certification. Note 2 A reversing lamp that does not comply with condition and performance requirements must be made to comply or be disabled so that it does not emit a light. Quote
KKtrips Posted September 14, 2011 Posted September 14, 2011 Note 2 A reversing lamp that does not comply with condition and performance requirements must be made to comply or be disabled so that it does not emit a light. Sweet, need to both go or none go would be the winner.. Quote
durty Posted September 14, 2011 Posted September 14, 2011 Yeah my 360 kept blowing reverse light bulbs so I just removed the bulbs. Just make sure your extra careful cos other people have no idea you are reversing. Makes supermarket carparks etc interesting Quote
keltik Posted September 14, 2011 Posted September 14, 2011 Havnt had reversing lights in my wagon for 3 years now. Really should get around to hooking up the gearbox switch tbh, angle parks are annoying with no lights. Quote
mad_max Posted September 14, 2011 Author Posted September 14, 2011 Yea, Is a bit annoying reversing knowing that no1 knows your are, Wheres the fuse for them? There's no fuse in the fuse box for reverse lights, I assume they have one? Bulbs are good so something in wiring id say Quote
keltik Posted September 14, 2011 Posted September 14, 2011 9 times out of ten its the switch on the gearbox that packs a sad. I dont know about your van, but on my cars the switch has always just been screwed into the side of the box near the shifter linkages. Usually only $30-40 to buy a new one. Quote
mad_max Posted September 14, 2011 Author Posted September 14, 2011 Oh yea, Might just do that as id prefer to have them than not, But atleast i can get a wof without them Quote
Cullen Posted November 16, 2022 Posted November 16, 2022 Bump. Saw a conversation on fb today where a couple of wof inspectors say they won't pass a car that doesn't have reverse lights. It's been a decade have the rules changed? Quote
tortron Posted November 16, 2022 Posted November 16, 2022 14 minutes ago, Cullen said: Bump. Saw a conversation on fb today where a couple of wof inspectors say they won't pass a car that doesn't have reverse lights. It's been a decade have the rules changed? Please report their names so they can have corrective training Permitted, not required Quote
cletus Posted November 16, 2022 Posted November 16, 2022 No, they are not a required lamp edit. Beaten by a tortoise Quote
kicker Posted November 16, 2022 Posted November 16, 2022 Don't even need reverse itself for a wof Quote
Cullen Posted November 16, 2022 Posted November 16, 2022 Good to know. I was fairly sure you didn't need them but yeah these guys know it all. Quote
kws Posted November 16, 2022 Posted November 16, 2022 My wife was failed years ago because only one of two fitted reverse lights worked. We were told "if its there it must work", much like fog lamps. But saying that, I have also had cars pass where neither of the reverse lights have worked (dodgy inhibitor switch). Quote
ajg193 Posted November 17, 2022 Posted November 17, 2022 Quite a lot of old toyotas only came with one bulb fitted from factory. Either that or every old Toyota I have bought has had a bulb removed at one point. Quote
SOHC Posted November 18, 2022 Posted November 18, 2022 They are handy if you need to back up a long dark drive at night Quote
kws Posted November 18, 2022 Posted November 18, 2022 46 minutes ago, SOHC said: They are handy if you need to back up a long dark drive at night and for having people stop to let you out of a park Quote
