Valiant Posted March 3, 2023 Posted March 3, 2023 Cool. +1 for mig construction. Furniture tube and exhaust tube work great, the chain stays wont be very strong the way they are in the picture with small diameter tube? I'd be tempted to use one piece of large diameter with smaller chain stays at the end in a Y configuration. Quote
anglia4 Posted March 3, 2023 Author Posted March 3, 2023 No mig lol I only own a TIG. I’ll do a bit of reinforcing of the places that look a little weak. The chain stays will be 16mm furniture tube. Tie down points - tick Thanks! Quote
kicker Posted March 3, 2023 Posted March 3, 2023 I see quite a few cargo bikes daily now, most look as below. Good idea for a project though as most retail options seem to run close to 10k Quote
EpochNZ Posted March 3, 2023 Posted March 3, 2023 Atomic Zombie sell bike plans and instructions for all kinds of strange.... https://www.atomiczombie.com/plans/ 1 Quote
fletch Posted March 3, 2023 Posted March 3, 2023 Plz do the 3kw 48v hub motor and use a 72v battery pack. 3 Quote
anglia4 Posted March 3, 2023 Author Posted March 3, 2023 Wheelstands with the kids on the back? Quote
anglia4 Posted March 3, 2023 Author Posted March 3, 2023 2 hours ago, kicker said: I see quite a few cargo bikes daily now, most look as below. Good idea for a project though as most retail options seem to run close to 10k Yeah I priced up one from Alibaba and it wasn't as bad, but it was still going to be a lot of money and wasn't quite going tick all the boxes. Quote
anglia4 Posted August 9, 2023 Author Posted August 9, 2023 This arrived today. Very exciting. One week from order on Ali, so fast! 7 Quote
anglia4 Posted September 3, 2023 Author Posted September 3, 2023 https://www.trademe.co.nz/a/marketplace/sports/cycling/bmx/other/listing/4306610237 Need to clear some space so the BMX is up for grabs and the wobbly bike will be listed shortly too Quote
anglia4 Posted July 9, 2024 Author Posted July 9, 2024 I've been chipping away at designing this a bit more. A while back I did some fairly rudimentary beam element FEA on it to get an idea of what bars were important and what ones weren't to make sure its reasonably stiff for its weight. Its ended up looking like a bird cage, but its fairly light tube so it won't be overly heavy and it needs the geometric strength since its not brute forcing it with bigger steel sections. Every time I think "Right, thats enough designing, I can wing it from here" then I spot something that needs checking, and it ends in major changes... So at the moment I'm busy adding pretty much all the detail I can into the 3D model to set everything I can. I've modelled in the crank clearance, checked the chain lines, and at the moment I'm working on figuring out the dropouts. I had to add some bends into the diagonals at the front to leave room for the chain to run. And it turns out that the rear wheel I've got has an odd drop-out width and isn't symmetrical, so I've had to make the whole thing wider than I planned and will add a spacer to center it. I also drew up the main accessories I want for it so I could put useful provisions for mounting them. Which also saved me from having to do a few tube bends. I'm hanging out to start cutting steel. I might also order the battery cells this week, but I need to take some brave pills for a) the cost, b) the idea of welding together 100 lithium cells. 5 Quote
cubastreet Posted July 10, 2024 Posted July 10, 2024 Check this listing and their others, might find a good battery option 36v battery pack, 17~17.9Ah (0.644kWh) https://www.trademe.co.nz/4804346775 1 Quote
anglia4 Posted July 10, 2024 Author Posted July 10, 2024 Yeah I had been eyeing up one of the other trademe sellers for individual cells. Quote
Dr Danger Posted July 12, 2024 Posted July 12, 2024 Might have missed it, but how are you going to slow this puppy down? Quote
anglia4 Posted July 12, 2024 Author Posted July 12, 2024 I'm not at my computer to grab a screen shot, but I designed the mounts for a rear disc brake setup this morning. Planning to run cable operated disc brakes front and rear. Cable operated so that they are compatible with the levers that go with the electric motor kit, they have switches in them so when you pull the brake it cuts the motor. 1 Quote
anglia4 Posted July 12, 2024 Author Posted July 12, 2024 Also... "Dr. Danger" asking about slowing stuff down... what a world we live in. Quote
fletch Posted July 12, 2024 Posted July 12, 2024 1 hour ago, anglia4 said: I'm not at my computer to grab a screen shot, but I designed the mounts for a rear disc brake setup this morning. Planning to run cable operated disc brakes front and rear. Cable operated so that they are compatible with the levers that go with the electric motor kit, they have switches in them so when you pull the brake it cuts the motor. But how will you do big vrod burnouts if you can't hold the front brake at the same time 1 Quote
Dr Danger Posted July 12, 2024 Posted July 12, 2024 2 hours ago, anglia4 said: Also... "Dr. Danger" asking about slowing stuff down... what a world we live in. It's unlike me, but also - have trailered brats around on a feebly braked bike and do not recommend. Can cables make equal slows for same lever input compared to hydraulic? I'd imagine it will weigh a bit without brats and all their crap on the back. Quote
anglia4 Posted July 12, 2024 Author Posted July 12, 2024 Nah cable never quite work as well as hydraulic but will be miles better than anything oldschool Quote
