peteretep's mk1 escort
atropine
  • Replies 400
i'm not quite sure, its flaming out all intake ports with injectors set at 19lbs as you suggested
The fuel holds quite good at about 46psi but appears to have air in it (sub par return line routing related), not sure if thats an actual problem though
we tested the ignition quite a bit and it seems to be sweet, not getting interference/misfires but im still not 100% on the timing. will the engine run if timing is 10 degrees out either side of tdc?
hall effect isnt missing any teeth
Remember hearing about a type of misfire years ago that has something to do with when the carbs are designed to suit engines with a different intake pulse? Some shit like that. But Id agree with comments above that ignition timing or incorrect firing order would be the first place to start. Hope you get it sorted and its a simple fix.
Car looks awesome BTW
Has been flashed with latest version from the website (unsure what rev number that was though)
Just make sure the valves open and close as you'd expect in regards to TDC etc? only way you get constant flames like that is when the intake ports are still popen when it fires, and the timing light seems to say its legit, so wouldnt hurt to check the cam.
Cam (the person) said he's gonna use my scope to check for noise properly to rule that out, and then set the base timing with the plugs out so it cranks nice and quick. and go from there?
Might pay to find a dial gauge?
