Mitch.W Posted September 28, 2012 Share Posted September 28, 2012 this car is amazing! its going to look and sound sooo badass on the track! so keen to see this out there 1 Quote Link to comment Share on other sites More sharing options...
nick_m Posted September 29, 2012 Share Posted September 29, 2012 Oil cooler increase capacity plus cooling? This is probably the route Im going to take. The decrease in oil is pretty minimal anyway. Nick, yeah it is something I was wondering about, but I havnt really looked into it. What sort of coin are you looking at for a suitable setup? yeah ill add an oil cooler too, The accusumps arent too bad, About 200USD for the accumulator (3 Quarts) and about 200USD for the electric pressure switch. The pressure switch electronically controls the accumulator to empty when engine oil pressure drops below a set psi and refills once above it. They are just a hydraulic accumulator, when the time comes im going to talk to my hydraulic engineer mate as I bet he could whip something up for pretty cheap Quote Link to comment Share on other sites More sharing options...
flyingbrick Posted October 23, 2012 Share Posted October 23, 2012 belzona 1111 ? if so- that shits great huh! looks good man! Quote Link to comment Share on other sites More sharing options...
bean.101 Posted October 24, 2012 Share Posted October 24, 2012 Man you are making sweet progress, its going to be mean on the track. Craig is really good to work with. He does a bit of machining for my work. Quote Link to comment Share on other sites More sharing options...
nothingsfree Posted October 25, 2012 Author Share Posted October 25, 2012 Cheers boys, yeah getting there slowly. This thing is an exersise in doing things the hard way because of the wheels I wanted to run, and the height I wanted it at, while still making it work properly haha. Quote Link to comment Share on other sites More sharing options...
nothingsfree Posted October 25, 2012 Author Share Posted October 25, 2012 Also, Iv decided to upgrade my front brake set up (again), so if anyone is interested in a decent upgrade for ae86 struts, let me know.. Quote Link to comment Share on other sites More sharing options...
mikuni Posted October 25, 2012 Share Posted October 25, 2012 This thing is an exersise in doing things the hard way because of the wheels I wanted to run, and the height I wanted it at, while still making it work properly haha. haha. I know exactly what you mean. But at the end of the day, that's the whole point of it really. Quote Link to comment Share on other sites More sharing options...
nick_m Posted November 20, 2012 Share Posted November 20, 2012 Hey dude what are the rotors you are using on the back?, might do the same brake setup on the back of mine Quote Link to comment Share on other sites More sharing options...
SuspectZero Posted November 22, 2012 Share Posted November 22, 2012 i'm speechless... i like the time and attention you have given this build. The welds look really neat and solid. i'm sure it will turn out great. i plan on doing the same swap > ke70+beams 3s. i dont think i can do it as perfectly as you, but after seeing this, i have to try. i didnt quite get the mode/car that you got your diff from... which type of dyna was it? dyu know? also, who did for you the tuning on the Link G4? does it come already tuned? do you have plans for a roll cage? Lastly, do you have any other vids of this build apart from this one? share? Quote Link to comment Share on other sites More sharing options...
nothingsfree Posted November 23, 2012 Author Share Posted November 23, 2012 Hey Nick, drop round sometime for a yarn, got a few things you maybe interested in.. Quote Link to comment Share on other sites More sharing options...
nothingsfree Posted November 23, 2012 Author Share Posted November 23, 2012 i'm speechless... i like the time and attention you have given this build. The welds look really neat and solid. i'm sure it will turn out great. i plan on doing the same swap > ke70+beams 3s. i dont think i can do it as perfectly as you, but after seeing this, i have to try. i didnt quite get the mode/car that you got your diff from... which type of dyna was it? dyu know? also, who did for you the tuning on the Link G4? does it come already tuned? do you have plans for a roll cage? Lastly, do you have any other vids of this build apart from this one? share? Cheers bro. Sorry unsure of what model the diff was out off as i bought it as a bare diff. The engine hasnt been tuned yet, but it will be going to NZEFI when it is ready. Currently it is running on the map that Surfab had on his Link for his 3s. But you can load on a base map that will be enough to get the engine running at least if you buy a Link. Yeah cage is near the top of the to do list now, hopefully in Dec sometime.. No other vids at the mo, but hoping to have an exciting update in the next week or two.. Quote Link to comment Share on other sites More sharing options...
nothingsfree Posted December 11, 2012 Author Share Posted December 11, 2012 Right, who has worked out matching master cylinders to calipers? Cardwells recommended a 3/4inch master for the Dynalites, I just need to then match that to the 2pots on the back. Anyone able to help? Quote Link to comment Share on other sites More sharing options...
escortwags Posted December 12, 2012 Share Posted December 12, 2012 might be useful in regards to masters, have bleed mine up and they feel boss! specs are as follows all on a floor mount pedal box (bar handbrake) front - FC3S 4 piston - Tilton .625 master rear - S14 silvia single piston - Tilton .75 handbrake - Tilton .75 clutch - Tilton .70 Wouldn't want it any harder on the front brakes unless you had popeye legs Quote Link to comment Share on other sites More sharing options...
nothingsfree Posted December 17, 2012 Author Share Posted December 17, 2012 Sweet, thanks bro. I ended going and have a yarn to Les Hunter about what would be my best option. His recommendation with the size of the pistons in my calipers, was to start with a 3/4inch master for both front and rear systems. And then play with the balance bar to figure what feels good, and has a good bias. Quote Link to comment Share on other sites More sharing options...
ryanfels Posted January 10, 2013 Share Posted January 10, 2013 Was this going back on the road? because i dont think that crossmember will pass a cert Quote Link to comment Share on other sites More sharing options...
nothingsfree Posted January 12, 2013 Author Share Posted January 12, 2013 Yeah its a race car, but I am intending to get it road legal. What would be the issue with the cross member good sir? Quote Link to comment Share on other sites More sharing options...
k2dori Posted January 30, 2013 Share Posted January 30, 2013 so damn awesome! love your work Quote Link to comment Share on other sites More sharing options...
KE11Beams Posted February 13, 2013 Share Posted February 13, 2013 Hi, Just want to say awesome work on your KE70!!! I am very impressed with the work you doing. I am currently building a KE11 with a 3SGE Beams engine and I am very interested in your oil pan mod. Have you had any road/track experience with this setup yet and how much oil capacity did it remove from the system after this mod??? I also need to raise the pan up for clearance issues and think this could possibly be the way to go without building a new pan. Thanks Luke PS. Need more updates Quote Link to comment Share on other sites More sharing options...
nothingsfree Posted February 19, 2013 Author Share Posted February 19, 2013 Cheers dude, yeah Surfab had a reduced capacity sump in his ae85 (especially after smashing it a few times), and he had no issues with oil pressure etc on the track, and that thing got a hiding. Didnt bother to measure how much capacity changed, it had to be done regardless to give me some clearance. I have a bunch of updates that I need to get round to writing up.. Quote Link to comment Share on other sites More sharing options...
My name is Russell Posted February 19, 2013 Share Posted February 19, 2013 Looking good keep the updates coming Quote Link to comment Share on other sites More sharing options...
