peteretep Posted October 27, 2014 Share Posted October 27, 2014 nah it was from motorsport tools, I think the brand was rix, apparently an exact copy of gartrac 1 Quote Link to comment Share on other sites More sharing options...
Rookie Posted November 16, 2014 Share Posted November 16, 2014 NICE!!! What did you guys fuck up to make it not run? Quote Link to comment Share on other sites More sharing options...
kyteler Posted November 16, 2014 Share Posted November 16, 2014 They've clearly installed the intake and exhaust valves in the wrong way. 4 Quote Link to comment Share on other sites More sharing options...
peteretep Posted November 16, 2014 Share Posted November 16, 2014 i'm not quite sure, its flaming out all intake ports with injectors set at 19lbs as you suggested The fuel holds quite good at about 46psi but appears to have air in it (sub par return line routing related), not sure if thats an actual problem though we tested the ignition quite a bit and it seems to be sweet, not getting interference/misfires but im still not 100% on the timing. will the engine run if timing is 10 degrees out either side of tdc? hall effect isnt missing any teeth Quote Link to comment Share on other sites More sharing options...
kyteler Posted November 16, 2014 Share Posted November 16, 2014 It's gotta be timing for flame to be able to escape out the intake port before the valve closes. Well, either timing or incorrect firing order. Quote Link to comment Share on other sites More sharing options...
Abarth Posted November 16, 2014 Share Posted November 16, 2014 Check the firing order mate. My Fiat shot flames like that out the side drafts after I mistakenly put the spark plug leads back on wrong. Quote Link to comment Share on other sites More sharing options...
xygtho Posted November 16, 2014 Share Posted November 16, 2014 Remember hearing about a type of misfire years ago that has something to do with when the carbs are designed to suit engines with a different intake pulse? Some shit like that. But Id agree with comments above that ignition timing or incorrect firing order would be the first place to start. Hope you get it sorted and its a simple fix. Car looks awesome BTW Quote Link to comment Share on other sites More sharing options...
Ned Posted November 16, 2014 Share Posted November 16, 2014 firing order is sweet (1, 4 and 2, 3 together for wasted spark), and timing appears sweet (enough). Pete is pulling the rocker cover off to check cam timing, as we're lost for ideas at this point Quote Link to comment Share on other sites More sharing options...
sentra Posted November 16, 2014 Share Posted November 16, 2014 check both the front lobes on both cams are pointing toward each other at tdc comp side 1 Quote Link to comment Share on other sites More sharing options...
peteretep Posted November 16, 2014 Share Posted November 16, 2014 ohv single cam so a fucking pain to check cam timing. half the motor has to come apart to check properly so I will try to check from the rockers and find cam specs. im 99% sure the cam timing is right though Quote Link to comment Share on other sites More sharing options...
Testament Posted November 16, 2014 Share Posted November 16, 2014 use piston stop to check TDC and 100% confirm the trigger angle for the hall effect sensor. also make sure you have flashed the microsquirt to the latest 3.3.2 MS2/Extra code. Quote Link to comment Share on other sites More sharing options...
Ned Posted November 16, 2014 Share Posted November 16, 2014 Has been flashed with latest version from the website (unsure what rev number that was though) Just make sure the valves open and close as you'd expect in regards to TDC etc? only way you get constant flames like that is when the intake ports are still popen when it fires, and the timing light seems to say its legit, so wouldnt hurt to check the cam. Cam (the person) said he's gonna use my scope to check for noise properly to rule that out, and then set the base timing with the plugs out so it cranks nice and quick. and go from there? Might pay to find a dial gauge? Quote Link to comment Share on other sites More sharing options...
Testament Posted November 17, 2014 Share Posted November 17, 2014 Piston stop. Dont muck about with a DTI its not accurate due to piston dwell at tdc Quote Link to comment Share on other sites More sharing options...
Rookie Posted November 17, 2014 Share Posted November 17, 2014 Good Jerb Peter. Quote Link to comment Share on other sites More sharing options...
peteretep Posted November 17, 2014 Share Posted November 17, 2014 timing was wrong, then it started no problem 4 Quote Link to comment Share on other sites More sharing options...
Rookie Posted November 17, 2014 Share Posted November 17, 2014 I knew Quote Link to comment Share on other sites More sharing options...
Roman Posted November 17, 2014 Share Posted November 17, 2014 Feck yeah! Great work Quote Link to comment Share on other sites More sharing options...
Ned Posted November 17, 2014 Share Posted November 17, 2014 dig it! Quote Link to comment Share on other sites More sharing options...
shaneo Posted November 17, 2014 Share Posted November 17, 2014 Cant wait to see this going in the flesh Quote Link to comment Share on other sites More sharing options...
punkoutnz Posted November 17, 2014 Share Posted November 17, 2014 "The first startup video". Lies! It's always the second startup that you film cos you forgot to do the first one. Good work though team. Should be rocking for monthly meet tomorrow then aye Quote Link to comment Share on other sites More sharing options...
