KE11 3SGE Beams
Hi guys and girls,
I only found this page the other day and thought I'd sign up and share my pride and joy. I bought her about 2 1/2yrs ago and have been slowly putting her together when funds, resources and knowledge permit. I will be getting her engineered here in NSW and have spoken with an engineer who is willing to sign of on it. The following is a run down on the specs so far.
Specs
Engine
-1999 3SGE Beams 2L w/6 speed manual
-4AGE Blacktop Quads w/ Glenn Booth manifold and throttle linkage
-Custom PWR alloy radiator
-Sam Q 110mm velocity stacks
-Adaptronic 440 Select ECU w/Innovate Wideband o2 sensor
-Race Technologies LCD Dash
-Custom wiring loom
-Original fuel tank w/LS1 intank pump mounted in Adapter plate
-Aeroflow -6AN 200 series fuel lines
-Turbosmart pressure regulator
Suspension
Front
-Ke20 Engine crossmember
-KE30 LCA's
-KE20 Castor Mounts
-KE30 Castor Rods (thread machine to suit 20 mounts)
-KE70 Steering rack w/Altezza column
-AE86 struts w/Otomoto 6kg coilover kit and pillow ball tops
-AE86 Power Steering Arms (extra lock)
-Hopper Stopper Big 2 piston brake kit w/braided lines and 114.3*5 pattern
-Custom made 22mm Signature SwayBar
Rear
-Ford EF XR6 LSD (shortened to suit) w/single piston calipers
-Custom 40mm lowering blocks
-Custom K.C.D.R 1 piece 3in tailshaft
-Custom made 19mm Signature Sway Bar
Brakes
-Custom mounted Tilton underdash pedal assembly
-5/8' front, 7/8' rear, 5/8'clutch master cylinders
-Custom brake & clutch lines w/Aeroflow -3AN 200 series braided lines
-Remote mounted Tilton brake/clutch reservior
In car
-Recaro Adjustable back seats
-Vintage Air underdash heater/demister
So currently the car is driveable but I will be pulling it down to finish the body work (finish weding tunnel and firewall in) and repair a few rust areas.
Plans for the future
-Finish wiring (high beam, horn, hazards)
-Sandblast underside of car, engine bay, interior floor, boot
-Seam weld entire car
-Paint and interior
-Registration
Also how do I go about uploading some pics for you guys & girls???
