EURON8 Posted April 28, 2011 Share Posted April 28, 2011 when i pulled my manifold off to modify it the gasket was\got fucked. Just been toyota and partmaster and its discontinued and no listing. Need one asap. just grab some cork gasket material and punch out the holes????? Other ideas??? Quote Link to comment Share on other sites More sharing options...
kyteler Posted April 28, 2011 Share Posted April 28, 2011 The fuck? What motor is it? Quote Link to comment Share on other sites More sharing options...
Simon Posted April 28, 2011 Share Posted April 28, 2011 And what manifold? Quote Link to comment Share on other sites More sharing options...
EURON8 Posted April 28, 2011 Author Share Posted April 28, 2011 18rgeu I need the middle one. The intake manifold is in 2 parts Quote Link to comment Share on other sites More sharing options...
Raizer Posted April 28, 2011 Share Posted April 28, 2011 Quote Link to comment Share on other sites More sharing options...
kyteler Posted April 28, 2011 Share Posted April 28, 2011 So, it's and the chamber -> runner gasket on the intake mani? Either do as Hellraizer says or get some gasket paper and trace it then cut it up. Personally, I'd just high temp RTV it, because I'm lazy. Quote Link to comment Share on other sites More sharing options...
Brock-Lee Posted April 28, 2011 Share Posted April 28, 2011 fuck tracing it. put gasket paper on mani. hit with hammer until it is a gasket. done Quote Link to comment Share on other sites More sharing options...
d.p.n.s Posted April 28, 2011 Share Posted April 28, 2011 ^+1 or rubber hammer Quote Link to comment Share on other sites More sharing options...
EURON8 Posted April 28, 2011 Author Share Posted April 28, 2011 I think ill just ''borrow'' maniseal outta stephens work van and do that. Gonna be a cunt to get manifold in there without making a mess of the sealant. studs would be helpfull if i could get monifold in with them. have had to go for all bolts. Quote Link to comment Share on other sites More sharing options...
KKtrips Posted April 28, 2011 Share Posted April 28, 2011 The gasket will be available - try Repco.. http://www.nzgaskets.co.nz/catalogue/En ... ineID=2139 DK690 is the part number for the valve regrind set - so there must be just the inlet manifold gasket alone.. Quote Link to comment Share on other sites More sharing options...
peteretep Posted April 28, 2011 Share Posted April 28, 2011 fuck tracing it. put gasket paper on mani. hit with hammer until it is a gasket. done +2 Quote Link to comment Share on other sites More sharing options...
bubblegoose Posted April 28, 2011 Share Posted April 28, 2011 i use the round end of a spanner and a coco-pops box never failed yet Quote Link to comment Share on other sites More sharing options...
Simon Posted April 28, 2011 Share Posted April 28, 2011 I got a herb tea box for a thermostat gasket. Works. Quote Link to comment Share on other sites More sharing options...
BS5620 Posted April 28, 2011 Share Posted April 28, 2011 slight thread creep. Where can you get that three bond gasket stuff picutred from. Is it very expensive?? Quote Link to comment Share on other sites More sharing options...
DJZ Posted April 28, 2011 Share Posted April 28, 2011 Don't use maniseal. Anybody that can get NZ Gaskets stuff can get Three bond, Repco etc etc or you can get the same stuff in a Nissan tube from Nissan, my RB gasket set came with a tube in it. Quote Link to comment Share on other sites More sharing options...
bubblegoose Posted April 28, 2011 Share Posted April 28, 2011 toyota sell rtv stuff too its $128 i kid nots Quote Link to comment Share on other sites More sharing options...
Seedy Al Posted April 28, 2011 Share Posted April 28, 2011 Fuck, just get some gasket paper and use a small hammer to do it. Works mint everytime Infact I own a small ballpeen hammer for this very perpose Other wise three bond from somewhere will work But On that that note I to dissagree with using sealer on intake manifolds as there is room for the sealer to loosen and enter the engine/ valves/ yuck Quote Link to comment Share on other sites More sharing options...
CaMpylobacter Posted April 28, 2011 Share Posted April 28, 2011 yuh threebond comes from nzgaskets. i try and stay away from rtv only. gasket hammers rule. fuck paying $128 for a tube of rtv that's likely jsut a rebranded tube of threebond worth $30. Quote Link to comment Share on other sites More sharing options...
coldturkey Posted April 28, 2011 Share Posted April 28, 2011 if you care about your shit, dont use silicone. Its basically a bodge and not a long term solution, seen too much of this shizz. In the past I have got some gasket paper, snapped a ballpoint pen and spread a bit of ink on the manifold, then pressed the gasket paper against it to give me a outline to carve out with a craft knife. Pretty low tech but works. (Clean up the ink before re-assembly). Quote Link to comment Share on other sites More sharing options...
jakesae101 Posted April 29, 2011 Share Posted April 29, 2011 Fuck, just get some gasket paper and use a small hammer to do it.Works mint everytime Infact I own a small ballpeen hammer for this very perpose Other wise three bond from somewhere will work But On that that note I to dissagree with using sealer on intake manifolds as there is room for the sealer to loosen and enter the engine/ valves/ yuck small ball peen hammer was how i was taught and made many a gasket this way that i was too jew to buy Quote Link to comment Share on other sites More sharing options...
