SuspectZero
New Members
Everything posted by SuspectZero
  1. i found this somwhere on the net. it should be helpful to u guys.... Identifying Toyota Hilux & Hiace Differentials The Toyota Hilux has ID plates fitted in the engine bay, while the Hiace has them fitted near the base of the front seats. In each case one of the plates will have the 'Axle' code originally fitted to the vehicle. As an example a RN25 Hilux manufactured during the 2/74 has the 'Axle' code "G142". The letter "G" signifies it has a "G" series differential and therefore an 8" diametre crownwheel. The next two digits, "14", nominate the ratio, which according the ratio table below is 4.875:1. Many of the ratios have not been fitted to Australian vehicles nor are they all sold here as an aftermarket item. The 4.875 and above ratio centres have a slightly different crownwheel position on the centre. So if ratios below 4.875 are to be fitted then select a diff with a ratio below 4.875 or vice verca if shorter ratios are to be used. Two suppliers who have crownwheel & pinion sets are Sunstate 4WD & Jack McNamarra Diffs. The last digit, "2", is for the type of centre, in this case 2 Pinion & Open centre as per the centre table below. The factory LSD is a clutch pack type, while aftermarket suppliers offer these, plus a wide range of other types. RATIO TABLE Code Ratio Code Ratio Code Ratio Code Ratio 01 3.300 13 4.790 25 4.556 37 3.583 02 3.360 14 4.875 26 5.571 38 3.417 03 3.545 15 5.125 27 3.364 39 3.154 04 3.556 16 5.286 28 4.300 40 5.375 05 3.700 17 5.600 29 4.100 41 3.308 06 3.889 18 5.714 30 3.727 07 3.900 19 5.833 31 3.909 08 4.110 20 6.167 32 6.591 or 4.807 09 4.222 21 6.667 33 7.503 or 5.583 10 4.375 22 6.780 34 6.781 or 4.786 11 4.444 23 6.833 35 7.636 or 5.600 12 4.625 24 7.640 36 4.778 CENTRE TABLE Code Centre Type 2 2 pinion open centre 3 2 pinion limited slip centre 4 4 pinion open centre 5 4 pinion limited slip centre The Toyota Hilux & Hiace Differentials The Toyota Hilux and Hiace differentials are all similar in design. They feature an 8" crownwheel, 31 spline axles and large bearings. They have ample capacity for an Escort and a converted Hilux diff will weigh about 60kg. Common ratios to be found at wreckers in Australia are from 4.110:1 to 4.875:1. The taller ratio of 3.7:1 was delivered with V6 vehicles in the USA. Aftermarket suppliers in Australia have gear sets of 3.5:1, 3.7:1 etc. available new. The closest fit for an Escort is the Hilux 2WD diff from RN10, RN15, RN20 & RN25 models manufactured during the first half of the 70's. Each of these has the same spring centres (940mm) and overall width (1350mm) as an Escort. The spring platform width is equal to the MkII Escort at 60mm but wider than a MkI which has 50mm width springs. What needs to be modified ? Axle Shafts and Flanges These axles have five M12x1.5mm studs on a 4.5" PCD and will require restudding to match the MkII Escort pattern of four M12x1.5mm studs on a 4.25" PCD. The Hilux studs are longer than Escort studs. The MkI Escort has 7/16"UNF studs on a 4.25" PCD. The drum/wheel location boss on the Hilux axle is Ø67mm compared to the Escorts Ø63mm. If Escort drum brakes are to be used then the boss must be machined down. If an upgrade to larger drums or disc brakes is chosen then the boss may need changing in size to suit the alternate drum or disc centre hole. Some Escort mag wheels may fit over the Hilux boss but standard wheels and some mags will require the boss to be Ø63mm where it protrudes out further than the drum or disc and into the wheel. If alternate discs are fitted over the axle flange this will increase the overall width of the diff by the thickness of the disc bell on each side of the diff. So if discs with a bell thickness 7.5mm are fitted then the overall diff width will be 1350+7.5+7.5=1365mm. Check your tire clearance to the guards and track width requirements. Most of the axle shaft fitted to the RN10-25 models have sufficient spline length for the axle to be shortened a small without the need for re-splining, but work out what you need and measure the axles before purchase. Brakes The Escort drum brake backing plates will need the centre hole size and bolt pattern changed to fit over the Hilux bearing carrier. The backing plate will need a spacer behind it so that the drum properly covers the brake shoes. Upgrading the brakes to discs has been done and reuse of the Hilux drum system may be possible. Differential Centre The ratio and type of the centre that is factory fitted to RN10-25 Hilux may not be suitable or serviceable considering the age. Options are to fit a diff centre from another later model Hilux or Hiace that has a suitable ratio or Limited Slip centre for example. Other options are to fit aftermarket ratios or Limited Slip Differential centres and new bearing and seals. If the chosen ratio is different to standard and an accurate speedo is required, the speedo accuracy will need checking and correcting. Differential Housing If Escort drum brakes are retained the handbrake linkage brackets and hydraulic line bracket will need fitting to the Hilux housing. If the factory style anti tramp rods are to fitted then these will need fitting to the Hilux housing at the correct angle relative to the spring platforms. For originality sway brackets would also need fitting to the Hilux housing at the correct angle relative to the spring platforms. If discs, tyre clearance etc. dictate shorter axles then the housing will also have to be shortened by an equal amount on each side. With the exception of tramp rods, the brackets can normally be cut from a donor Escort housing. Shackles and Shackle Plates The RN10 - 25 Hilux housing axle tubes are Ø65mm and 5.5mm thick compared to an Escort axle tube at Ø63mm and 3.2mm thick. The Escort shackles fit over this housing, alternatively the slightly larger diameter Hilux shackles will fit through the Escort shackle plate. The MkII Escort shackle plates will not require modification to use this Hilux diff housing. Spring Platforms To prevent rapid universal joint wear and tailshaft vibration, the operating angles of front and rear universal joints need to be similar, eg: less that 1° difference in operating angle. The angle required will varies depending on whether anti tramp rods are fitted and the curvature/rating/ride height of the leaf springs. Anti tramp rods and stiffer leaf springs reduce the amount the diff nose lifts under power where as leaf spring curvature and ride height alter the static position of the diff nose. The angle of the spring platform to the pinion needs to be checked and altered, if necessary, by relocating the spring platforms around the axle. If this diff is fitted to MkI leaf springs, the 50mm wide MkI Escort spring platforms will need to be fitted to the Hilux Diff. Tailshaft The 1 peice Escort tailshaft that has replaceable universals has the same universal as most of the Hilux/Hiace units, but the tailshaft will need shortening and a Hilux flange fitted to the universal. Other Hilux & Hiace Diffs Later Model Hilux 2WD The later model, particularly 80's on, 2WD hilux diffs are to wide to be useful in an Escort fitted with wider tyres. The axles do not suit re-splining as they are machined down behind the existing spline for too great a distance. They may provide the ratio you are looking for though. Hilux 4WD The Hilux 4WD diffs are generally 20mm narrower than an equivalent year 2WD diff. Some of the axles have an extra length spline that may be shortened without the need for re-splining, in particular check out the RN46 manufactured around 4/83. All 4WD axles have 6 wheel studs and can be re-drilled for an Escort stud pattern without the need for welding up the old stud holes. The 4WD housings are the least suitable as they are step up in diameter toward the centre and will cause mounting hassles for brackets and shackles. The 4WD centres will in some cases be Limited slip units and may contain suitable ratios. Hiace The Hiace diffs are all to wide for an Escort. The housings are the same style as the 2WD Hilux but the axle tube dimension is 68mm x 62mm oval and 4.5mm wall thickness. Use of this housing represents a small weight saving which may be cost effective if the 2WD housing for your application requires shortening and other alterations. The Hiace centres may also have the ratio you are looking for. The mid 90's Hiace is fitted with a wheel stud that has extra spline length. These may prove useful for a disc brake setup.
  2. i'm speechless... i like the time and attention you have given this build. The welds look really neat and solid. i'm sure it will turn out great. i plan on doing the same swap > ke70+beams 3s. i dont think i can do it as perfectly as you, but after seeing this, i have to try. i didnt quite get the mode/car that you got your diff from... which type of dyna was it? dyu know? also, who did for you the tuning on the Link G4? does it come already tuned? do you have plans for a roll cage? Lastly, do you have any other vids of this build apart from this one? share?
  3. i guess "doubting-Thomas" hasnt had a chance to drive a 4age 20v blacktop Carina gt with a 6 speed manual transmission...
  4. //oldschool.co.nz/index.php?/topic/35172-post-your-0-60mph-times/
  5. actually If u add power to weight ratio into the equation then the 3sge KE70 should make about 5 seconds, 0-60. ... How about you save us all the maths and just do random 0-60mph sprints and tell us how it goes?? meanwhile, I'm totally CONFUSED!!!! Here's why. i drove my pal's Carina GT yesterday and it was frickin FAST!! The sound of the engine was superb. and he's willing to sell it to me for peanuts coz he wants to top up on a WRX STI... Suddenly I'm now interested in the Carina GT. I WANT IT!! yet i cant own 3 cars. don't even know what to do. my wife will cut off my balls if i buy a third car... dunno what to do... here are some pics of the engine bay and interior
  6. Post your 0-60mph times for your oldskool rides Your car: model/year etc: engine: performance mods done to car: 0-60mph Time: i'll start: Your car: toyota Corolla Model/year etc: 1983 Engine: 4k Performance mods done to car: none yet 0-60mph Time: ...still counting...
  7. sure, i wonder what the 0-60 times are for a KE70 with an Altezza 3sge??.... like 6 or 7 seconds? :dontknow:
  8. Nice Carina bro,,,, like the color... too bad i cant view the other pics... keep going.... i'd like to see the massive torque of the 3rzfe in action!
  9. inspiration... These Rims could look really nice on yours... i see them in the pic on the left....
  10. yes... there are lots of them here... you would be suprised!
  11. Here's my KE70. still saving up for an Altezza Beams 3SGE ...
  12. Changed my Username to suspectZero... dont want my boss checking up on me.... @Simon - i live in Kampala city.... not that many potholes really. The suspension has very stiff King Springs (not the lowering type) and KYBs. dont know why its still high....
  13. heres an older look of the car....
  14. Hello Oldskool class of NZ, i'm new to this ... just wanted to share some pics of my GT but it looks like i need a little guidance on that.... finally! Random pictures: others:
