peteretep Posted August 19, 2013 Share Posted August 19, 2013 Nah I havent ever rebuilt it, so its age is unknown. Pcv valve was removed and now it is just a 1/2" line from crank case to the oil catch can. It breathes quite heavily/visibly even at idle but does not build up much fluid Quote Link to comment Share on other sites More sharing options...
Spencer Posted August 19, 2013 Share Posted August 19, 2013 All signs point to ring seal for me. Quote Link to comment Share on other sites More sharing options...
Rookie Posted August 19, 2013 Share Posted August 19, 2013 Breathing heavy and low compression are just Kent lyfe. Your cam will be stealing a bunch of static compression aswell. Quote Link to comment Share on other sites More sharing options...
bigfoot Posted August 19, 2013 Share Posted August 19, 2013 My lancer had similar symptoms(fog blowing out catch can) found 2 broken rings Quote Link to comment Share on other sites More sharing options...
peteretep Posted August 20, 2013 Share Posted August 20, 2013 even english people were concerned with those pressures, they expected at least 150psi maybe a good reason to machine cutouts in pistons and fit a bigger cam Quote Link to comment Share on other sites More sharing options...
Spencer Posted August 20, 2013 Share Posted August 20, 2013 You would be hoping for something around 150ish, but yea I don't know your cam specs. Get a spare kent a build something fresh on the side? its no doubt a little tired. Quote Link to comment Share on other sites More sharing options...
Rookie Posted August 20, 2013 Share Posted August 20, 2013 Do you know what the compression ratio is supposed to be Pete? The only reason I'm not worried is my Kent is a LC one and I put the same cam in it as yours and I have similar Psi readings. Quote Link to comment Share on other sites More sharing options...
peteretep Posted August 20, 2013 Share Posted August 20, 2013 nah not sure what compression should be heres the specs on my cam http://www.kentcams.com/product-details/92/Camshaft/Camshaft/BCF2-Fast-Road/ only problem with building up another motor is that I would struggle to find a block that could be taken out to 1800 like what I have now, but I could do that Quote Link to comment Share on other sites More sharing options...
punkoutnz Posted August 20, 2013 Share Posted August 20, 2013 Why not just pick up a stockish motor to chuck in while you rebuild the one you have then? Quote Link to comment Share on other sites More sharing options...
peteretep Posted August 20, 2013 Share Posted August 20, 2013 with oil in cylinder 1, it went from 130psi to 140 and cylinder 4 went from 115 to 135psi Quote Link to comment Share on other sites More sharing options...
Spencer Posted August 20, 2013 Share Posted August 20, 2013 So yea ring seal a little sad, up to you how much you care? Its still going to chug along for awhile yet. 1 Quote Link to comment Share on other sites More sharing options...
Testament Posted August 21, 2013 Share Posted August 21, 2013 must be time for boost 1 Quote Link to comment Share on other sites More sharing options...
peteretep Posted January 20, 2014 Share Posted January 20, 2014 I was just looking around under the dash at a place to put the new ecu, and discovered that my heater is leaking from somewhere, looked like a couple of places. I will take it out some time this week. What are opinions on removing it all together and fit a fan only or is that a dumb idea? Quote Link to comment Share on other sites More sharing options...
Spencer Posted January 20, 2014 Share Posted January 20, 2014 Depends how much you drive in winter? in Straya cunt there's not much point. Quote Link to comment Share on other sites More sharing options...
peteretep Posted January 20, 2014 Share Posted January 20, 2014 is it generally considered a stupid idea for a street car? the interior of my escort is unusually hot even with the fancy radiator. It seems like I could fit a jabsco fan and hook it up to the outlets to blow air on the windscreen without too much trouble Quote Link to comment Share on other sites More sharing options...
UTERUS Posted January 20, 2014 Share Posted January 20, 2014 Like this kind? http://www.aliexpress.com/item/Safe-Shipping-NEW-Turbo-Blowers-Intake-Fan-3-12-V-In-line-design-High-Quality-and/509882472.html Quote Link to comment Share on other sites More sharing options...
peteretep Posted January 20, 2014 Share Posted January 20, 2014 you know it simon Quote Link to comment Share on other sites More sharing options...
UTERUS Posted January 20, 2014 Share Posted January 20, 2014 Do it, if you're cold then just shiver harder. 1 Quote Link to comment Share on other sites More sharing options...
peteretep Posted January 20, 2014 Share Posted January 20, 2014 OK I'll do it 1 Quote Link to comment Share on other sites More sharing options...
bigfoot Posted January 20, 2014 Share Posted January 20, 2014 Lancer currently rolls no heater or fan. Sucks when the window fogs up but easy enough to deal with Quote Link to comment Share on other sites More sharing options...
