danger Posted July 28, 2009 Share Posted July 28, 2009 Right. I currently have a 13b bridgey(not through water jacket) thats got cut up rotor bearings, not sure if the E shafts alright or not yet. I also have a good S4 13BT in parts with slotted rotors. Have alot of other stuff as well. I need to build a motor for my RX929 that i'll put together after finishing the RX7 also need to at some stage build a motor or use one of my 12as for my mazda 1000 ute. Was thinking of making the mazda 1000 a major project (cause so easy to work on and light) and would like to narrow and 4link the rear as well as a powerful enough motor to justify this. Logically most people would go 13BT for power. I'm wondering instead of whether to build a supercharged carb fed 13b bridgeport Probably wont be as much power but a hell of alot more torque (its a 13B so wont be going over 8-9k revs) and could possibly be very fun with a bridgeport as they dont idle due to low air speed at low revs this could possibly make it pulse along very nicely with more drivability but still making very good power and not having to invest in computers, injectors, turbos and all that shit. plus I prefer non turbo rotaries. Does anyone have any experience with this? I know its probably the wrong forum to ask. Would a bridgeport be ok? along with a slightly extended exhaust port? What carb/blower to use etc and any other precautions? May run dowells or better thru bolts but havent gotten that far yet. Quote Link to comment Share on other sites More sharing options...
thegreatestben Posted July 28, 2009 Share Posted July 28, 2009 Dunno if this can apply to rotaries but seedy al got himself a factory turbo blow through carb off've a rover afaik. Toyota SC14 for charger? Quote Link to comment Share on other sites More sharing options...
treggo Posted July 28, 2009 Share Posted July 28, 2009 I'm almost stupid enough to want to supercharge with carbs too. Quote Link to comment Share on other sites More sharing options...
UTERUS Posted July 28, 2009 Share Posted July 28, 2009 SC14 wouldn't even come close to supplying the amount of air a ported 13b would want, i'd be looking at an M90 or M112. They aren't very efficient but still pump a fair emount of air. Quote Link to comment Share on other sites More sharing options...
shizzl Posted July 28, 2009 Share Posted July 28, 2009 just go for a secondary bridge...decent size blower,ive seen skidder blowers on them.. or get a fancy yanky one... run a holley double pumper..and scoop. would be tall but would look sick. i remember andys 13b was real tall..i think it used a 64/7 or whatever the numbers are..and 1 or 2 300zx throttle bodies,microtech... i used to have a large wade blower off a skidder that i was gonna mount on a 13bt block. was going to use a 650 double pumper and elec dizzy. you wont need to dowel it if you dont run mass boost..id go 12psi.... i was looking at putting an a/c clutch or something onto the blower drive so it was switchable-mad max style.. just go onto ausrotary and search blower or supercharged and you should find some sweet set ups on there... realistically any jap factory blower wont be good enough... there used to be a 13b j port blown with 2 idas in a rx3 coupe years ago in hams.. sparked my keeness in rotors,until all the crossed up flat cappers with puffy shoes started owning them.... Quote Link to comment Share on other sites More sharing options...
danger Posted July 28, 2009 Author Share Posted July 28, 2009 Yeah was thinking holley double pumper on a 4/71 or something? And taller and stauncher the better. May run no bonnet stz 1000s have quite a cool shape engine bay having no strut towers etc Quote Link to comment Share on other sites More sharing options...
Black Francis Posted July 28, 2009 Share Posted July 28, 2009 wont something with sweet fuck all low down torque(ur engine) be a sack of shit if its having to turn a massive, yank style, supercharger? iduno just the bridgeport 13b will make heap o lot of power anyway so why bother? i will put my money where my mouth is and say buy a 20b import engine and run it stock standard minus the turboZ on an aftermarket computer. Will make oooodles of power and prob cost similar amout to this supercharging humbojumbo. Seen some ausis do similar and they make like 300kw+ mayyte. + has the added bonus of being a streetable engine and quite enough to be legal. thats my 50 cent this post was non constructive. Quote Link to comment Share on other sites More sharing options...
shizzl Posted July 28, 2009 Share Posted July 28, 2009 you wont loose bugger all power driving a blower.. blowers= constant boost,bridgey idle set to 1500rpm... burnouts on tap.. and itll be tuff Quote Link to comment Share on other sites More sharing options...
tenyearguarantee Posted July 28, 2009 Share Posted July 28, 2009 I was looking at supercharging my 12a until i saw how much money would go in for relatively little power gains. The M90 was the one i sized up based on the volume. Maybe it will do for the 13b as well. Looked into the dimensions of the thing and had to get one with a small snout as the thing would have been longer than my engine. Get a book called 'Supercharged!' by corky bell off amazon, about $40 delievered when i got it. Real good read,. Don't know what happened to the site but rotahavik.co.nz had a guy who had supercharged his 20b, he was pretty on to it with this type of thing Quote Link to comment Share on other sites More sharing options...
SHGWAG Posted July 28, 2009 Share Posted July 28, 2009 Might pay to check out the RX8 Supercharger kits, i know Blitz do one, just not sure it will be large enough for a full cut bridge. Also, saw above mentioned supercharged rx3 coupe at mere mere not too long ago, OSC Jismd everywhere & spent almost an hour just looking at / walking around it. Quote Link to comment Share on other sites More sharing options...
danger Posted July 29, 2009 Author Share Posted July 29, 2009 wont something with sweet fuck all low down torque(ur engine) be a sack of shit if its having to turn a massive, yank style, supercharger? iduno just the bridgeport 13b will make heap o lot of power anyway so why bother? i will put my money where my mouth is and say buy a 20b import engine and run it stock standard minus the turboZ on an aftermarket computer. Will make oooodles of power and prob cost similar amout to this supercharging humbojumbo. Seen some ausis do similar and they make like 300kw+ mayyte. + has the added bonus of being a streetable engine and quite enough to be legal. thats my 50 cent this post was non constructive. Not confident I have enough room for a 20b but the thought has crossed my mind New style more efficient wee superchargers Quote Link to comment Share on other sites More sharing options...
Black Francis Posted July 29, 2009 Share Posted July 29, 2009 20b aint that much larger/make it fit.... i was at a car wreckers once geting some wheels and they had a 20b JC halfcut. Engine was good compression and had startup warrenty etc. They wanted 5g for the halfcut. what about a renesis + 6 speed? then again... Carbs and noise are cool try find that guy that had the supercharged dark green rx4. He used to be on rotahavik so yeh. He will know what to do Quote Link to comment Share on other sites More sharing options...
escortwags Posted July 29, 2009 Share Posted July 29, 2009 its very doable, just get a bigy blower and biggy balls, and build a motor that can handle the pain. have a search around ausrota to get some ideas, here's Justins nice wee wagon thats here in N.Z, sounds like satin screaming!!! Quote Link to comment Share on other sites More sharing options...
Mick Doohan Posted July 29, 2009 Share Posted July 29, 2009 m112 or 671 .. minimum anything else is just poo's Quote Link to comment Share on other sites More sharing options...
Simon Posted July 29, 2009 Share Posted July 29, 2009 Know where theres a 20b in a jet boat that the owner complains has no torque and uses too much fuel. Will find out more / straight swap him a 350 chev. Quote Link to comment Share on other sites More sharing options...
durty Posted July 29, 2009 Share Posted July 29, 2009 sounds like satin screaming!!! man i love the sound of fabric screaming Quote Link to comment Share on other sites More sharing options...
Mr.Mk1 Posted July 30, 2009 Share Posted July 30, 2009 Thats been in My favourites for ages. Quote Link to comment Share on other sites More sharing options...
escortwags Posted July 30, 2009 Share Posted July 30, 2009 lol its my birthday give me a brake engrish + fast typing is never my thing ***SATAN either way its f**king mint and you can beat the sound more details of it on my mates blog http://octaneculture.wordpress.com/ check out his R100 to..should be a sweet little racecar once weve finished it Quote Link to comment Share on other sites More sharing options...
RUNAMUCK Posted July 30, 2009 Share Posted July 30, 2009 I can remember that 3 being in nzpc way back before it became a hardcore fail publication. Quote Link to comment Share on other sites More sharing options...
sentra Posted July 30, 2009 Share Posted July 30, 2009 just do what ever the australians do, there rotarys are faster then ours, there all simple big turbo setups, theres a guy on here who im suprised hasnt spoken up? ? Quote Link to comment Share on other sites More sharing options...
