ke70_83_dx
Everything posted by ke70_83_dx
  1. I bought that exact K-box kit a few years ago. Its seemed very good quality and solved my leak. I am not aware of a similar locally available kit.
  2. If your in Palmy go have a chat to Warren at RimRite, he will give you an idea. http://www.rimrite.co.nz/
  3. Apparently ae86 rails don't bolt up perfectly- Two line up, one's very close, the other one's around ten mm off.
  4. Off road express http://www.offroadexpress.co.nz/Forums/viewtopic.php?f=94&t=27756&sid=6c52d10e951742434add12352468b864
  5. Applicable legislation • Land Transport Rule: Vehicle Lighting 2004 Permitted equipment 1. One or two reversing lamps fitted at the rear of the vehicle. 2. A retrofitted pair of reversing lamps must be symmetrically mounted as far towards each side of the vehicle as practicable. Condition 3. A reversing lamp must be in good condition. Performance 4. A reversing lamp must operate in a way that is appropriate for the lamp and the vehicle. 5. A reversing lamp, when operated, must emit a diffuse light or a dipped beam of light that is substantially white (Note 3). 6. A reversing lamp must emit a steady light. 7. A reversing lamp may operate only when the reverse gear is engaged or the headlamps are turned off. 8. Where a reversing lamp comprises an array of light sources (eg LEDs), at least 75% of these must operate. Modifications 9. A reversing lamp that is affected by a modification: a) must meet equipment, condition and performance requirements, and does not require LVV specialist certification. Note 2 A reversing lamp that does not comply with condition and performance requirements must be made to comply or be disabled so that it does not emit a light.
  6. http://www.billzilla.org/4agmods.htm
  7. Im currently running a pair of narva Plus 100's in my ke70 with new relay kit, was a major upgrade.
  8. well...... http://www.nzherald.co.nz/nz/news/artic ... d=10741545
